DICE ipod text display question - BMW M5 Forum and M6 Forums
Old 24th November 2006, 16:47   #1
BCelts
Garage: Black 2003 M5
I posted this is response to the thread on this topic, but wanted to post this here in hopes of getting advice quicker. If people are like me they may not check those threads...
I had my dice ipod adapter installed last week. At the install place it worked great - full text display and all. It still works great for sound, but somehow I messed up the full text display. I know that everything is connected right because it worked the first time. If someone could please give me a step by step on how to get full text display to work in an m5 with navigation (mine is a non-dsp with a mkIV head unit, 2003 car) I would really appreciate it. THank you in advance.
BCelts is offline   Reply With Quote
Old 24th November 2006, 19:00   #2
kalvin
kalvin's Avatar
Garage: 2000 m5 Blue
dude,
I am having the same problems. I am getting text on my odo, but not on my nav screen
1995 Chevy Astro Cargo White Everyday working van
2000 M5 Lemans Blue/Black-silver my new LOVE
Clutchmaster stage 3 clutch, Back up camera, 2-12" infinity with earthquake 1000 , CCFL angel eyes, Stern 18" chrome wheels, DVD player, z3m short shifter, projector fogs, deleted factory mufflers, 16x9 nav screen with mk3, Ipod dice, hardwired V1 with remote display, 3.45 LSD
2003 Suzuki GSXR-750 for the hot days
kalvin is offline   Reply With Quote
Old 25th November 2006, 01:49   #3
code7rpd
Garage: BMW 540i Anthracite
I had the same problem and found that if you push the 'pty' button (it's the first button below the number buttons on the left, it will turn the text mode on and off. If you depress button number one you can scroll through the songs and if you push number two you can scroll between playlists. Hope that helps.
code7rpd is offline   Reply With Quote
Old 25th November 2006, 08:17   #4
shadowman
shadowman's Avatar
Garage: Z8
Press #6...... then right arrow to scroll through the display options..... it will not say display options...simply tracks but as you do so the text is routed..... it may take a short time as the system reconfigures itself......
track 3 = display under the speedo
track 6 = Nav screen
I hope that this helps
Shadowman
shadowman is offline   Reply With Quote
Old 25th November 2006, 18:34   #5
BCelts
Shadowman
Again and again I am very glad to have found this helpful place. Thanks to all above who helped, I will try the fix shortly.
Old 26th November 2006, 14:15   #6
BCelts
Er, I don't have a pty button. At least I don't think I do. I will turn pty on and see if that helps. Thanks again.
Old 26th November 2006, 18:22   #7
kalvin
kalvin's Avatar
its still not working for me....
Old 27th November 2006, 02:00   #8
BCelts
Funny part is that it was working for me at the install shop. I'll try to go back there next weekend (er weekend following next) and see if they can help me out hten I will post. In the meantime, if anyone has other suggestions (assume I am an idiot when suggesting)...
Old 21st December 2006, 18:44   #9
daniellebimer
Banned
Garage: 1998 BMW M3 Blue
I know a guy over at www.mp3yourcar.com and if you find their number and call in tell them you got it from them you might be able to fiond out everything you need to know
daniellebimer is offline   Reply With Quote
Old 22nd December 2006, 18:35   #10
sjdennis
sjdennis's Avatar
Garage: 2000 M5 Avus Blue
I have the ice-link plus in my car for over a year now and lost the text shortly after install. I was given some software files to load on my ipod and run from the ipod that will set the text-to-nav or text-to-obc when you loose the connection. After a year I still loose the text from time-to-time and either have to toggle the "mode" button to get it back and in rare occasions run one of these files.
I don't know if the DICE version will work with these files. Perhaps you could contact Dension and find out.
Good luck! :p
sjdennis is online now   Reply With Quote
Computer display question KevinM E39 M5 and E52 Z8 Discussion 16 19th December 2009 07:52
Nav Display - Dimmer Question El_Mono E39 M5 and E52 Z8 Discussion 13 2nd March 2006 19:20
Questions regarding iPod installation wolfturbo E60 M5 and E61 M5 Touring Discussion 36 23rd January 2006 21:36
M5 & M6 Ipod question markf E60 M5 and E61 M5 Touring Discussion 12 14th March 2005 20:29
