Old 17th November 2006, 05:23   #1
madyspop
Garage: 01 Imola red M5
Send a message via AIM to madyspop Send a message via Yahoo to madyspop
Different clutch pedal feel between M5's?
I have the 11" UUC units with the performance organic discs. I would think they should feel the same but they are complete opposites. My 01 has about 8K miles of use on it and my 02 S2 has about 4K miles of use.
The clutch pedal in the 01 is much stiffer then stock and the pedal in the S2 feels like stock or even lighter, anyone know why this is?
02 M5 Sterling Grey/silverstone sport interior w/titanium trim
[font="Comic Sans MS"]Full blown Dinan S2 package, Dinan wheels w/ 275-[font="Comic Sans MS"]35-18 on all four corners, Dinan by Brembo 4 wheel big brake kit with Euro brake ducts, Lidatek laser diffuser and V1 w/hidden display, TV on Nav, DVD player, and XM satelite radio, 3M tinted windows and clear bra, color matched bumper, side moldings and grill, Euro headlights with 6000K ultinon bulbs, UUC 11" clutch and lightweight Flywheel, DSSR, EVO 3 short shifter, black tranny mounts, [font="Comic Sans MS"]AcShnitzer aluminum pedals
madyspop is offline
Old 17th November 2006, 05:25   #2
KBK
KBK's Avatar
Garage: E39/Anthracite Metallic
Lucky barsteward.
If I buy an extra clutch and put it in the trunk, I will have two different clutches too. They will even feel (act)
different.
Somehow, I don't think it will feel the same.
KBK is offline
Old 17th November 2006, 05:54   #3
Beamer_usa
Beamer_usa's Avatar
Garage: explosive ford pinto
Not all S62 motors put out exactly the hame hp's, some are stronger than others. I would hazard a guess that not all UUC clutches are exactly the same
Dinan Cans
Dinan Software
Beamer_usa is offline
Old 17th November 2006, 06:06   #4
E55AMG2
E55AMG2's Avatar
Its to do with a number of things, the major ones are;
1) breakin procedure for each unit
2) whether the clutch/brakes hav been bled properly
3) whether or not the installer swapped the slave unit, or simply swapped the new pin into the old unit.
E55AMG2 is offline
Old 17th November 2006, 07:36   #5
Need4Spd
Need4Spd's Avatar
The UUC 11" kits use a different slave unit that reduces pedal effort back to stock. Maybe the stiff one didn't get that installed?
BTW, are you otherwise happy with the UUC? Rollover noise any problem? Did you have the idle rpm bumped up?
Need4Spd
Need4Spd is offline
Old 17th November 2006, 09:39   #6
madyspop
I am very happy with the clutch, it grabs like hell with no problems. It does have some rollover noise but nothing major and definately worth it for the peace of mind it gives me. I did get the powerchip software and had the idle raised, but my S2 has the Dinan software so I'm not sure if they do anything to accomodate the rollover. Both cars sound the same in regards to rollover even though I am running different software.
madyspop is offline
Old 17th November 2006, 18:49   #7
E55AMG2
E55AMG2's Avatar
Rollover = gear lash, nothing harmful about it really. It's more to do with how much the owner cares about having a silent car at idle (when the car is hot). It sounds like they swapped the pin (the UUC/E31 pin is longer to accomodate the new clutch/pressure plate travel) from your UUC slave to your stock slave on one car, and used the entire E31 unit on your other car.
E55AMG2 is offline
Old 17th November 2006, 19:04   #8
wilsodh
wilsodh's Avatar
I have the UUC stage 3 6-puck/ lightweight flywheel, and I haven't noticed any rollover noise (standard idle speed). Maybe it is obscured by the exhaust note (SS/Magnum)?
Dave
'00 Royal Red/black/walnut M5
'El Diablo'
’00 Black/black DA s/c M5
Carrillo rods, Arias pistons,
Schrick cams, Vortech T-trim,
Supersprint headers/exhaust,
wilsodh is offline
Old 17th November 2006, 19:10   #9
E55AMG2
E55AMG2's Avatar
Dave
it only makes itself heard when the car is hot. Example, you have been slogging in rushour traffic for 30 minutes in 100 degree heat.
E55AMG2 is offline
Old 18th November 2006, 04:52   #10
wilsodh
wilsodh's Avatar
Madyspop's M5's
Ok, here we are...
I only posted the M5's. Nice looking stable Ceasar!
Dave
'El Diablo'
wilsodh is offline
Spongy Clutch Pedal & Dealer's Findings matt310 E39 M5 and E52 Z8 Discussion 10 6th May 2005 05:08
Stage 3 (6-puck ceramic) clutch 1st impressions 1badm5 E39 M5 and E52 Z8 Discussion 11 2nd November 2004 22:00
An in-depth SMG II review (LONG) kenneth E39 M5 and E52 Z8 Discussion 17 10th March 2004 01:31
Spongy brake pedal feel madmax E39 M5 and E52 Z8 Discussion 18 29th January 2004 00:31
Page generated in 0.15505 seconds with 12 queries
