Old 20th November 2006, 01:39   #1
FAST 5
FAST 5's Avatar
Advice on dash message area pixels starting to go?
I've heard of this, and even seen this being posted on the board but without doing the tedious search method, here's my situation at hand, car is a 2003 model, has 12, 800 miles on the clock. Just got the car back from Dinan located in CA, from the S3 conversion project, so it's blatantly obvious that the car is no longer in it's stock form. This is an electrical or electronic issue/problem. BMWNA shouldn't DICK with me over this problem, right??? It has nothing to do with Dinan's work or attached parts. For those who had this pixel problem what was your car's maileage when you started losing the readability of the center info screen on the dash board which can display; mileage info, date, fuel consumtion, avg. miles per hr, miles to empty range, timer , etc..........
What did the BMW techs do to resolve this issue? What's the procedure to attacking this problem? Will they take apart the dash to access the info screen, and replace it with a new improved part ???
All replies are appreciated. thank you.
Rob
FAST 5 is offline
Old 20th November 2006, 01:48   #2
KBK
KBK's Avatar
Garage: E39/Anthracite Metallic
Mine comes and goes. It hasn't given me grief in nearly a year, now.
They can be repaired.
It's only irritating as it's there, in your face, every day. If it was an intermittent passenger door ground light, you wouldn't even post.
KBK is offline
Old 20th November 2006, 01:54   #3
Nabio
Nabio's Avatar
Garage: Jet Black E39 M5
Send a message via AIM to Nabio Send a message via Skype™ to Nabio
I thought the reason you pay all that extra money for Dinan parts is that it won't void warranties and such with BMW. They shouldn't give you a problem then, right?
Jet Black 2000 M5
Nabio is offline
Old 20th November 2006, 01:56   #4
phillym5
Garage: 01 Area 51 M5 Le mans.
Well.... even though I don't believe this car exist.....lack of photo's and all.....
You should be able to get it replaced under warranty..... I doubt that the Dinan mods have anything to do with the pixels going out.
And yeah.... some of us are still waiting to see those pictures.....
phillym5 is offline
Old 20th November 2006, 02:08   #5
EM5PWR
EM5PWR's Avatar
Garage: 02 M5
Yeah what he said !!
EM5PWR is offline
Old 20th November 2006, 02:22   #6
ard
ard's Avatar
Man, Robert... this is a brutal crowd, eh?
Provided the 4 yr warranty isn't up, this is a clear warranty claim- should be no issues. It is related to AGE not miles, BTW
A
ard is offline
Old 20th November 2006, 02:23   #7
SC'dKellenersM5
SC'dKellenersM5's Avatar
Garage: Red White and Blue
Blame dinan...
Im in the highspeed aluminum business
SC'dKellenersM5 is offline
Old 20th November 2006, 03:06   #8
jclyman
jclyman's Avatar
My car was very near the end of the warranty when my problem appeared ... at first it was intermittant (multiple columns coming and going), now one column seems to be gone forever, and I am into my extended warranty (which I didn't have at the time it first failed ... took a pick with my cell phone to document the failure and mileage).
I had posted the info here, and received a contact from BMW NA ... and, they said it would be fixed ...
The dealer replaces the entire cluster and reprogramms the mileage numbers to match the old mileage. If you have black dial faces they will be grey. However, I am not sure they fix the cause of the problem and I am considering having it fixed locally by someone who will fix the cause of the problem, even if it costs money ... could be $ 300.00.
- Daniel Boorstin
jclyman is offline
Old 20th November 2006, 03:29   #9
mr_bock
mr_bock's Avatar
Garage: 2002 M5, Sterling Gray
Robert,
If your car is under warranty, BMW should replace the screen, no problem. I had mine replaced last summer for missing pixels at no cost.
How does your car run now?????
Good Luck!!!
George B.
2002 Sterling Gray, Black and Aluminum interior
UUC Short Shifter & DSSR
UUC Clutch Stop
UUC Transmission Supports
UUC UltraSmooth CeraMetallic Clutch/LWF
Active Autowerks Cold Ram Air Intake - Modified
Air Plenum Heat Shield, 1700 degree black Jet-Hot coating
Alpine amp for JL Audio Sub Woofers
UFMotorsport S62 Intake Air Temp Sensor Relocation
Dinan Stage II Suspension
Dinan 3.45 Rear Diff. Gear Set
Dual JL Audio 10" Sub Woofers
K40/Laser Defuserplus, hidden install
K-Mac Adjustable Caster/Camber Plates
Kelleners Aluminum Sport Pedals & Foot Rest
MB Quart speaker replacement
NAV MKIV DVD
StopTech SS Brakelines
Axxis Ultimate Brake Pads
EvoSport Performance Underdrive Pulley Set
TubiStyle Cat-Back Exhaust
Power Chip 93 Gold - Modified & Sport 'On'
Perma-Cool Electric Engine Fan (no mechanical fan!)
Michelin Pilot Sport II Tires (front/rear stock sizes)
Royal Purple Synchromax Transmission Oil
Red Line 75W90 Differential Gear Oil
Sirius Radio receiver
SS Headers, EVO High Flow CATS
Zionsville Aluminum Radiator w/ Dual Speed Fan
My latest toy... a 2001 360 Modena Ferrari
My 'other' car is a supercharged 1996 911 C2 993
mr_bock is offline
Old 20th November 2006, 04:06   #10
Vossen10
Vossen10's Avatar
Garage: M5
My dealer definitely knows I have Dinan on my car and I had some pixel problems. They replaced the cluster under warranty no questions asked.
Dinan M5
335i Coupe
Vossen10 is offline
Dash Message "Check Side Lights" after installing LED Markers KingM5 E39 M5 and E52 Z8 Discussion 32 12th March 2007 02:44
Dash board Message ?? SeeSure E39 M5 and E52 Z8 Discussion 17 11th June 2006 20:20
Advice on DSC error message? sulaiman E60 M5 and E61 M5 Touring Discussion 2 17th March 2006 06:14
HELP !!"CHECK CONTROL" error message on my dash. PPHILPOT ALPINABoard.com | BMW Alpina Discussion 5 14th December 2001 01:23
Page generated in 0.16029 seconds with 11 queries
