Old 16th November 2006, 09:11   #1
MfiveLeo
MfiveLeo's Avatar
Garage: 00 ///M5, Black
Check engine light, car studders
The check engine light came on a few weeks back, the mechanic ran the code and said one of the cats is going bad. So he turned off the light, car kept running fine.
Now on my way home from the meet tonight, the light came on again. But this time at low rpm's it would studder.
Anyone have this problem before? Could it just be the cats going bad? Hopefully, atleast it will be an excuse for a full exhaust
MfiveLeo is offline
Old 16th November 2006, 11:15   #2
bayerischemotor
bayerischemotor's Avatar
Garage: M5 E39, Carbon Black
Sounds somewhat similar to my problem.
VANOS solenoids.
#1 BMW M5 E39
#2 BMW 530D E39
#3 BMW 735 E65
www.albatros.fi
bayerischemotor is offline
Old 16th November 2006, 15:28   #3
verhagke
verhagke's Avatar
Garage: 2000 BMW M5 (Titanium Silver)
I think its something other than cats since you describe that the engine is running poorly at idle. If you are getting a cat inefficiency code, all this means is that the post cat oxygen sensors are finding some unburnt fuel. It will assume that the problem is the cats, but it could be something upstream which is causing the mixture to be too rich. It is possible that the cats got plugged up, but this would typically result in significant loss of power above idle. Idle would be fine.
A couple of things to check out (other than the obvious rescanning the codes which are stored):
-- MAFs
-- Oxygen sensors
However, if they want to change your cats under warranty (either standard factory warranty or federal emmissions warranty) I'd say let them at it.
verhagke is offline
Old 16th November 2006, 18:49   #4
MfiveLeo
MfiveLeo's Avatar
Thanks guys, since I am not the original owner of the car, but it is still under 100k miles. The cats should still be covered by warranty right?
If it were to be VANOS silinoids, what exactly is that and what does the repair cost look like?
MfiveLeo is offline
Old 16th November 2006, 18:51   #5
mishkinm5
mishkinm5's Avatar
Garage: 2007 M6 Alpine White
Sales Feedback: (15)
I would look into cam position sensors that is a typical problem with the m5's.
2007 BMW M6
2003 M3 Cp SMG For Sale!
mishkinm5 is offline
Old 16th November 2006, 18:54   #6
wilsodh
wilsodh's Avatar
Iirc, cats are covered under the federal emissions warranty to 80k miles.
I wouldn't be thinking vanos repair yet. More likely MAFs or cps. You need to get a Peake reader.. it will help lift the veil of uncertainty. Pull the codes and post them on this board.. you'll be glad you did.
Dave
'00 Royal Red/black/walnut M5
'El Diablo'
’00 Black/black DA s/c M5
Carrillo rods, Arias pistons,
Schrick cams, Vortech T-trim,
Supersprint headers/exhaust,
wilsodh is offline
Old 16th November 2006, 18:58   #7
MfiveLeo
MfiveLeo's Avatar
Dave
Well my beast just went over 91k miles
Well hopefully its not vanos, I will see if I can get ahold of a peake reader or any kind of scanner that will fit my car. I'll let you guys know what we come up with.
MfiveLeo is offline
Vanos issues (long rant) mokushiroku E39 M5 and E52 Z8 Discussion 110 3rd February 2010 22:33
BMW M6 Press Release no 5: Body, Design, Equipment: Light and Safe, Sporting and... Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 9 15th December 2004 22:25
Alpina/BMWM5.com meeting at Nurburgring Oldtimer Grand Prix 2003 kees ALPINABoard.com | BMW Alpina Discussion 15 20th September 2003 02:46
My visit to the Old Timer Grand Prix on the 10th of August raymondw Regional Forums and Events and group meetings for M5, M6 and Alpina owners 2 26th August 2003 01:05
Problems to look out for when buying M5's BarryP E34 M5 Discussion 29 17th September 2002 18:52
Page generated in 0.15590 seconds with 11 queries
