Interest in Twin Turbo M5? - Page 35 - BMW M5 Forum and M6 Forums
Old 5th February 2008, 17:17   #341
wilsodh
wilsodh's Avatar
Originally Posted by BigBump View Post
I was thinking about the sleeves, and while I see no issues with half a bar, once they get over 12, at high rpm, I could see some issues with ring lands. However, all of that is a function of hotspots on the pistons and tuning. I think on the supercharged cars running into problems, it was because the vanos was advancing the cam timing at higher rpm, which was causing some detonation.
I think timing & tuning pushing the boost envelope with the S62 has generally been on the conservative side due to concerns about the S62 short block. We're not talking about backyard warriors who don't know FI fundamentals and managing detonation. At least four different tuners reached the same conclusion.
If HPF can reliably get 1000hp out of a stock S62 short block.. well, I was gonna say I'll turn in my s/c, but I love the sound too much!
Cheers
D
'00 Royal Red/black/walnut M5
'El Diablo'
’00 Black/black DA s/c M5
Carrillo rods, Arias pistons,
Schrick cams, Vortech T-trim,
Supersprint headers/exhaust,
Old 5th February 2008, 17:36   #342
jimmyz2
Banned
Garage: 1995 540i 4.4L supercharged
"At half a bar (~8psi) I would guess that 650-700 easy. Also, it will be easier on the engine because there's no crank loading from the supercharger belt."
Actually,it will be harder on the engine due more boost spread over a wider RPM range.With a CF system.the engine only "sees" boost at much narrower range and hence,less wear on the motor.
jimmyz2 is offline   Reply With Quote
Old 5th February 2008, 18:23   #343
HPF Chris
Garage: BMW M3, 330 and 530
This unit is why HPF can and will be successful. It simply is badass, and the relationship they have with AEM will ensure the tuning on it is top notch.
http://aempower.com/ViewCategory.aspx?CategoryID=116
The two best things about the unit are the fact that it can drive larger injectors and control cam timing systems while keeping all the other functions of the ecu intact. Also, the interface for their engine management systems is really intuitive and after you get through the learning curve, easy to use.
If that's not enough, read the forums on the F/IC and you will see exactly how powerful the system is when combined with a UEGO wideband and the AEM tru boost controller.
We hired AEM's lead engineer and we developed our own engine management system. AEM manufactured it for us. The item above is AEM's new ignition and fuel computer which I hear works very well, but it is not what we're using. We developed a "plug-n-play" full standalone that piggybacks on top of the factory DME.
Here is a picture of our EMS. This pre-configuration is for the E46 M3. I will have pictures of the pre-configuration for the E39 M5 shortly.
Chris Bergemann
HPF Chris is offline   Reply With Quote
Old 5th February 2008, 21:07   #344
FastPOLAK
FastPOLAK's Avatar
Garage: 2001 m5 JET black
i think i just had an accident
FastPOLAK is offline   Reply With Quote
The Following 2 Users Say Thank You to FastPOLAK For This Useful Post:
BMWMPWR (7th February 2008), gsfent (5th February 2008)
Old 5th February 2008, 21:59   #345
alquazi
Garage: 2000 M5 Alpine White
Hi Chris,
What modifications would be required for the tt setup if I would Install it in my M5 with the schrick cams, Headers, and free flow exhaust?
Thanks,
Al
'00 BMW ///M5 Alpine White
Mods
Evolve stage 3 tune
Schrick cams
Hamann Headers (High temperature coated inside and out)
Custom made exhaust (cat delet)
KW Coilovers V3
WP Pro BBK (360 mm rotors, 8 pot calipers front, 6 pot calipers rear)
alquazi is offline   Reply With Quote
Old 6th February 2008, 07:28   #346
jimmyz2
Banned
Chris,I know the new AEM is bad-***.But is it a full standalone or a piggyback?What can it do more than the other piggybacks out there?Does it allow you to control fuel/timing etc. and then piggyback for AC and other OEM functions?
Old 6th February 2008, 15:38   #347
BigBump
BigBump's Avatar
Garage: '95 740i Sport, '88 750iL, '00 Jet Black M5
HPF - I figured you worked with AEM to develop a custom computer using a lot of the technology from their I/FC, since their commercial one only does up to 6 cylinders. Regardless, its badass. Is that an onboard 3bar map sensor?
D - You're right, I'm a backyard warrior who doesn't know about tuning. However, it's been discussed at length that the main bearings lose their film strength at high rpm, fail, and then rods bend and people have accused the rods of being the faulty part of the shortblock. Nissan had the same problem in their SR20 race engines back in the early 90's and developed bearings with more oiling galleys and fixed the problem. Subsequently, the rods stopped failing.
olis1 - Naw, I just came from the turbo import world. I've always loved BMWs and the M5. I have bought a lot of stuff from, and followed HPF for awhile. Nothing but the utmost respect for them. I've seen tons of hate on them in the supra world already - same things people are saying now, just like the guys on the M3 forums when they made their M3 kit about the block can't take it and this art will fail or that part will fail. They have come correct with their products everytime, so if they say they can do it, I believe em. Kinda like I'm Morpheus and they're Neo.
jimmyz22 - The supercharger is always loading the crank and as such all the bearings in the system. That additional force is there during startup, constantly through the rpm range, etc. Turbos load the engine when there's a load put on the engine, giving a responsible driver time to warm up the car, make sure the oil pressure's good and then beat on the car with that additional boost you're talking about. Holed pistions and broken ring lands happen from heat problems and poor tuning.
I'm just happy to see that this is happening. I'm very excited to see that M5 standalone and the rest of the developments ahead.
-Bump
BigBump is offline   Reply With Quote
Old 6th February 2008, 20:50   #348
jetblack01m5
jetblack01m5's Avatar
Garage: '84 911, '06 Cayenne TT
Just a guess on my part, but you'll lose the headers (assuming the turbo system isn't remote mount). The cams could probably be accounted for in a DME reprogramming and the free flow exhaust should be far enough down stream of any exhaust plumbing changes that it won't matter.
jetblack01m5 is offline   Reply With Quote
Old 6th February 2008, 21:02   #349
wilsodh
wilsodh's Avatar
Hey Bump, if I seem skeptical in some of my comments, it is not a knee-jerk thing like some of the 3r/bimmerforums and other crowds (notice I've never said 'kaboom' ) Informed experimentation, pushing the envelope, and seeing what can be done with the M5 is a very good thing indeed! I'm really looking forward to seeing a tt set up. As I've stated, I think HPF has the deep pockets and know-how to make it happen.
Over the years, some good minds have been applied to boosting the S62. There have been some lessons learned along the way. If it is of any help, I thought I'd share what seems to be a main concern high boosting this engine. It is not the bearings, and it is not detonation. It is the thin walls and the fact that the engine is aluminum and not grey iron, as is the rigid S54. Two cracked blocks would seem to indicate the concerns are well founded. Shadowman also had concerns about the alusil coating of the cylinder bores with high-boost applications. Given the number of pistons that have failed, it may also be prudent to worry about the strength of the stock pistons under high boost.
That said, I'm 100% 'pro HPF', although I'm not big on pre-selling and tossing around big numbers (ala Currency Motor Cars). I really like HPFs pump gas/racing gas feature on the e46. That is waaay cool!
Dave
Old 6th February 2008, 21:03   #350
Ted
Ted's Avatar
Garage: 2001 M5 Jet Black/Black
Sales Feedback: (6)
Does anyone know if a TMS shark injector will work with the HPF kit or will the AEM software and engine management over-ride anything the injector does?
2009 Toyota Tundra TRD Black/Gray
aFe cold air intake, aFe throttle body spacer, TRD rear sway bar, HID 6K low beams & fog lights, Recon LED tailgate bar, Recon Auxiliary reverse lights, GoLight Stryker remote control spotlight, JL Audio sound system, Tekonsha brake controller, Line-X on front grill-front bumper-rear bumper-bed, Black Horse grille guard and taillight guards.
"The car is the closest thing we will ever create to something that is alive"
Ted is offline   Reply With Quote
Rumours about the E39 M5 pre 1998. Gustav F10 M5 Discussion 15 21st October 2009 00:11
List: Sultan of Brunei's complete car collection, no M5 but an Alpina Gustav GTBoard.com: General Sportscars 12 20th September 2007 19:14
Report from Geneva, a lot of pics (Updated 13th March with 911 GT3 & Turbo pics/info) Gustav E60 M5 and E61 M5 Touring Discussion 71 1st April 2006 03:36
Press Release no 2: The new V10 engine in the BMW M5: A masterpiece in engine cons... Gustav Most Memorable Threads' 31 4th July 2004 21:23
Press Release 1: World premiere of the new BMW M5 (summary of all press releases) Gustav Most Memorable Threads' 0 4th July 2004 21:13
