• Latest threads
    • Custom feed
      • Updates
        Old 1st September 2001, 20:10   #1 (permalink)
        MAH
        MAH's Avatar
        LED brake lights
        All,
        After much experimentation and testing, I have found true LED replacement bulbs that fit into the sockets for our M5's. They are a super bright red . They cost $48 for two, kind of expensive, but interesting none the less. they do look great. Posting pics will not do this upgrade justice.
        I am trying to retrofit one of the LED bulbs into the third brake light, but I am not done with that yet. I will probably have to sand a little off the top of the socket to make this one work.
        I am still testing the turn indicators. The problem that I am having there is that with the LED's installed, the turn indicators flash twice as fast as the regular bulbs. Any suggestions?
        If you are interested in a bulk purchase or you would like to order direct, let me know and I will make it happen. This manufactorer has the best LED replacements I have seen and I have looked at over 25 different LED solutions.
        The red LED's are a deeper red than stock. The turn indicators are a brighter yellow as well, but are more concentrated to a single point than the regular bulbs.
        Let me know if you have any interest. I am going to try and replace all of the incandecent bulbs on my car with LED's.
        Mark
        MAH is offline
        Old 1st September 2001, 20:53   #2 (permalink)
        BostonRocket
        BostonRocket's Avatar
        Send a message via ICQ to BostonRocket
        Mark,
        I would be very interested in changing the bulbs to LED.. Is there any way you could hook me up with the contact to at least first get the brake lights?? I am interested in the turn signals as well, but I think the blinking problem would have to be solved first! Thanks in advance!
        'Rocket
        BostonRocket is offline
        Old 1st September 2001, 21:13   #3 (permalink)
        raland9
        MAH, Which manufacturer? I've been trying to find LEDs for
        a while and have tried quite a few. The lights need to be clear
        and not red or amber and they need to have a provision for
        reflecting the light as opposed to directing it into a concentrated
        circle. LEDTRONICs is one of the manufacturers. Others, from which I have a few samples just don't have it right yet.
        Thanks.
        Rick
        raland9 is offline
        Old 1st September 2001, 21:36   #4 (permalink)
        Gustav
        Administrator
        Gustav's Avatar
        MAH, I tremember the LED Flashlight you had around President's House. Cool. If you find the brake lights will be that strong? Also, you'll only have two LED per brakelight?
        Say hi to your Mr Vette friend
        BMW M5 2003 with complete Supersprint exhaust system and StopTech brakes, delimited by Hartge.
        gtboard.com DVD II (NTSC) Best Price $25.00
        gtboard.com DVD II (PAL) Best Price $30.00
        Webmaster LinkedIn Facebook
        m5board.com Facebook Group
        At your service: comments, suggestions or feedback: gustav@bmwm5.com m5board Member visiting Stockholm, Sweden? PM me to and I'll show you Stockholm! gtboard.com
        Gustav is offline
        Old 1st September 2001, 22:45   #5 (permalink)
        atomic80
        M5 Extraordinare!
        atomic80's Avatar
        Mah,
        Could you hook me up too...I'd be interested in getting a set for my brake lights too. I already have the silvervisions in the turn signals so unless you know of a LED solution that's also "silver" then I'd be inclined to keep what I have in there except for the brake lights of course!
        jgtang@mindspring.com
        Thanks!
        Jason
        atomic80 is offline
        Old 1st September 2001, 23:40   #6 (permalink)
        MAH
        MAH's Avatar
        The scoop
        Thanks.
        Rick
        Rick,
        I thought the same thing, that the lights would have to be clear because that is what is in there now. I was wrong. The LED's are super red which makes the light a little bit darker, but it would be more pinkish if it were left white. I did try this so I am spealing from experience.
        LEDTRONICS is where I ordered from, but they have a distributor called Netdisty that is familiar with the problems that I had. You cannot buy in small quantities from LEDTRONICS.
        Netdisty's # is 310-326-5806. Check out www.LEDTRONICS.com for the specs on the lights. The specific number for the bulb is AUT1156-ER-014V.
        These LED's not only have LED's projecting rear ward, but on the sides as well for reflecting purposes.
        I hope this answers a few questions. We could still order in quantity if you would like. And just a reminder, these LED's do work, I have them on the car.
        One last thing, because LED's are white or clear when they are not on, you will not need silver turn signal bulbs anymore. That is until I find the right solution for the LED replacement for the turn indicators.
        Mark
        MAH is offline
        Old 1st September 2001, 23:53   #7 (permalink)
        MAH
        MAH's Avatar
        That was a bright LED flashlight
        Gustav,
        It was good to meet you and spend a little time in Monterey. Yes the LED bulbs are almost as bright as that flashlight. You can see the flashlight I am talking about on www.pszone.com. That is Popular Science Magazines website.
        You will actually need three LED's if you are going to replace the third brake light as well. It is amazing how much faster the LED's react than the regular bulbs. I still have the third brake light bulb in and it goes on a split second slower than the LED's down in the lower light housings.
        The Vette guys name was Gregg and he has a 2002 Z06 on order. I understand you had an interesting discussion with him while we were at the table for dinner that evening.
        Glade you had a good time in sunny California. You just won't be allowed to drive any more Porsche's in the states again LOL.
        Talk with you later,
        Mark
        MAH is offline
        Old 2nd September 2001, 00:05   #8 (permalink)
        atomic80
        M5 Extraordinare!
        atomic80's Avatar
        Mark,
        So we all need to get all three bulbs that are exactly the same to replace all three brake lights or does the third light use a different type of bulb?
        Thanks so much for the tips! I can't wait to try them out!
        Jason
        atomic80 is offline
        Old 2nd September 2001, 01:00   #9 (permalink)
        Dallas Spikes
        Dallas Spikes's Avatar
        please help explain
        I'm confused/ignorant on this issue. Could someone explain the benefits of LED lights. I guess I've never seen them before and so I don't know what they look like. I assume the benefit is cosmetic, but I can't picture what they would look like.
        Thanks in advance,
        Chris
        Dallas Spikes is offline
        Old 2nd September 2001, 03:24   #10 (permalink)
        raland9
        MAH --
        I found the same thing with LEDTRONICS. You
        found the distributor, which is better. Sounds
        like you found the right bulbs and I'd be interested
        in buying them (including the amber). You may
        be right about the clear shining through a little
        pinkish. The main problem with most of them
        is that they are in a concentrated circle and
        don't reflect properly. If the ones you found take
        care of this issue, you've probably got the right
        ones. LEDTRONICS can provide any of their
        lights through the dealer and most come in
        a variety of colors.
        Chris, among the advantages is that they
        consume not much more electricity than your
        electric clock. They are very bright and are
        either on or off. Normal bulbs turn on and
        off "gradually" whereas these are much quicker,
        for what that's worth.
        Rick
        raland9 is offline
        Old 2nd September 2001, 04:06   #11 (permalink)
        Gustav
        Administrator
        Gustav's Avatar
        Re: please help explain
        Have a look on the new S Class, CL or SL when braking, lights up faster and looks VERY cool Also, faster brakelights reduce the risk of people crashing into you from the back because they see it faster
        Thanks in advance,
        Chris
