I had a SES light tonight so I pulled out the Peake reader to see what was up.
I pulled it in and looked for the Fc light and then checked for the codes. I got code 18 and code 69.
I opened up the book and went to page 12 and started looking for the two codes. I quickly realized that there are eleven different tables in the book. I also realized there are multiple code descriptions for these two different codes under different tables.
I then went back to reading the instruction to see what table I was suppose to choose from. On page six of the book it states that "the first number is not a code" The first number shown is the code table to use. It also states that if the tool does NOT display "FF" then use code table on page twelve (1996 and later).
So using the first code I read "18" I would look for table number 1 correct? Well there is no table number 1? There is a table 1b. As you can see this isn't makeing sense?
Looking at the second code that got from the reader "69" I then goto table 6 and then look for code number 9. There is no code number 9 listed in this section.
My first instynct was to simply take the code and look it up and not seperated the numbers. If I do that I find multiple code definations:
18 - Table 00 - "Ignition Coil, Cyl #4"
18 - Table 0F - "Mixture Control, higher load, Cyl #1-4"
18 - Table 1b - "Ignition Coil, Cyl #3"
18 - Table 06 - "A/C Compressor"
18 - Table 07 - "A/C Compressor"
18 - Table 09 - "A/C Compressor"
18 - Table 11 - "Fuel Injector, Cyl #4"
18 - Table 15 - "Fuel Injector, Cyl #4"
18 - Table 18 - "Ignition Coil, Cyl #3"
18 - Table 19 - "Fuel Injector, Cyl #4"
69 - Table 0b - "DME, EEPROM failure"
69 - Table 0F - "Control unit self-test, ROM faulty"
69 - Table 15 - "VANOS, intake mechanically stuck"
69 - Table 18 - "Engine coolant temperature, Plausibility"
69 - Table 19 - "Intake camshaft VANOS, over-******ed"
Now I hope that I didn't type all that for nothing
So a little help would be appreciated.
