i never had an ses light with the x pipe, at least not consistantly. I had a couple of 'cat efficiency' codes here and there, possibly related. I ran the x pipe for a couple of years with no real issues.
The x pipe will speed up the flow of exhaust gasses thru the cats, so if the cats are marginal, you may get a cat efficiency code. As jon above mentioned there is software to reduce the sensitivity of the post cat o2 sensors which eliminates this issue if it were to come up.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
