Old 6th October 2006, 05:33   #1
psunitlions1
psunitlions1's Avatar
Garage: 2001 M5 Carbon Black
CPS(Cam position sensor) question
in looking through the threads
Im trying to determine why the car has a lugging of the engine noise around 3500 rpm...doesnt seem to pickup as much as it did a few weeks ago
Im thinking this is a CPS issue but could it be something else?
the lugging engine noise just gets real deep as I give it gas pass 3500 rpm then around 4500 it seems to get back to normal
now this doesnt happen all the time but it is starting to happen more frequently
if it is cps can this be easly identifiable at the dealer and whats the cost to fix
man she dissapointed me tonight and the noise was enough for me just to drive around 3000
psunitlions1 is offline
Old 6th October 2006, 06:11   #2
ard
ard's Avatar
Weird.
bad cps should not be just at certain RPMs but I suppose it could start out like that. each one is around $250 total if the dealer does it- one thrid that if you do it.
Problem is most cps failures manifest as a code and SES light, I thought.... do you have a peake code reader? (You might consider it, one use and it is break even)
Have you done the MAF test?
Miles, year, recent maintenance? Airfilters all new?
A
ard is offline
Old 6th October 2006, 07:46   #3
psunitlions1
hmmm
2001 42k just had it inspected sept 8th and some minor repairs to pass inspection
but drove it on a long roadtrip soon after at the end of the road trip check engine light came on but has been off since
had nasty rain storm about two weeks ago and drove through some 2ft water ---symptoms happened soon after
thought it was water related
then my check oil level went on recently and I kinda laxed on checking it since I havent driven it much but tonight was when the lugging noise started to occur so I put some oil in for fear that I was on the verge of siezing the engine-- im sure it wasnt going to..... but that lugging sound ... i could feel it in the car a big rumble coming from the rear just had me very worried about it
Old 6th October 2006, 08:31   #4
Need4Spd
Need4Spd's Avatar
Uh-oh. Sorry to say this but you might have had some serious engine damage. If you drive through deep water there's a good chance your engine inhales water into the intake. When that happens, it goes to the cylinders where the pistons try to compress it, but water is mostly incompressible. Something has to give, so the result is bent valves or possibly broken piston rings. You should have your car inspected by a good independent shop and tell them what happened. Hope I'm wrong about this and all that happened was the water contaminated the MAFS, which are easily changed.
Need4Spd
Need4Spd is offline
Old 6th October 2006, 08:41   #5
ard
ard's Avatar
The error that set the light will still be stored. Important info.
I'm having trouble with 'lugging noise' and 'big rumble from the rear'.. they aren't painting a picture for me. The classic cps failure, for the exhaustCPS, is a blatty exhaust sound and markedly low power.
How are your air filters? Nice and dry?
A
PS Go Joe Pa...
ard is offline
Old 6th October 2006, 16:08   #6
psunitlions1
well i cant exactly say it was 2ft
of water it was just driving through a bad rainstorm where everyone goes like 10 mph becuase there is significant water on the highway maybe more like 5-6 inches
I can chek the air filters... they are dry they are dirty and need changing
However if it is the cps is this something I can drive with for awhile just to expect a lcak of performance or does engine damage start to creep in the longer i let it go
I have about a 200 mile trip on Saturday and I dont want it to be somethng that leaves me ina tough spot
Old 6th October 2006, 16:35   #7
Frits
Frits's Avatar
Garage: E36 M3 alpine white E39 M5 carbon black E24 M635CSi royal blue
I would bring it in to the dealer TODAY, just to check what's wrong. They can see in 20 seconds if you have a bad CPS. And I wouldn't dare to drive more than 30 miles when the check engine oil level warning came up. You're dealing with a very expensive engine here!
In the future, make sure you always have an extra litre of oil in the trunk. Whenever the check oil level warning comes up, add that litre from the trunk.
edit: I would not start this 200 mile trip before having the car inspected by a dealer.
Frits is offline
Old 6th October 2006, 17:29   #8
mjshira
Garage: Silver 2000 M5
this sounds very much like CPS. If you need help send me a PM and we can talk on the phone.
I would be careful with dealers, you never know what you are going to get when you go to one.
mjshira is offline
Old 6th October 2006, 23:09   #9
psunitlions1
turns out an o2 sensor triggered the code
would an o2 sensor cause the same stuf a cps would?
also how about a bad guibo for noise?
Old 6th October 2006, 23:38   #10
ard
ard's Avatar
Originally Posted by psunitlions1
would an o2 sensor cause the same stuf a cps would??
What "stuff"????? symptoms or codes?? did someone diagnose your car and pull codes? If so, post the details
Very much so, but shouldn't affect 'lugging and driveability'. Combined with maybe 02 or cps I suppose it might appear that way.
ard is offline
TECH: Replacing intake Camshaft Position Sensor... BlueBomber E39 M5 and E52 Z8 Discussion 70 15th May 2009 08:42
Troubleshooting throttle position sensor codes? WraithCar E39 M5 and E52 Z8 Discussion 7 9th August 2007 06:24
Steering wheel shift paddles position brutus E60 M5 and E61 M5 Touring Discussion 4 13th November 2005 23:18
What is your best seat/driving position? ManikM5 E39 M5 and E52 Z8 Discussion 1 17th May 2004 14:39
TireRack Test of SO3, Pilot Sports, Pzero's steveB E39 M5 and E52 Z8 Discussion 1 12th June 2001 00:16
Page generated in 0.16552 seconds with 11 queries
