Old 13th January 2007, 03:19   #1
kosmo
kosmo's Avatar
Garage: M5 2002, LeMans Blue
Replacing flywheel when replacing clutch?
Is is typical to replace the flywheel when replacing the clutch? I have 50k miles. thanks
2002 M5 Lemans Blue
2000 Ferrari 456M
1999 Lexus Rx 300
2005 Vento Phantom Scooter (70mpg )
kosmo is offline
Old 13th January 2007, 04:24   #2
Gamedemon
Gamedemon's Avatar
Garage: Anthracite M5
Depends on the condition of your Flywheel.. and you cannot know the condition until you take it out ! I just replaced my clutch at 38k miles. The Flywheel looked perfect with no burn spots !!! sorry that this was not a straight answer, but it really depends....
Now, if you are looking for a perfomance (lightened flywheel) then it is a different story, but be prepared to pay for it quite a bit !
Gamedemon is offline
Old 13th January 2007, 05:13   #3
ssomed
ssomed's Avatar
Garage: 2000 M5, lemans blue
Good point gamedemon,
I would also add that it appears many aftermarket flywheels can add noise, vibration, or harshness.
There is much discussion on this topic if you search the clutch threads
I, also am waiting for the clutch to give out a bit more before replacement. I am currently thinking UUC direct fit organic or clutchmasters stage III. For less noise I would look at the dinan flywheel (If you can still get it).
good luck,
ssomed
ssomed is offline
Old 13th January 2007, 15:54   #4
Gamedemon
Gamedemon's Avatar
good luck,
ssomed
I ended up with the UUC organic direct fit... So far so good. I only have 300 miles since the operation. Some vibration in first and revese when initially engaging, but that is slowly fading away.. Otherwise, no noise, very smooth...
Old 13th January 2007, 17:05   #5
SeeSure
Garage: M5 Le Mans Blue
Had my original clutch replaced before Xmas (92k miles, slight slippage when dropping from 6th to 5th to over take) by my trustworthy BMW independant. When I picked the car up he confirmed that the flywheel was not needed, but he did say that when he rang the local dealer for the OEM clutch they asked him if he wanted the flywheel.
He responded to them that he didn't want the flywheel as he only changed that when it needed changing. Apparantly the dealer said that they always changed the flywheel as a matter of course...
His response " That's why your customers always end up coming to me"
So if you are paying for a clutch yourself make sure you really need the flywheel as it is common practice by dealers to automatically replace it !!
Why is the slowest person always at the front of the queue ???
SeeSure is offline
Old 13th January 2007, 18:32   #6
kalvin
kalvin's Avatar
Garage: 2000 m5 Blue
I had my clutch upgraded to cm stage 3 without changing the flywheel. I was at 50k miles also. BUt like above post you have to check the condidtion of your flywheel to determine this...
1995 Chevy Astro Cargo White Everyday working van
2000 M5 Lemans Blue/Black-silver my new LOVE
Clutchmaster stage 3 clutch, Back up camera, 2-12" infinity with earthquake 1000 , CCFL angel eyes, Stern 18" chrome wheels, DVD player, z3m short shifter, projector fogs, deleted factory mufflers, 16x9 nav screen with mk3, Ipod dice, hardwired V1 with remote display, 3.45 LSD
2003 Suzuki GSXR-750 for the hot days
kalvin is offline
Old 13th January 2007, 18:55   #7
Need4Spd
Need4Spd's Avatar
Think of it like brake rotors only you can't see it until after tear down. Often rotors don't need changing at the time the first set of new pads are needed but you have to check. The difference is labor and ease of inspection. You can easily tell if a rotor is worn out, and it's easy to replace. But once you go with re-using a flywheel, it's inside, and it's not easy to swap it again. So just be sure.
Need4Spd
Need4Spd is offline
Old 13th January 2007, 19:15   #8
greg
greg's Avatar
Garage: 2000 Anthracite
I'm in the same boat - want to replace the clutch soon, but suspect the flywheel is OK. How much does the flywheel cost?
greg is offline
Old 13th January 2007, 20:34   #9
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
List is $885. You should be able to buy it for about $800, maybe a little less.
gsfent is offline
Old 16th January 2007, 08:40   #10
M5Joe
M5Joe's Avatar
Garage: BMW M5 Anthracite
My original throwout bearing failed at 102k miles, so I replaced the original clutch, throwout bearing and pressure plate with a UUC Performance Organic direct fit clutch but kept my original flywheel. Big mistake. (My mechanic asked me why go aftermarket when the OEM lasted more than 110k miles).
The new clutch material never mated properly with the old flywheel and I wound up with a lot (I mean A LOT) of shudder on engagement of first and reverse. This never improved much and I was contemplating paying the labor a second time to replace the flywheel when the new UUC pressure plate catastrophicly failed, breaking into 3 pieces, at 3000 miles. (Now,explain to me exactly why I went with aftermarket clutch?)
I called UUC and they talked me into their just released moderate lightweight single mass flywheel at a discount and they sent me a new clutch kit (under warranty). At least the flywheel was cheaper than OEM.
I had quite a bit of driveline chatter despite the sprung hub clutch and changing the transmission fluid to the UUC recommended concoction. Suprisingly, the chatter is now intermittent, but after several thousand miles is still quite loud when present. I'm very careful not to let the car idle with the clutch out when my wife is around.
The moral? Think very hard about changing a high milage flywheel when changing the clutch, especially if going to an aftermarket clutch. Also, rethink the aftermarket clutch. The OEM clutch may cause a few less headaches.
Joe
M5Joe is offline
UUC Direct fit performance organic issues HJB1988M5 E39 M5 and E52 Z8 Discussion 376 26th June 2009 19:02
just had clutch replaced and... m5jmh E39 M5 and E52 Z8 Discussion 30 22nd October 2008 00:55
Installed: Clutch Stop for my Bi-Turbo puppypilgrim ALPINABoard.com | BMW Alpina Discussion 6 25th October 2006 03:44
UUC clutch owners step inside. ( No opinions please) Jayson E39 M5 and E52 Z8 Discussion 19 27th February 2006 02:00
New Sachs Power Clutch tripleD E39 M5 and E52 Z8 Discussion 13 12th April 2005 22:04
Page generated in 0.15905 seconds with 12 queries
