Risk of Driving with different size tires - BMW M5 Forum and M6 Forums
post #1 of 5 Old 31st October 2006, 07:15 PM Thread Starter
zaapa
Had a rear tire damaged and installed a slightly different size tire (until a PS2 of the right size can be shipped in for mounting). Are there any problems driving with different size tires on the car. Could the different rotational speeds of the two different size tires damage the rear differential?
zaapa is offline
post #2 of 5 Old 31st October 2006, 07:36 PM
ard
Super Moderator
ard's Avatar
What size?
How many miles until the PS2 comes in?
You should know that the new PS2 only comes in an "MO" version, and the older PS2s are non-MO (this is a mercedes version)...Michelin recommends replacing BOTH tires on an axle when going to the MO...
A
ard is offline
post #3 of 5 Old 31st October 2006, 07:38 PM
SCC
SCC's Avatar
Using a different size tire temporarily wouldn't necessarily be a bad thing. If used for an extended period of time it would definitely cause some problems to the diff being that one tire is going to get traction before the other. Premature tire wear as well. The real question is how long is it safe to do it for and I would imagine that a less aggressive driving style would be suggested.
00 M5 Carbon Black /All leather - Black/Bruyere Club/Alcantra Headliner
325i Sport (sold)
SCC is offline
post #4 of 5 Old 31st October 2006, 08:07 PM
PhilSeastrand
PhilSeastrand's Avatar
I was told that this is definitely a high risk. The differential is not designed to be "differentiating" all the time. Normally, with same sized tires, the differential isn't really doing anything. When you take a corner, it needs to compensate for the differences, but this is relatively short-term. In your case, the differential will be conpensating constantly and I believe it will generate too much heat in the differential and cause damage.
Phil
2010 Toyota Prius
2004 Honda Pilot
PhilSeastrand is offline
post #5 of 5 Old 31st October 2006, 08:18 PM
verhagke
verhagke's Avatar
If you mean a difference in circumference, it's a no go. If you are talking about tire width, and the difference is within 5%, I think you will be ok for a short period of time.
verhagke is offline
BMW Performance Center announces 2005 driving program schedule kees E39 M5 and E52 Z8 Discussion 0 22nd March 2005 11:55 PM
When To Flip Race Tires and My Local "Horror" Story--TRACK BLABBING Too Anita E39 M5 and E52 Z8 Discussion 6 1st August 2004 10:10 PM
An in-depth SMG II review (LONG) kenneth E39 M5 and E52 Z8 Discussion 17 10th March 2004 01:31 AM
SMG Press Release Omar E39 M5 and E52 Z8 Discussion 12 18th February 2001 11:45 PM
