Old 5th January 2007, 05:28   #1
dcaron9999
dcaron9999's Avatar
Garage: Carbon Black 2002 E39/M5
OMG! Just changed tranny oil to Royal Purple
I just changed my Manual Transmission Fluid from OEM to Royal Purple Syncromax MTF. I'm amazed by the smoothness of the shifts. Best $25 noticeable mod I've done in long time. The old fluid (probably LT1) flushed out pretty clean. I highly recommend the RP Syncromax for those of you with notchy shifting issues, caused by old fluid, and/or cold weather.
I have allways been an OEM fluid consumer, but decided to give the RP products a try, after the feedback on this forum. I changed out my tranny fluid with Syncromax, my diff fluid with Max-Gear 75W-140, but stayed with good old Castrol TWS10W60 engine oil, since I had a batch of 6 liters left from my previous E46/M3.
Next time around, I might try AGIP 10W60. I am a little more conservative with the engine, so I doubt I will try the 10W40 Multigrade RP Engine Oil.
dcaron9999 is offline
Old 5th January 2007, 05:32   #2
Beamer_usa
Beamer_usa's Avatar
Garage: explosive ford pinto
Keep us posted on the long term 5K......and on
Dinan Cans
Dinan Software
Beamer_usa is offline
Old 5th January 2007, 07:57   #3
Blockdoc
Blockdoc's Avatar
Garage: 2003 Sterling Gray M5
I had a similar experience with a dramatic improvement using RP and 33k miles. After 1500 miles with RP, the improvement is pretty much gone (perhaps I am used to it?) I had never changed with OEM fluid...so I can't compare new vs. new.
Brian
2003 Sterling Grey M5
Dinan Free Flow Exhaust, Dinan Rear Sway Bar
Super Sprint Headers
Custom tuned by ESS
Rogue Octane SSK and WSR
DICE Ipod connectivity
Bimmian Black Kidney Grilles
Ultimate Pedals
Rear Wheels Up Front (275s all around)
Supercharged by ESS!! (Kit number 01)
Blockdoc is offline
Old 5th January 2007, 12:08   #4
tranck
tranck's Avatar
Garage: 2000 M5 - Silverstone Metallic
I tried the RP and could not tell a bit of difference - I then switched back to the OEM - still couldn't tell which was which.
tranck is offline
Old 5th January 2007, 15:50   #5
dcaron9999
dcaron9999's Avatar
How long did you keep the RP in? I noticed it took about three driving errands, with a large number of gear shifts before noticing a difference.
Old 5th January 2007, 15:57   #6
dcaron9999
dcaron9999's Avatar
I will take that into consideration, and post back later. What did you end up doing - returning to LT1/LT2?
Old 5th January 2007, 16:07   #7
tranck
tranck's Avatar
I had it in for a ct least a month or so - I do remember that after speaking with my BMW tech that he said the OEM was much thicker than the RP and probably a safer route to go.
The other things is that whenever you change ANY transmission fluid depending on how long it's been, you might see a difference just from the new fluid.
I don't want to throw water on your story at all - just my experience.
tranck is offline
Old 5th January 2007, 20:46   #8
dcaron9999
dcaron9999's Avatar
I had it in for a ct least a month or so - I do remember that after speaking with my BMW tech that he said the OEM was much thicker than the RP and probably a safer route to go. The other things is that whenever you change ANY transmission fluid depending on how long it's been, you might see a difference just from the new fluid. I don't want to throw water on your story at all - just my experience.
No offense taken at all. Good feedback which I will take into account. New fluids would all probably feel different initially. I'll see if the RP Syncromax benefits fade away after a while, and if so, switch back to OEM LT2. It's easy and cheap enough to DIY anyways. Thanks for sharing your experience.
Old 5th January 2007, 21:06   #9
Sebring NL
Sebring NL's Avatar
I got two bottles waiting on the shelf for the E34's gearbox. Just need to do the clutch anytime soon, so I'll save it for that occasion..
Along with brand new shifter linkage etc, this 1991 lady should shift like a toyota!
Sebring NL is offline
Old 5th January 2007, 21:11   #10
THRILOS5
THRILOS5's Avatar
Garage: 2001 m5 black
Sales Feedback: (3)
I used Redline MTL such an improvement over stock fluid specialy in cold weather shifting,so I dont doubt the Synchromax improvement
e39 M5
Audi S4
300ZX tt 580hp@20psi
Mustang GT 5.0L
Suzuki GSXR750
THRILOS5 is offline
S85 V10 oil level service bulletin cobradav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 5 12th November 2006 19:10
BMW Revises E60 M5 oil service procedure SuperBMW E60 M5 and E61 M5 Touring Discussion 9 3rd March 2006 00:17
ROYAL PURPLE Motor Oil VS OEM Castrol TWS 10W60 marcvip E39 M5 and E52 Z8 Discussion 30 1st March 2005 22:26
Help - Oil From Somewhere x703jko E39 M5 and E52 Z8 Discussion 9 27th December 2004 15:03
Oil Facts And Myths DrRob E39 M5 and E52 Z8 Discussion 9 21st December 2001 23:20
Page generated in 0.16313 seconds with 11 queries
