Originally posted by Jeff L:
You can still swap your gear ratios by changing the ring and pinion set, but BMW no longer sells these seperately. You have to buy a whole new differential. I am not sure of the details. A good option may be a Quaife differential. Check with them or a good performance tuner.The cost will be two to three thousand dollars.
If you intend to alter the drivetrain, don't bother going with a BMW setup, go with the above mentioned Quaife diff, as I have heard nothing but praise for their products.
