Update
My SA got me in today on 45 minutes notice. Code read misfire cylinder#2. Their procedure on a one-time misfire fault is to swap the coil to another cylinder and see if it reoccurs. If it does, the coil will be replaced. As for the rough running, I was told that if a code is tripped, the car will stay in limp mode. As has already been stated, killing ignition and re-starting resets to normal. Mine actually resolved without doing that. Car is still running fine. I guess we'll see if it happens again. I guess it was worth the trip, as they also replaced a broken CD changer. Thanks for all the knowledge shared.
'03 Sterling Grey
Full leather
DICE ipod integration
DINAN exhaust
