So I normally track my old porsche but the weather was too cold for me to handle a 2 hour drive to thunderhill with no heat or defrost (read: open windows) so I opted to take my m5 for the first time to the track - some observations that might be relevant for those thinking of driving on a track:
1/ the horsepower is intoxicating. I run completely stock but the ability to just power down helped me track down a bunch of cars on the track. If anyone knows thunderhill, i was hitting 125 on the front straight before braking for 1. (the mix of cars ranged from EVOs to Caymans to Volvos to Corvettes)
2/ this car is HEAVY and it will let you know it (my comparison is my porsche that weighs 2000lbs), though the weight is beneficial in spots (downhills and long wide out drifts). the car is very predictable. the weight is an issue for brakes though - i did get fade, more than i expected
3/ tall drivers are a tough fit with a helmet - i am 6-4, had a few head bumps going over the crest of hills and was sitting in a modified position
4/ the stock clutch is too weak for hard "track-use" - In the morning i was using 2nd through 4th for shifting but the heat buildup actually made the clutch slip a little so I opted to keep the car in 3rd or 4th afterthat and everything was fine for the rest of the day. now my stock clutch should be near the end of a respectable life anyways (37k miles on original clutch) but i was still surprised by the slipping
5/ the pedals are tough to heel/toe, esp if you have more narrow shoes. I had my regular race shoes on that suit me fine with my porsche, not so with the m5
6/ yoko advan sports are pretty decent on the track - no excessive noise, firm sidewalls, built heat quickly and didnt shred. the weight however pushed the tires to the limit - i was losing tire towards the end of 20 minute sessions esp when I was trying to get an extra 10th out of the car.
7/ the heated seats rock when the outside temp is 38F and you have front windows open
Overall a decent car and it helped me make up my mind where I am going to spend money on it first:
- brakes and pedals
- suspension
- then speed
