Old 6th October 2006, 00:45   #1
Anita
Anita's Avatar
Garage: 02 M5 TiSi
Quick Fog Lamp Assembly Part Question
Does anyone know if the fog lamp assembly, in this case I'm using the part number for the left one, #63 177 894 017, comes with the bulb? Or do you need to order it seperately?
Thanks so much!
Anita
"When will I know that I really can't go
To the well once more time to decide on
When it's killing me, when will I really see
All that I need to look inside
Come to believe that I better not leave
Before I get my chance to ride" RHCP "Snow"
Anita is offline
Old 6th October 2006, 01:08   #2
1mpowerme
1mpowerme's Avatar
Garage: 2000 Carbon Black M5
Sales Feedback: (7)
That part number you listed looks like the one for the left side to me. Yes when you buy a new fog lamp assembly from BMW, the bulb is included.
2000 BMW M5
Carbon Black
Black/Aluminum Trim
- Bilstein PSS9 Suspention
- Dinan F&R Tower Struts
- Navigation Upgrade to MKIV Computer and 16:9 Widescreen
- Headlight Upgrade to Hella Headlights w/Angel Eyes and 6000K HIDs
- Fog Light Upgrade with 6000K HIDs
- Tail Light Upgrade with Hella Celis Tail Lights
- BBS RGR Diamondblack Wheels
- Tubi Exhaust
- UUC Short Shifter
- Black Kidney Grills
- Carbon Fiber Roundels on Wheels, Hood and Trunk
1mpowerme is offline
Old 6th October 2006, 01:21   #3
aaronmiles
aaronmiles's Avatar
Garage: 1999 Imola Red M5
Send a message via MSN to aaronmiles
Same here.. bought a set about 12 months ago (and got one replaced under warranty about 3 months ago) and they certainly do come with globes.
1999 Imola Red M5. Extended Caramel Interior
Mods on my pre-update beast:Eisenmann "Race" exhaust (76mm tips), 19" Hamann PG2's, AACAI, Clear Angel Eyes, MK4 Nav, GC's M5 Coilover kit w/front camber plates, Dinan Front and rear sway bars, D/A swaybar mounts, Dinan front and rear strut brace, Braided brake lines, Eibach 3mm wheel spacers, Rogue Engineering underdrive pulleys, IATS Relocation, Powerchip, Xenon foglights & Lower engine covers w/Brake duct cutout
2008 Volkswagen Golf GTI. The wifes new car
2005 Ford Territory Ghia. The wifes car. (Sold)
1986 Toyota Landcruiser HJ75. The farm ute.
aaronmiles is offline
Old 6th October 2006, 03:15   #4
Anita
Anita's Avatar
Garage: 02 M5 TiSi
Thanks very much!! I cracked the lens a long, long time ago and was so cheap that I decided to use it 'till the bulb went--which it did just recently.
I would've probably just ignored it, but that message on my display (and those 2 triangles) are driving me nuts.
It sounds like a real easy item to replace too, right?
Anita
Anita is offline
Old 6th October 2006, 03:43   #5
jclyman
jclyman's Avatar
Anita
Easy to fix, BUT you need to be VERY careful removing the old light ... I would "power" spray water all around the oval part to try and remove little grits of dust ... they will scratch the paint if you aren't careful ... Using a screwdriver is not the problem as you know that may scratch, it's the years of grit that has built up ...
- Daniel Boorstin
jclyman is online now
Old 6th October 2006, 03:48   #6
Anita
Anita's Avatar
Garage: 02 M5 TiSi
Thanks very much for that tip. I would bet I have some very embarassing grit down there too!
Anita is offline
Old 25th October 2006, 01:40   #7
Anita
Anita's Avatar
Garage: 02 M5 TiSi
Well it's done and after a little tool wrestling and job sharing with the hubby I would rate this as an "EASY DIY"
Anita is offline
Old 25th October 2006, 02:07   #8
aaronmiles
aaronmiles's Avatar
very good .. it can be a pain getting them in and slotted can't it. Now all your need a HID kit for it
Quick Wheel Question (BBS LM'S) jhendershaw E39 M5 and E52 Z8 Discussion 9 30th June 2005 17:07
quick question for you audio/stereo experts...... FAST 5 Off Topic Forum 0 30th May 2005 23:36
Quick fog light removal question kcdoyle E39 M5 and E52 Z8 Discussion 3 20th February 2005 02:15
Question for those with HID Fog Upgrade. Amir M5 E39 M5 and E52 Z8 Discussion 5 11th February 2005 16:11
Quick wheel question, thanks... KevinM E39 M5 and E52 Z8 Discussion 2 7th February 2005 18:43
Page generated in 0.12434 seconds with 11 queries
