Old 17th November 2006, 07:36   #1
em5464
em5464's Avatar
Garage: BMW M5, Silver
SES light....System too lean...any suggestions ?
This is really strange that I get these codes now, after replacing the spark plugs just 2 days ago, OEM NGK. The old plugs were in bad shape (no oil deposits though) after only 26k miles.
The codes are:
OBDII codes P0171 and P0174 - System Too Lean, bank 1 and bank 2
I've pretty much gone down the checklist.
Checked the MAFS, they're in good shape.....150 at WOT in 2nd gear.
O2 sensors only have 30k miles. cats are OEM.
The last DYNO A/F ratio was about 13.
I've just reset the codes and will see if they pop up again.
Any idea what those codes might be associated with or cause them ? thanks in advance.
Ed
00 M5/Silver/Black
DINAN CAI
DINAN high flow mass meters,
DINAN Stage 3 software
DINAN 17mm adjustable rear sway-bar
DINAN strut tower brace
DINAN 3.45 diff
HAMANN DTM exhaust w/ Supersprint X-pipe
Brembo 14" BBK/355 mm/front w/ Porterfield RS4
UUC Ultimate V12 Flywheel and Clutch Kit
UUC EVO3 w/ DSSR
IATS kit
GC Coilover kit 430/380
19's RH w/ Potenza RA050
Angel eyes by HELLA, w/ clear front & rear lights
ALPINE IVA D900 Multimedia System
em5464 is offline
Old 18th November 2006, 01:54   #2
aaronmiles
aaronmiles's Avatar
Garage: 1999 Imola Red M5
Send a message via MSN to aaronmiles
PM boardmember DavidS. He is good on things like that .. he helped me out.
What are your long term fuel trims like?
1999 Imola Red M5. Extended Caramel Interior
Mods on my pre-update beast:Eisenmann "Race" exhaust (76mm tips), 19" Hamann PG2's, AACAI, Clear Angel Eyes, MK4 Nav, GC's M5 Coilover kit w/front camber plates, Dinan Front and rear sway bars, D/A swaybar mounts, Dinan front and rear strut brace, Braided brake lines, Eibach 3mm wheel spacers, Rogue Engineering underdrive pulleys, IATS Relocation, Powerchip, Xenon foglights & Lower engine covers w/Brake duct cutout
2008 Volkswagen Golf GTI. The wifes new car
2005 Ford Territory Ghia. The wifes car. (Sold)
1986 Toyota Landcruiser HJ75. The farm ute.
aaronmiles is offline
Old 18th November 2006, 02:13   #3
omes
omes's Avatar
Garage: 2008 997.1 C4S
Sales Feedback: (4)
Just a thought but have atmospheric or weather conditions changed much in the LA area recently. Sometimes the car may need a bit of adaptation time if the air is cooler and more dense which would trigger the code, when you clear it does it come back? or is this just random?
omes is offline
Old 18th November 2006, 02:55   #4
mishkinm5
mishkinm5's Avatar
Garage: 2007 M6 Alpine White
Sales Feedback: (15)
probably o2 sensors or mafs need replacement
2007 BMW M6
2003 M3 Cp SMG For Sale!
mishkinm5 is offline
Old 18th November 2006, 08:28   #5
em5464
em5464's Avatar
Interesting theory there about the climate.....
I'd have to say that the weather it's been really changing lately, from day to night there is a difference of almost 40 degrees....Nights are down in the 40's and daytime is 80's...So, this might be a factor.
I've just reset the code about 2 days ago and so far no SES light.....hopefully it'll stay that way....thanks for the info
Ed
00 M5/Silver/Black
DINAN CAI
DINAN 3.45 diff
UUC EVO3 w/ DSSR
IATS kit
em5464 is offline
Old 18th November 2006, 08:31   #6
em5464
em5464's Avatar
The LTFT was at approx 4.6% and the STFTwas around 3 % or so....I'll try to email DavidS....thanks
Ed
00 M5/Silver/Black
DINAN CAI
DINAN 3.45 diff
UUC EVO3 w/ DSSR
IATS kit
em5464 is offline
Old 18th November 2006, 14:43   #7
aaronmiles
aaronmiles's Avatar
m a LTFT of 4.6% is probably a touch high but would not throw codes like that I would not think. I had mine at 11 and 12% and it threw those codes. Replaced MAF, O2, spark plugs and air filters and it dropped to about 1-2%
Old 18th November 2006, 15:11   #8
wiggis
wiggis's Avatar
Garage: Le Mans Blue
Air leaking into the plenum chamber? Fuel grade? You have lots of Dinan stuff on your car, so it may be more sensitive to fuel grade than a normal M5. Did you change brand recently? Or it could be that the new plugs are burning the fuel more completely, reducing the O2 levels in the exhaust gases, making the car think it's running lean.
My guess is that if you didn't change fuel grade or brand recently, that the car DME just needs to adjust to the new conditions.
wiggis is offline
SES Light, on and off recently matt310 E39 M5 and E52 Z8 Discussion 12 14th May 2005 05:30
SES light Z8 Dave E39 M5 and E52 Z8 Discussion 1 7th November 2004 11:22
SES exhaust light fix Keith97M3turbo E39 M5 and E52 Z8 Discussion 0 13th September 2004 03:35
Nav Sw Ver 18 upgrade - FAQ 1C00lVC M5 E39 and E60 tips & tricks 0 12th March 2002 06:00
OT - Nissan's lane keeping system. The high tech march continues... blue max E39 M5 and E52 Z8 Discussion 8 9th December 2001 20:58
Page generated in 0.13043 seconds with 11 queries
