Old 7th January 2007, 10:18   #1
phid_bombadier
phid_bombadier's Avatar
Garage: '01 M5 - Silverstone
Adventures with Headlight Adjusters
I was fed up with my left headlight pointing at the ground so after reading the instructions here:
http://www.blueheronkayaks.com/bmw/adjusters.pdf
What I used:
-3/4 inch plastic (kitchen cutting board type material from TAP plastics in Bellevue)
-1x 2 1/2" SS 10-24 machine screw (Ace Hardware)
-2x #10 acorn nuts (Ace)
-Coping saw - to cut plastic
-Dremmel + cutting wheel - to shape plasitc, fine cutting work
-Drill with 11/16" bit
-flat screwdrivers
-heat gun
-8mm, 10mm sockets
-torx drivers
Total in parts was about 5 bucks.
Notes beyond the above instructions:
1) It's not important to be very precise with your pieces. Dremmel can do it all!
2) Try and shorten and totally round down the acorn nuts. I wasn't able to with the tools I had on hand so the ball and socket joint fit is not good and the nut may pop out of the socket. (Something I may have to revisit in the future )
3) Reattach the leveling unit ball joint BEFORE putting the black inner frame back on. (Don't be stupid like me and have everything back together only to realize it's near impossible to get the leveling unit joint back together.)
4) Having compressed air to blow out the housing and lenses is really helpful
5) the adjusters are much bigger than I had visualized looking at pictures - see razor blade for reference
Here are some pictures to supplement the instructions above.
Took me somewhere in the 4-5 hour range but would have been faster if 1) I had more/better power tools 2) I didn't have to disassemble for the second time.
I initally tried to do this without taking the lights apart but found it impossible to access the vertical aim adjuster.
Hope someone else can benefit from my pain...
BTW it's nice to be able to see more than 15 feet infront of the car!
--Mike
phid_bombadier is offline
The Following User Says Thank You to phid_bombadier For This Useful Post:
SSense (4th August 2008)
Old 8th January 2007, 00:13   #2
wiggis
wiggis's Avatar
Garage: Le Mans Blue
Congrats. I went through a similar chore on my 2000 M5 a little while back, but had the luxury of lenses which came off easily, and a pack of new adjusters from the dealership. Couple of scary moments with the vertical adjuster ball joint ........ !
2007 Honda CR-V 2.2 CDTi Ex - Silver and fully loaded
2006 MINI Cooper S JCW GP - Thunder Blue #1236 of 2000
1999 Volvo V40 T4 - Black / Black
Gone but not forgotten
2000 E39 M5 - Le Mans Blue / Silverstone
2007 R56 MINI Cooper - Pure Silver / Black
wiggis is offline
Old 8th January 2007, 09:06   #3
gherardini
gherardini's Avatar
Garage: 2002 M5 Titanium Silver
Sales Feedback: (5)
Send a message via ICQ to gherardini Send a message via Yahoo to gherardini
--Mike
nice ambitious job! i always found that working on my cars and motorcyles was *the* best reason/excuse to run out and buy new tools.
even the ministry of war & finance can't begrudge you running out to get them when your vehicle is in various staes of disassembly and you "need" a tool to do the job right...
'02 M5 TiSi-SBI [Sexy Black Interior] - "Audrey"
BMWMOA iBMWr IBA#7268 LPR#71 SEAT#17
- Valentine1 - hardwired
- StealthOne
- SS Exhaust
- GrafxWerks ///M5 Lighted Door Sills, all 4 doors
- Hella Euro clear corner headlights
- Steath Auto Turn Signal Bulbs
- Predator ICE v2.1
- Xenon fog lights
- CNS Racing clutch
- TC Designs Sway Bar Brackets
'87 K75S - "Maybellene"
'00 R1100S - "Tresor!"
Sierra Vista, AZ
gherardini is offline
Old 8th January 2007, 18:21   #4
Kin Mak
Kin Mak's Avatar
Garage: BMW E46 M3
Sales Feedback: (3)
Send a message via MSN to Kin Mak
Can you buy the regular adjuster from BMW if it is broken? I broke mine and I just want to relpace it with the OEM piece.
BMW E46 M3 SMG Carbon Black/Cinnamon
BMW E39 M5 Avus Blue - SOLD
KinMak.com - Loads of Photos - Elara Online
Kin Mak is offline
Old 9th January 2007, 01:03   #5
wiggis
wiggis's Avatar
Yes, you can, so long as you have pre-2001 'non angel eyes' headlights.
Look on www.realoem.com for the part number
Cheers !
wiggis is offline
Old 21st January 2007, 22:00   #6
colbywan
colbywan's Avatar
Garage: '01 E39 M5 Lemans Blue w/Blk & Blue Int
You can buy METAL adjusters from one of our sponsors, I plan on buying the metal ones that way I know they'll never break again.
http://www.h-i-d.co.uk/products1.shtml
Just a thought.
01 Lemans /w blue & blk interior, /w alum trim, MK4 DVD NAV, OEM Sirius Retrofit, Rogue SSK, Blk-out Kidney's, Dinan CAI, Dinan Stage II Software, Dinan 3.45 Diff, Remus Exhaust, TC Design Rear Sway Bar Brackets, Schnitzer Pedals, Schnizter front splitters-lip, Hamann rear diffuser, Hamann roof spoiler (soon to be installed), 19x8.5 19x9.5 Axis Penta Wheels, 20%
Tint all around
http://www.youtube.com/watch?v=G144168JfCY
colbywan is offline
Old 22nd January 2007, 18:00   #7
phid_bombadier
Just a thought.
I also found delrin ones for sale in the US by http://www.odometergears.com/subpages/bmw.html but I'd rather not spend 80+ bucks PER side when the pieces can be made for less than 5 bucks.
Now if the replacement pieces were closer to 20 bucks per side then it would be a no brainer.
--Mike
Old 23rd January 2007, 18:20   #8
ehssan_alkhiyami
ehssan_alkhiyami's Avatar
Garage: BMW M5 E60
Send a message via MSN to ehssan_alkhiyami Send a message via Yahoo to ehssan_alkhiyami
thanks for the great information .. I personally bought the metal ones from a guy in UK ..it was great and I'm so happy with it
E.K
ehssan_alkhiyami is offline
Old 23rd January 2007, 21:11   #9
colbywan
colbywan's Avatar
I plan on doing the same, but I want to wait til it's a little warmer to tackle a project like that.
Tint all around
colbywan is offline
Old 23rd January 2007, 21:45   #10
ehssan_alkhiyami
Garage: BMW M5 E60
well actually .. it takes 5 minutes to remove the headlights from the car then the rest of the job is indoor ...
E.K
Broken Headlight Adjusters Blown540 E39 M5 and E52 Z8 Discussion 4 27th August 2006 16:41
FS: new pre-AE headlight adjusters, used passenger side airbox, used fog lights HDClown For Sale or Wanted 2 23rd September 2005 03:05
Smashed headlight...have a quick question Angel E39 M5 and E52 Z8 Discussion 9 2nd May 2003 19:02
european headlight adjusters on dash jh_m5 E39 M5 and E52 Z8 Discussion 7 1st August 2001 17:35
Page generated in 0.17757 seconds with 12 queries
