Rear tire wear and alignment. - BMW M5 Forum and M6 Forums
Old 12th January 2007, 06:34   #1
bimmernut1
bimmernut1's Avatar
Garage: Ti Silver M5, Red Porsche C4S, Carbon Black BMW 35i Msport, Tobacco Metallic 911SC
Actually two questions.
1) How many pairs of of rears do you typically go through per front pair.
2) What alignment is available on the M5 rear?
I have some Toyo T1R's on now. The fronts are around 6mm and the rears are down to 3mm on the left and 2mm on the right. The left rear is wearing evenly across but the right rear has extra wear on the inside. It could be I've been having way too much fun.
2003 Titanium Silver BMW M5
1996 Guards Red Porsche 993 C4S
1979 Tobacco Metallic 911SC
2013 Carbon Black BMW X3 35i M sport
bimmernut1 is offline   Reply With Quote
Old 12th January 2007, 07:34   #2
Need4Spd
Need4Spd's Avatar
The rears wear almost 2x as fast as the fronts. The differential isn't as great with stock size front tires since they don't hold up as well to load. If you run rears on front, it's much closer to 2x but you can rotate them. I'm not sure what adjustments can be made to the rear alignment.
Need4Spd
'01 M5 (now my brother's car) UUC SSK + Rogue WSR/RE Tranny Mounts+Royal Purple Synchromax/Axxis ULT Pads/StopTech SS Lines/TC Design from BeastPower Anti-roll Bar Brackets/Dinan LtWtFlywheel and Stage 3 suspension/4xOEM rear 275 Goodyear F1 Asymmetrics/Vines thrust arms/IATS relocation/10w-60 oil/hardwired Escort 9500i/Euro Armrest/TEC Cupholder/IceLink/PowerChip 91 Gold/TUBIs!/Strong Strut/BSW Stage 1/BT/Angel iBrights 3.0/space-saver spare by Bimmerzone
'11 Jaguar XFR, Quicksilver exhaust, Escort 9500ci
Unnamed weekend Italian 2 seater with DCT
Future - F10 M5 with manual transmission?
Need4Spd is online now   Reply With Quote
Old 12th January 2007, 07:45   #3
Lawaia
Lawaia's Avatar
Garage: '02 M5 /// Sterling Gray
Sales Feedback: (5)
I had to dial out a bunch of rear camber on my old 540i/6 due to uneven tire wear. I'm going to assume the same adjustment can be done on the M. But I did read somewhere there is much less negative camber on the M5 as opposed to the 540i (BMW factory specs).
'02 M5 Sterling Gray / Black
UUC EVO3 w/DSSR
Supersprint Cat Back Exhaust
Lawaia is offline   Reply With Quote
Old 14th January 2007, 00:52   #4
jclyman
jclyman's Avatar
My rears wore faster than the fronts ... lasted about 80% of the time of the fronts ... even wear although a little more on the inside of rears ... (bought the car new).
I ran fairly high pressures - 40 front and 43 to 45 rear - mostly high speed longer trips ...
- Daniel Boorstin
jclyman is offline   Reply With Quote
Old 14th January 2007, 02:56   #5
ard
Super Moderator
ard's Avatar
Many erroneously believe that the camber has a major impact on uneven wear... imperfect toe will scrub tires much faster than mild camber.
The BMW specs on toe allow way too much- don't just let then "check specs"- have them set it to ideal. Should be some threads in the FAQ sticky.
I'm running 275s front and rear, and rotating, so no reall difference. The 275s up front wear much more evenly than the 245s did...
A
Old 14th January 2007, 04:52   #6
bimmernut1
bimmernut1's Avatar
Thanks for the input. I'll check the stickies for info on the rear alignment specs.
I just checked my mileage. I'll end up getting about 12k miles out of my rears and at the rate the fronts are wearing, I'll get about 15-18k out of them. In the meantime, I plan to order another pair of Toyo Proxes T1R's for the rears and have them ready. A couple mils of thread is not very much but I'm on winters right now so I'll put this off for a month or so.
I've got to give props to the Dunlop Wintersport M3's as well. Driving this weekend on sleet and snow has been completely uneventful. I don't think the DSC light flashed but a couple times and I was able to accelerate away in a straight line just like some other vehicles more known for their winter prowess.
Lets talk tire wear... olis1 E39 M5 and E52 Z8 Discussion 47 25th March 2008 20:35
Rear wheel alignment? Blue Thunder E39 M5 and E52 Z8 Discussion 20 28th October 2006 18:05
Help! Need info for Alignment unusual tire wear? mruiz0280 E39 M5 and E52 Z8 Discussion 4 13th June 2006 01:30
Crazy tire wear, need some advice Pete E39 M5 and E52 Z8 Discussion 26 28th July 2005 01:43
The definitive Ground Control coilover suspension discussion thread - step on in! Redshift E39 M5 and E52 Z8 Discussion 61 1st August 2004 21:27
