DIY Spark Plugs, as requested. (Pics inside) - The Unofficial BMW M5 Messageboard (m5board.com)
Old 3rd November 2006, 17:24   #1
rdm190
rdm190's Avatar
Garage: 2001 Carbon Black
A few people asked for a small write up, so here it is! The job itself is not very hard, just takes a little time and some small hands. I am not responsible for any damage you do to you engine or yourself. This is a high voltage system, use common sense and disconnect your battery.
Tools:
3/8'' Rachet
LONG 3/8'' Extension
3/8'' Wobble joint
10mm Socket
Spark Plug socket
Torque Wrench
Flat head screw driver
New plugs, NGK or Bosch are the BMW choice from the manual
Lots of light
Gloves
Liquid refreshment
A girlfriend/wife with small hands (If you have giant monster hands like me)
I started with the passenger side first. In order to access everything the cabin filter and its plumbing need to be removed. Zee Germans did a very nice job of making this unit easy to remove. At the center of the filter tray there is a small metal clip that holds the entire unit to the strut tower. Pull this clip out and set aside. Now lift the long, thin black bar that holds the filter lid on. Remove the lid and filter and set aside. Now to disconnect the plumbing into the firewall. On the filter box end, there are 3 tabs on the connector that need to be lifted (I choose a small screw driver but your fingers will do) The filter box and plumbing should now be separated. To remove the tube from the firewall rotate the entire tube clockwise, then it will pull straight out. To remove the filter box lift it from the right side. the box has a tab that sits in the fender and will pull right out when the right side in angled upwards.
You should have an area like this when finished
Parts that were removed look like this
There are two 10mm nuts on the surface of the access cover that need to be removed. Take care are not to drop the nuts or their washers into the engine bay! Once these bolts are removed the cover can be lifted (with a little force) and then maneuvered out of the engine bay. Be gentle and just wiggle the cover out, it will come, it may take some different angles.
You should see this
Now for the Bremi's (coils). I found it best (after trying many different ways) to remove all connectors first. To remove the electrical connector from the bremi takes the following: There is a large metal retaining clip that holds each connector in place. I found it best to use a flat head screwdriver, insert in the small recess at the front/long side of the clip and just "pop" the clip up. Then with your fingers lift the clip as far up as you can (it will stop, you won't pull it off). These clips are a pain in the arse because they always want to work there way back down, so with one hand hold the clip up, and with the other slide the electrical connector off the bremi. Repeat this process for all 4 bremis. The last one (closest to the firewall) is a PITA but take your time, just move the rubber insulator as best you can to access the connector. With the electrical connectors off I then removed the two 10mm nuts that hold the black, plastic wire loom in place. With the all of the above mentioned removed it makes access to the bremis very easy.
On to the Bremis. There are two 10mm nuts that hold each bremi in. Start with the first bremi, remove the nuts (again be careful as not to drop the nuts down into the galley) With the nuts removed get two fingers under each side of the bremi and give it a firm tug straight out. Remove the bremi and set aside.
Cover off and the first bremi out
Here is a pic with a bremi out, it is the driver's side but you getb the point
With the bremi out, use a very long 3/8'' extension, a wobble joint and your spark plug socket to get the plug out. Try to turn the plug as true to center as possible. This is hard because of the angles required to access the plugs. Remove plug and number. Reinstall new plug and turn in with FINGERS ONLY (ie remove the racket and turn the extension with your hands) this will ensure the plug seats true and not cross threaded. These are aluminum heads, not hard to f up. Once the plug is turned down by hand grab your torque wrench and tighten to 21-22 ft/lbs. Again keep your extension as true to center as possible. Reinstall the bremi and your done your first plug. I again suggest leaving the electrical connectors off to better facilitate access to the remaining units.
Work your way rearward. The last plug is a bit hard to access, but use your head and take your time.
After you change all 4 plugs, put everything back together in reverse order. Again the plug closest to the firewall is just a PIA.
I am not going to post about the drivers side because it is 99% the same as the passenger! There are a few AC hoses that are in the way, so small hands work better.
Button everything up
Start her up and enjoy! Make sure you get all your tools out of the engine bay!! Label your old plugs and post pics on here so smarter people can analyze them for you
2001 M5 Carbon Black/Black Extended
Hella Euro Headlamps/Umnitza LED Angel Eyes/UF IATS/MVIV NAV Computer/20% Tint all around
2008 Ford Explorer Eddie Bauer 4x4. Takes the bad weather beating for the beast.
1995 Ford Mustang Cobra
2006 SeaDoo RXP
rdm190 is offline   Reply With Quote
The Following 18 Users Say Thank You to rdm190 For This Useful Post:
-BEASTMW- (11th April 2009), 5PEEDY (9th January 2010), abbas.ali (15th September 2010), AfricaOffroad (28th July 2009), b757236 (18th November 2009), Bryan@Jlevi SW (7th November 2010), Don Incognito (13th October 2009), INFL8 (20th November 2009), NICEBIMMER (12th October 2009), Phil M5 (13th May 2011), primeral (15th January 2010), Sikorsky (8th January 2011), Smiling (17th May 2010), Sulli (21st November 2009), Ted (21st February 2009), thebeef74 (7th May 2010), Torquey5 (14th June 2010), Wi_KeD_M5 (12th April 2009)
Old 3rd November 2006, 18:03   #2
richie_rvf
richie_rvf's Avatar
Garage: BMW E39 M5 Le Mans Blue
Thank you very much for that - I was to do this over the weekend but something else has come up so it will have to wait
Did you fit OEM plugs?
Richie.
richie_rvf is offline   Reply With Quote
Old 3rd November 2006, 18:09   #3
rdm190
rdm190's Avatar
Richie.
The manual has two plugs Bosch and NGK. I Choose to try the Bosch, just to be different
Old 3rd November 2006, 18:11   #4
richie_rvf
richie_rvf's Avatar
Just read your other post where you say that
Thanks again!!
Richie.
Old 3rd November 2006, 18:55   #5
Beamer_usa
Beamer_usa's Avatar
Garage: explosive ford pinto
Cool DIY, Thx for the pics. Keep us posted on the Bosch plugs
Dinan Cans
Dinan Software
Beamer_usa is offline   Reply With Quote
Old 5th November 2006, 00:19   #6
M5CCIE
M5CCIE's Avatar
Garage: 2003 M5 Sterling Gray
Sales Feedback: (5)
In my bookmarks. Thanks!
Dinan 3.45 differential
TMS Shark Injector - 91 Octane tune
IATS Relocation - Inside Air box
Strong Strut front brace
TC Design rear swaybar brackets
Bluetooth
V1
Aux port
M5CCIE is offline   Reply With Quote
Old 5th November 2006, 00:51   #7
ard
Super Moderator
ard's Avatar
Which manual???
Old 5th November 2006, 01:11   #8
M5finally
M5finally's Avatar
Garage: 2002 M5 Silver
Good job
M5finally is offline   Reply With Quote
Old 5th November 2006, 02:37   #9
rdm190
rdm190's Avatar
Originally Posted by ard
Which manual???
My 01 BMW "User Manual" has two plugs in the back of the book under "Specs" a NGK type and a Bosch type. I can scan the page for you if you like
Old 5th November 2006, 04:35   #10
a_ok2me
a_ok2me's Avatar
Garage: M5
Tools:
3/8'' Rachet
3/8'' Wobble joint
10mm Socket
Spark Plug socket
Torque Wrench
Lots of light
Gloves
Liquid refreshment
I attached pics in the other spark plug thread too. If only I saw this post before I started.
I didn't have to touch the air filter. I used a universal joint instead of the wobble extension. This gave me all the clearance I needed around the air filter box. I bet this saved some time. It took me 2 hours total, but I spent 1/2 hour talking to neighbors, so 1.5 hours.
Different from yours. I used:
1/2" rachet
Two 1/2" extensions 6" long
Universal joint
One 1/2" extension 3" long
a_ok2me is offline   Reply With Quote
FS Brand new set of 8 NGK spark plugs dmz Parts / Other For Sale or Wanted 2 18th April 2006 19:41
Another reason to change the spark plugs. vics E39 M5 and E52 Z8 Discussion 10 24th March 2006 06:16
Problem removing spark plugs OldDawg E34 M5 Discussion 7 21st February 2006 01:32
Changed Spark plugs, old ones were so foul cali6869 E39 M5 and E52 Z8 Discussion 17 16th January 2005 19:18
New pics of E60.. link inside wanted///M5 E60 M5 and E61 M5 Touring Discussion 9 14th November 2002 04:22
