Rear wheel alignment? - BMW M5 Forum and M6 Forums
post #1 of 21 Old 26th October 2006, 12:46 PM Thread Starter
Blue Thunder
My car wears its rear tires very unevenly as you can see in this picture:
The car is lowered so maybe that comes into play.
What are my options to even out the wear - has the rear suspension any alignment options to compensate for this?
1999 M5 Avus Blau Metallic
Twin Rotrex superchargers, Front mount intercooler, Steel sleeved block, Forged CP pistons, 10.5:1 compression, SS Headers, SS race cats, TUBI Rumore, UUC 11" V12 cerametallic clutch + flywheel, UUC EVO3 SSK w/DSSR, Brembo GT4 brakes front/back, KWv3's, Angel Eyes + Angelibrights, Celis, 19" Hamann PG2´s, Strongstrut front Strut Brace, BMW fire extinguisher, Dynawin headunit, CF interior trim
1989 E30 M3 White - track toy
S85B54 with M-DCT - 600+ hp, 1300kg rocket for the Ring being built
Blue Thunder is offline
post #2 of 21 Old 26th October 2006, 01:40 PM
Michael_s
Michael_s's Avatar
When I was in college i was driving on a twisty road in my 87 Supra Turbo (great car until the turbo blew ) and I heard a loud bang. I pulled over and the rear tire was flat. I changed the tire and looked at the tread which looks exactly like yours. Half of the tire had tread, the other half was worn down to the steel. The rear alignment was way off. I think you might have the same problem. I would get it checked out. Also, I would not use that tire as its going to blow out on you. Just my 2 cents. Good luck.
Michael_s is offline
post #3 of 21 Old 26th October 2006, 06:59 PM
gbogh3
gbogh3's Avatar
That is pretty typical. If you look how BMW's "sit" the camber of the rear tyres wears this way. Yours seems to be a little more extreme that I have experienced.
g
2010 X5 3.5 diesel, dialy driver, loaded, Awesome Car!
2002 E39 M5 Sold
2004 X5 4.8is Sold
2005 X5 3.0 RIP
1995 E36 325i Sold
1989 E30 325i RIP
1972 3.0s Sold
gbogh3 is offline
post #4 of 21 Old 26th October 2006, 07:28 PM
Kin Mak
Kin Mak's Avatar
Too much negative camber... good conering on the track but the outcome is the inside wears out first.
BMW E46 M3 SMG Carbon Black/Cinnamon
BMW E39 M5 Avus Blue - SOLD
Kin Mak is offline
post #5 of 21 Old 26th October 2006, 08:23 PM
SACM5
SACM5's Avatar
Could also be that with wear the suspension is starting to sag. If you take it to BMW they will do the whole sandbag thing and then check the camber. They can adjust the negative camber so you still have camber but it is not so harsh on the inside of your tires. Often times it is because the suspension needs to be adjusted.
2003 BMW DINAN M5 - (Dyno Run - SS Headers, SS Xpipe, Dinan Cans)
Dinan Forged Wheels - Dinan High Flow CAI - Dinan IATS Relocation - Dinan Front Strut Tower Brace - Dinan Exhaust - SuperSprint Headers (ceramic coated) - SuperSprint Downpipe - SuperSprint X Pipe - Evosport Power Pulleys - UUC EVO III SSK - UUC DSSR - UUC Tranni Mounts - Euro Headlight Lens w/Clear Corners OEM - Umnitza HID 6000k Angel Eyes, Low Beams & Fogs - Valentine 1 Hardwire - DA Upgraded Rear Sway Bar Supports - DA High Flow Velocity Stacks - D/A Shadowman Software (PowerChip REMOVED) - Michelin PS2's - Tuned By Discovery Automotive (AREA 51)
2004 BMW X5 4.4i
2003 BMW 530i
1998 Chevy Tahoe
1998 Honda CBR - Smokin Joe's
1969 AMX 390 Hurst 4-speed (GoPak)
2003 MasterCraft X2 (MCX)
Emmick Shifter Kart (0-100-0 in under 7 seconds)
Couple Go Peds w/High Powered Weed Eaters on board
SACM5 is offline
post #6 of 21 Old 26th October 2006, 09:24 PM
E55AMG2
E55AMG2's Avatar
You need to have your "toe" set to zero. If that doesnt work, you need camber plates.
E55AMG2 is offline
post #7 of 21 Old 26th October 2006, 09:42 PM
gsfent
gsfent's Avatar
Thought the rear had some camber adjustment. For less tire wear, take it down to about 1 degree, or the lowest amount the specs call for. I use a much too aggressive 2.2, should prob be more like 1.5, but the rear sure does stay planted!
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, Sachs high performance PP and CCC proprietary clutch disc, stock DMFW, open brake ducts, Hamann front splitters, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, 6k super white low beams, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge, Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup.......
gsfent is offline
post #8 of 21 Old 26th October 2006, 10:03 PM
ard
Super Moderator
ard's Avatar
Disagree.
You can have your camber perfect and if your toe and cross toe is off you will absolutely scrub the inner edge down to the cords very quickly!
Do not be satisified with "it is within BMW specs"... have the alignment set for minumum wear- close to minimum toe in.
A
ard is offline
post #9 of 21 Old 26th October 2006, 11:15 PM
Laidback
To get more of those tires try switching your tires every couple of thousand miles... (side to side if your running staggered setup) ...
"Illegitimus non carborundum"
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Laidback is offline
post #10 of 21 Old 26th October 2006, 11:20 PM
SACM5
SACM5's Avatar
Seems like with the directional tires these days you cant even go side to side.
2004 BMW X5 4.4i
2003 BMW 530i
1998 Chevy Tahoe
SACM5 is offline
Cracked rim, need new Rear OEM E39 M5 Wheel KBK Parts / Other For Sale or Wanted 12 25th October 2007 07:24 PM
Wheel bearings or Rear Diff mounts?? Tin E39 M5 and E52 Z8 Discussion 4 19th May 2005 08:09 PM
OT New Z06 rebel1 E39 M5 and E52 Z8 Discussion 86 12th January 2005 12:43 AM
Confused over wheel alignment russell2002 E39 M5 and E52 Z8 Discussion 1 26th July 2003 12:38 AM
wheel alignment with OEM wheels on car Magna E39 M5 and E52 Z8 Discussion 0 29th November 2002 06:40 PM
