Thanks. Glad you liked the upgrade.
Please note, the light is very bright because it was night time when I took the photos and very dark inside my garage. Dont be disappointed when it is not as bright during the day time.
This is no different than angel eye bulbs. It is always brighter at night, even when the bulbs upgraded to the predator ICE LED. Bulbs will always be brighter at night.
Anyway, here are details for the inside trunk light. You will need to remove the stock bulb first, then cut the clips connecting the bulb to the connector as close to the connector as possible to make room for the LED bulbs. You need to leave enough metal so you can solder the wires to it.
Note: LED bulbs have polarity! Which means you need to connect positive to positive leads and negative leads to the negative leads. Otherwise, it wont work!
Use one or two 1.5 volt AAA battery to determine which side of the LED bulb is positive and which side is negative. Mark the positive with a red marker.
Align the positive side by side, attach a wire and solder the two bulbs together.
Then you also need to determine which side of the car connector is positive and negative so before you solder the wires to the connector, check your car and determine which of the two wires is plus and minus. Then solder the wires permanently to the proper terminals.
Hope that helps.
BTW, yes, I currently have the stock incandescent dome interior lights as you noticed. I had white LED festoon regular bulbs in there but removed it and will be replaced soon with the same superstar bulbs too.
Dan
Originally Posted by gherardini
i am sooo doing this one. the white light looks great. and for thirty bucks! compare it to the yellow interior lights seen through the back window. haha! great job! thanks for the write up!
btw... how did you attach the leads to the dual festooned bulbs? can't see through the tape...
