My nav has started to occasionally locate itself as being about 40 miles east of where it actually is. I've tried everything - unplugging the electronics, changing the CD etc. but nothing seems to work - I'd say it's OK about 75% of the time and hopelessly lost the other 25%. What to do?
I would first check to make sure the GPS unit is functioning... check in the service menu of the NAV (the one where you hold MENU down in the set menu for about 5 seconds)....
If the GPS is not working you will find the version numbers for the GPS unit will show as 0.0.0.... where it should be something like 7.3.10 (for example).
If they are showing 0 then your GPS unit inside the nav unit (assuming MK4) is playing up. normally a reset will fix it but if it keeps happening then the nav unit / gps unit (for mk1-3) may be on the way out and need replacing.
just a thought...
1999 Imola Red M5. Extended Caramel Interior Mods on my pre-update beast:Eisenmann "Race" exhaust (76mm tips), 19" Hamann PG2's, AACAI, Clear Angel Eyes, MK4 Nav, GC's M5 Coilover kit w/front camber plates, Dinan Front and rear sway bars, D/A swaybar mounts, Dinan front and rear strut brace, Braided brake lines, Eibach 3mm wheel spacers, Rogue Engineering underdrive pulleys, IATS Relocation, Powerchip, Xenon foglights & Lower engine covers w/Brake duct cutout
2008 Volkswagen Golf GTI. The wifes new car
2005 Ford Territory Ghia. The wifes car. (Sold)
1986 Toyota Landcruiser HJ75. The farm ute.
Thanks a-m. I checked and it was all zeros so that's a start, I guess.
what version of NAV do you have 2, 3 or 4?
I found that it was more common with the latest version of the nav software. which version are you running? has anything changed since it started happening or its just started occuring by itself?
