Old 16th November 2006, 19:50   #1
labenzm5
Garage: 2001 m5 Lemans Blue
Blinker bulb..driving me crazy
My right front blinker went out.. so I thought. I pulled the bulb out and it looked fine. I pluged it back in and it worked for a few days. It went out again, I checked the bulb..it looked good. I pluged it back in, it worked for a couple of days then out again. I am getting irritated, what should I do?
thanks for the help!
labenzm5 is offline
Old 16th November 2006, 19:52   #2
Stevie
Stevie's Avatar
Garage: e34 540i, Orientblau
clean the contacts and replace the bulb!
Stevie is offline
Old 16th November 2006, 19:54   #3
labenzm5
thanks, what type of cleaner can I use?
labenzm5 is offline
Old 16th November 2006, 20:13   #4
volcan96
Garage: 2001 Anthracite Gray M5
Send a message via Yahoo to volcan96
I have had the same problem on my left blinker; every 6 months or so the bulb seems to burn out. Simply taking it out and reinstalling fixes it temporarily.
I've found that lightly cleaning the contacts on the bulb with med grit sandpaper helps a bit. I cleaned it with a rag soaked in a bit of carb cleaner (gumout). I also used electrical grease on the contacts, but don't think that made a difference.
volcan96 is offline
Old 16th November 2006, 20:39   #5
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Change the bulb socket, the early ones tended to corrode. That should solve the problem.
gsfent is offline
Old 16th November 2006, 22:48   #6
1mpowerme
1mpowerme's Avatar
Garage: 2000 Carbon Black M5
Sales Feedback: (7)
When your bulb goes out intermittently does the turn signal then blink fast?
I had this same problem occur for the first time about one month ago and I too thought I fixed the problem by removing the bulb and tightening the connection.
2000 BMW M5
Carbon Black
Black/Aluminum Trim
- Bilstein PSS9 Suspention
- Dinan F&R Tower Struts
- Navigation Upgrade to MKIV Computer and 16:9 Widescreen
- Headlight Upgrade to Hella Headlights w/Angel Eyes and 6000K HIDs
- Fog Light Upgrade with 6000K HIDs
- Tail Light Upgrade with Hella Celis Tail Lights
- BBS RGR Diamondblack Wheels
- Tubi Exhaust
- UUC Short Shifter
- Black Kidney Grills
- Carbon Fiber Roundels on Wheels, Hood and Trunk
1mpowerme is offline
Old 16th November 2006, 22:52   #7
GT35065
GT35065's Avatar
Garage: 02 M5 Jet Black/Carmel
I have the exact same problem with my left front blinker. It just quit working again today. If I wiggle it, it works for about two weeks. I have large hands, and I've had trouble trying to pull the bulb. Is there an easy way?
Mine blinks fast when it quits working.
Rick
Rick
2005 Ford GT Red
2002 M5 Jetblack/Carmel
2005 Mini Cooper S
1965 GT350 Supercharged White/Blue clone
1965 Superformance AC Cobra
1986 Must Convt GT supercharged
2002 BMW K1200 RS
2007 Yamaha FZ1
GT35065 is offline
Old 16th November 2006, 23:02   #8
labenzm5
I have the same issue, my meat hooks make it hard for me to get the bulb/socket back in and out. I used an open ended wrench to twist the socket on and off.
labenzm5 is offline
Old 16th November 2006, 23:46   #9
badboypolar
badboypolar's Avatar
Garage: '02 M5 Carbon Schwarz Metallic
Send a message via AIM to badboypolar
You need blinker fluid.
Make sure you buy Euro spec blubs. I know that if you put regular blubs (12v) they will work but have problems. BMW's use 21v blubs so make sure you buy the correct set.
You can't not be home before you haven't left.
2002 M5
M5Board.com Stickers Now Available
Crackberry E39 M5 Theme Ver 1.0
badboypolar is offline
Old 19th April 2008, 23:51   #10
M5CCIE
M5CCIE's Avatar
Garage: 2003 M5 Sterling Gray
Sales Feedback: (5)
Have the same issue all of a sudden. Has anyone been successful fixing this yet?
Dinan 3.45 differential
TMS Shark Injector - 91 Octane tune
IATS Relocation - Inside Air box
Strong Strut front brace
TC Design rear swaybar brackets
Bluetooth
V1
Aux port
M5CCIE is offline
Travel report E34 ///M5 meeting in the Alps 1-4 Sept 2006 raymondw Regional Forums and Events and group meetings for M5, M6 and Alpina owners 9 14th August 2007 14:05
How many M5 owners to change a light bulb? Aussie2U Off Topic Forum 35 17th June 2005 01:04
An in-depth SMG II review (LONG) kenneth E39 M5 and E52 Z8 Discussion 17 10th March 2004 01:31
E34 M5 owners weekend (5 till 8 September 2003) raymondw Regional Forums and Events and group meetings for M5, M6 and Alpina owners 5 28th September 2003 09:32
This board is driving me crazy ! Vince5 E39 M5 and E52 Z8 Discussion 10 3rd July 2002 09:16
Page generated in 0.16113 seconds with 11 queries
