Old 7th November 2006, 06:18   #1
M5CCIE
M5CCIE's Avatar
Garage: 2003 M5 Sterling Gray
Sales Feedback: (5)
Car ramps that won't slip
Hello,
I recently bought a pair of plastic car ramps from Pep Boys. I was unsuccesful getting the car on them because the front wheels kept pushing the ramps backwards. I have a concrete garage floor. I tried putting a rug underneeth the ramps with no luck.
Any suggestions of what works for you would be appreciated.
Thanks,
Jim
Dinan 3.45 differential
TMS Shark Injector - 91 Octane tune
IATS Relocation - Inside Air box
Strong Strut front brace
TC Design rear swaybar brackets
Bluetooth
V1
Aux port
M5CCIE is offline
Old 7th November 2006, 06:22   #2
Laidback
Garage: Camaro lol:)
Sales Feedback: (25)
try a sand paper on the back of the ramps...
"Illegitimus non carborundum"
Laidback is offline
Old 7th November 2006, 07:03   #3
jeeperjohn
Garage: 2002 BMW M5 Titanium Silver
Ramp
Jim,
I had to put a one foot long 2" thick x 12" wide piece of wood in front of the tire before the ramp to to get the tires a head start up the ramp. This kept the front spoiler from pushing the ramps. Check to see if your spoiler hits the ramps before the tires do.
John
2002 M5 titanium silver
19701/2 Chevrolet Camaro SS396/375 HP
1973 Chevrolet Z-28
1986 Jeep CJ-7
1960 Willys CJ-5
1946 Willys CJ-2A
jeeperjohn is offline
Old 7th November 2006, 08:19   #4
Need4Spd
Need4Spd's Avatar
If your garage has an inclined driveway (sloping DOWN from the garage), you might try this. Back the car into the garage, then place the ramps on the inclined driveway. Drive onto the ramps. This gives you more clearance, and driveways are usually less slippery than the garage floor. Also, because the driveway is inclined and drops away from the elevated car on the ramps, you gain a few more inches of work room, too. Someone on the M3 Forum told me this. I haven't tried it yet myself but it makes sense.
Need4Spd
Need4Spd is offline
Old 7th November 2006, 09:18   #5
M5Pageco
M5Pageco's Avatar
Garage: 2000 M5 - LeMans Blue
Bought the same ones and had the same problem. Here is what I did:
Go to Home Depot/Lowes type stores and buy a large rubber mat, like the ones you see at the enterance to stores (I think it's 4' x 6'). You can place the ramps on there and they will not slip AND you have a water/oil/liquid proof mat that will catch any spills and make sure your garage stays clean! Works great!
M5Pageco is offline
Old 7th November 2006, 10:38   #6
SehrSchnell
SehrSchnell's Avatar
Garage: 2002 IMOLA M5
Ha ha! Same problem here.
Man, one would think they could design these a little better.
The combination of wood planks on the bottom of the ramp and GRIP tape taped on the bottom of the ramps worked for me. But before that, it looked like a BMW rockcrawling event in my garage!
SehrSchnell is offline
Old 7th November 2006, 14:10   #7
Habu
Garage: E39 M5 TiAg
Sales Feedback: (3)
I have the same problem and someone suggested the rubber mat as well. I think I'll try it.
Habu is offline
Old 7th November 2006, 15:01   #8
Ocean's M5
Ocean's M5's Avatar
Garage: 2002 M5
I have the same ramps and i Lagged right into the Garage floor.
I measured so that when the front tires are on the ramp, the rear clears the garage door by 6". so, if you want to close the door with car on ramps you can, as well as not giving up much space.
I used a 1/2" cement drill and corresponding lagg bolt and secured the ramps. I have 13mm bolts that i use to tighten and loosen.
It's a astetically clean when ramps are not used, and still allows me to spray off garage floor...
2002-05 Build Carbon Black ///M5
First Aid Kit ~ Warning Triangle ~ Full BMW Tool Kit
Rear Cupholders ~ Stubby Air Stems ~ Rear Shades ~ PDC
M Audio ~ Fold-Down Rears ~ Black Sport Int.~ Yokohama Advan Sport~
Beast Power Sway Brackets ~ Tinting-80% Strip Windshield
Center Armrest *Storage Bin ~ ///M Black Trunk Mat
Ocean's M5 is offline
Old 7th November 2006, 15:11   #9
M5inGA
M5inGA's Avatar
Garage: '01 M5 in Carbon Black
Same problem! I thought that it was b/c my garage floor is epoxy sealed. I moved them out to the driveway where the concrete is 'rougher' and they worked fine.
Thanks for the advice, definitely better to work in the garage!
'01 Carbon Black
Black extended leather w/Aluminum
Fold down rear seat
PDC
Shades
STOCK (for the moment)
02 SWB Ford F-350 crew cab Lariat 4X4
3" lift
Edge Juice w/Attitude programmable chip
'02 Infiniti I35
'00 Lexus LX470
M5inGA is offline
Old 7th November 2006, 15:24   #10
beastunleashed
beastunleashed's Avatar
Garage: 2001 Titanium Silver M5
Here's a review on Race Ramps that might be of use:
http://features.evolutionm.net/article/projectevo/74
beastunleashed is offline
Vanos issues (long rant) mokushiroku E39 M5 and E52 Z8 Discussion 77 Today 22:30
Opinions on Full Leather? drewzMMM E60 M5 and E61 M5 Touring Discussion 54 13th March 2006 01:22
Guess the World's most outrageous car ever Black M5 E39 M5 and E52 Z8 Discussion 43 19th February 2005 17:19
Page generated in 0.25973 seconds with 12 queries
