Old 15th August 2001, 22:37   #1
VanCooper
VanCooper's Avatar
Garage: 2007 VW GTI
Question about tires
Recently, I have noticed tire screetch when doing a right or left turn leaving an intersection and all of that with the DSC on as well as sports mode turned off. We have 23000 kilometers on the pilots and I was wondering if that's a sign that we'll have to replace them soon? Thanks for any help!
P.S. I may sound blind but where is the wear indicator?
2006 Interlagos Blue M5 - My father's
2007 VW Golf GTI - My little rocket!
VanCooper is offline
Old 15th August 2001, 22:48   #2
greg
greg's Avatar
Garage: 2000 Anthracite
it is possible to have tire noise before DSC kicks in.
Check your pressures - my tires make more noise as the pressure gets lower.
Wear bars are part of the tread. USUALLY they are "bars" running across the grooves, and, although not quite as deep as the grooves, deeper than the main tread. When the tread wears down so that the bars are flush with the tread surface, it is time to replace. You CAN go further, but your grooves will no longer function, severely impacting wet handling.
greg is offline
Old 16th August 2001, 03:16   #3
VanCooper
VanCooper's Avatar
Garage: 2007 VW GTI
Thanks for the help Greg. I'll go check that tire pressure right away.
Old 16th August 2001, 04:47   #4
Scotty
Scotty's Avatar
Garage: M5
Also, DCS won't keep your tires from screeching when you're travelling sideways
Scotty is offline
Old 16th August 2001, 16:02   #5
fais2000
fais2000's Avatar
Garage: LeMans Blue M5
my suggestion,
don turn at speeds over 70 in an intersection hahahahahahaha,
im sure you knew that was coming
fas
fais2000 is offline
Winter tires on...BooHoo..no traction! ELEVENS E39 M5 and E52 Z8 Discussion 42 28th March 2006 07:34
Question about storing tires... adegiulio E39 M5 and E52 Z8 Discussion 3 19th October 2003 08:24
Question regarding track wheels & tires Rallistas E39 M5 and E52 Z8 Discussion 7 17th June 2002 18:59
Tread Bar / Tire Wear Question GNALUZU E39 M5 and E52 Z8 Discussion 3 23rd January 2002 18:21
Budget tires are fun! :) Xipe E34 M5 Discussion 7 28th August 2001 05:33
Page generated in 0.09547 seconds with 11 queries
