Old 16th December 2006, 01:18   #1
BimmerHead
BimmerHead's Avatar
Garage: big blue weenie
Sales Feedback: (3)
Send a message via Yahoo to BimmerHead
Rear Differential Axle Seal Replacement DIY - Help
Hello,
For the past several months I have been keeping an eye on the rear diff axle seals (they are seeping). But, now I am starting to see fuild on the exhuast and gas tank.
So, the time to replace the seals has come. I called a few places around me and I'm getting quotes in the $500 range. I did a search on the board and saw that some members did this job themselves.
Since I can get access to a lift I am now thinking of doing this myself (the parts are cheap and so is my labor).
Can anyone provide a step by step instruction guide on how to replace the seals?
Thanks...
01 M5 LMBs/LMB SSR GT3 Wheels, TC Design Rear Sway Bar Brackets, Dinan Stage 3 Software, V1 Hardwired
BimmerHead is offline
Old 16th December 2006, 08:06   #2
KirklandM5
KirklandM5's Avatar
Garage: 2001 M5 Titanium Silver
Send a message via AIM to KirklandM5 Send a message via Yahoo to KirklandM5
http://www.bmwe34.net/e34main/mainte...tial_seals.asp
2001 E39 M5 Titanium Silver/Silverstone
1997 BMW M3 Gruppe N Race Car
2005 X5 4.4i
KirklandM5 is offline
Old 17th December 2006, 18:52   #3
dcaron9999
dcaron9999's Avatar
Garage: Carbon Black 2002 E39/M5
Did you get this done? How did everythig go? Are E34/E39 diffs identical? Where are the bolt Torque Specs? This is something I'll have to do if I purchase a 2002 M5 I'm seeking this week, because it has a leaking diff too.
dcaron9999 is offline
Old 17th December 2006, 20:21   #4
Lscman
Garage: E39
Old E34 is different....E39 L6 is different....E39 540i is different....E39 M5 is different.
The E39 halfshafts are not easy to remove. This may require you to remove the wheel bearing which is a real pain.
The closest relatives to E39 M5 differential are E38 7 series and E46 M3. The procedure may be in BMW TIS.
Resolve never, screw genuine.
Lscman is offline
Old 18th December 2006, 02:44   #5
BimmerHead
BimmerHead's Avatar
Sales Feedback: (3)
Not yet.. I'm still waiting for one more place to call me back with an estimate. If it's still high then off to my friends garage I go.
I'll post once I get it either fixed or do it myself.
BTW, signed up for BMWTIS and didn't find any instructions on how to do this job.
If anyone knows where they are on that site, please let me know and I'll pay for another 24hrs.
Old 18th December 2006, 03:05   #6
dcaron9999
dcaron9999's Avatar
These repair codes might help you ...
27120037 Output flange to rear axle differential (incl. rotary shaft seal) Loose
27120048 Output flange to rear axle differential (incl. rotary shaft seal) Leaking
271200XX Output flange to rear axle differential (incl. rotary shaft seal)
33110048 Rear final drive housing Leaking
33110148 Rear axle differential breather Leaking
Old 18th December 2006, 08:45   #7
KirklandM5
KirklandM5's Avatar
Procedure is pretty much the same, but you need an external torx socket for the E39 M5 (probably an E12) for the half shaft. Also, the TIS sez to loosen the rear section of exh...
other than that pretty much the same, and torque for the half shaft is 135nM
2005 X5 4.4i
rear axle (final drive) leakage M5touring reg E34 M5 Discussion 1 12th June 2003 02:13
Help - What is involved in rear window regulator replacement? Alaris E39 M5 and E52 Z8 Discussion 0 23rd May 2003 00:26
rear shock replacement mikek E34 M5 Discussion 0 18th August 2001 14:58
Replacement for rear shock Anu E34 M5 Discussion 1 24th April 2000 02:16
Page generated in 0.17222 seconds with 11 queries
