Here's an easy upgrade if you are intested in increasing the light ouput and playing with different colors on your footwell lights.
Our footwell lights uses festoon bulbs. The brightest LED festoon bulb I am currently aware of is called "Superstar Superbright Festoon LED bulb" from autolumination.com. They are 10 bucks each. You need 4.
I love blue color so I replaced my stock incandescent footwell lights with one of these superstar LED's.
Done! I am happy with the results. See attached photos.
It is possible also to increase the light output even further by using two of these superstar LED's side by side, solder them together, stuff them inside the footwell light assembly and solder the wires to the connectors (similar to what I've done to the trunk light that I just posted here: http://www.m5board.com/vbulletin/sho...585#post941585
I may do this soon : )
Another worthy upgrade for me. Cheap too! Bulbs by the way are simple plug and play, remove and replace (if you only use one bulb). Removal of footwell light assembly is easy too, takes 1 second flat.
MY2001 Imola Red
Lux. Black Interior
Painted Calipers,
Autowerke CAI
Powerchip Software Upgrade
Tubi Catback Exhaust
361RWHP
425HP and growing!
Remove footwell light assembly by pushing the plastic assembly housing from the rear to the front using a flathead screw driver.
Push forward, then push down on the screw driver to remove the plastic housing. If it wont come out, do not force it, it may have been installed backwards so try the other way around.
Remove stock bulb and replace with your choice of superstar LED color. That's it!
You can possibly use two superstar LED's but you will have to solder the two together. Takes more time and work. Hope that helps. Dont forget to order an extra superstar LED and replace your glovebox light too!
ECB, thanks for the compliments. Always appreciated.
Mark, I know, non stop upgrades to our beast huh. But this upgrade is way cheap compared to your other upgrades.
How much was the supercharger again? I wish I had your money.
Dan
Originally Posted by Chessie
So, is it a straight plug and play switch out if I want to do this with only a single bulb in each footwell light?
Very cool! I'm going to do this too! I'll just try popping in one plug-n-play first, before I break out my soldering gun. But I'm an old EE, so maybe I will get the urge to use double bulbs.
Rex ///M5 E39 2000, Titanium Silver, Black Interior. Supersprint exhaust, Powerchip 91, Umnitza Projector39s with clear corners, projector foglights, front brake air ducts, Ultimate pedals, Blitzsafe aux adaptor for iPod, TV tuner, radar, power rear sunshade, armrest storage tray, Ultimate cup holders, blue LED interior lights.
Ex-M3 E36 1999, Green, Black interior, 4-door. 5sp manual.
Dan
Hi Dan,
Can you provide a link to the bulbs you bought? I went to the autolumination web site but can't seem to find the right ones.
01 M5 LMBs/LMB SSR GT3 Wheels, TC Design Rear Sway Bar Brackets, Dinan Stage 3 Software, V1 Hardwired
