Old 30th August 2001, 22:09   #1
doug
doug's Avatar
Garage: 2003 Sterling Grey M5
Brake system upgrade to Brembo?
Has anybody ever done an upgrade to a Brembo braking system? They're a well respected name in high performance and racing brake systems, and they have a caliper and rotor kit for the E39 M5. I'd be interested in finding out how these performed WRT the stock system as well as what potential problems this could introduce (if any).
-Doug
--- from www.brembo.com ----
Front system with two-piece 355 X 32m cross-drilled vented discs with anti-corrosive cadmium plating. Mounts "floating" style to vehicle specific billet aluminum bell. Brembo engineered and machined two-piece cast aluminum caliper fitted with four sequentially sized aluminum pistons, dusts seals and anti-rattle clip. Also included, complete axel set of high performance pads and DOT/TÜ approved stainless steel brake lines. Aircraft quality mounting brackets and hardware complete this system. All our high performance brake systems are ABS compatible and retain the stock master cylinder.
Product Code: 1B18010A3
Price:USD 3295.00
Area: Racing Inspired
Destination: Front
Availability: Available
Bell Thickness: 8.5 mm
Caliper Overhang: 20.5 mm
Caliper Piston Size: 40x44 mm
Caliper Radial Clearance: 199 mm
Disc Size: 355x32 mm
doug is offline
Brembo brake upgrade! John B E39 M5 and E52 Z8 Discussion 9 29th March 2003 04:58
Nav Sw Ver 18 upgrade - FAQ 1C00lVC M5 E39 and E60 tips & tricks 0 12th March 2002 06:00
Brembo brake upgrade kit: I'm doing it! bobafett E39 M5 and E52 Z8 Discussion 80 8th February 2002 17:30
Page generated in 0.11124 seconds with 11 queries
