Lots of smaller screws in the two wheel wells, but two big torques in the front lip. I did it once with the car on its wheels and once on a bridge. Obviously on a bridge it is very easy. I guess 20 minutes orso. On the ground you will have trouble re-assembling some screws that go in the bottom plate.
If you don't have the torque to fit the two front lip torques, don't even bother because you can't do it.
The 2 main front bolts are TORX bits. Then a bunch of standard metric head screws underneath the front bumper on either side as parto f the wheel well covers.
I found it easier to remove the wheel well liners all together. If you do that, you'll have a few screws inside the front tire well to undo to get the lower half of the liner out.
Also a few tiwst lock screws you'll use a phillips head screw driver on.
Once all that is undone, it just pulls off. I've removed it and put in on 2x with the car on the ground. Not difficult at all.
__________________ 2002 LMB/LMB M5 - Alcantara Headliner, Electric Shades, Folder Down Seats, M-Audio
-Britalman Exhaust, Brembo GT 355f/345r Big Brake Kit, Centric Posi-Quiet Pads, AA CAI
-UF IATS Relocation, UUC Evo3 SSK + DSSR, UUC Clutch Stop 19" Breyton Spirit Rims
-TCD Rear Sway Brackets, Euro Angel Eyes, Angel iBright v3.0, Stealth Bulbs, Stealth One
-Valentine One, Roof Spoiler, OEM Voice Control, OEM Trunk Storage Bin, 13% Solar Gard HP Tint
-http://gallery.slipoftime.com/m5
TIS has a good article on removing the bumper, but it is as everyone says .. pretty simple with the right torx bits... much easier than some cars I have had before.. I was quite suprised
1999 Imola Red M5. Extended Caramel Interior Mods on my pre-update beast:Eisenmann "Race" exhaust (76mm tips), 19" Hamann PG2's, AACAI, Clear Angel Eyes, MK4 Nav, GC's M5 Coilover kit w/front camber plates, Dinan Front and rear sway bars, D/A swaybar mounts, Dinan front and rear strut brace, Braided brake lines, Eibach 3mm wheel spacers, Rogue Engineering underdrive pulleys, IATS Relocation, Powerchip, Xenon foglights & Lower engine covers w/Brake duct cutout
2008 Volkswagen Golf GTI. The wifes new car
2005 Ford Territory Ghia. The wifes car. (Sold)
1986 Toyota Landcruiser HJ75. The farm ute.
torx bits can be had at any tool shop, i bought a set from my local Sears.
Also, as you're sliding off the bumper cover, you need to disconnect the hose to the headlamp washers. After youve done it a couple of times, it's an easy 10 minute project to get the bumper off. I would bet you can find pics at bmwtips.com, as i think someone did a write up for a dinan cai install.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
I got mine from the local hardware shop... Its a T60 or something.. I dont remove the entire innet wheel cover, just remove the outter 8mm bolts from inside of it... then it just slides off.. remember to disconnect your headlight cleaning if you have it
