Old 5th October 2006, 19:29   #1
Boz M5
Garage: M5 Jet Black
Suggestions on fixing nav?
Yesterday Im heading down south to Powerchip from Bakersfield. Reflash my car. About 3/4 of the way down there I notice the nav arrows blinking then pointing the wrong way then it starts saying im on a different street. Now it says on the screen correct destination not possible. I updated to the new nav over a year ago with no problems. One thing also is my car rides really rough on trips (H&R coilovers) it will wear you out. Another matter though. Ive taken the DVD out and reinserted it but nothing. (2005-2 version) If anybody has some suggestions it would be greatly appreciated.
Boz
Boz M5 is offline
Old 5th October 2006, 19:45   #2
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
are you running a mk4? Try disconnect/reconecting it. Wait until it powers down first. I've had a few quirks with my nav, seem to be temp related. If i'm taking a long drive, in hot weather, i leave the pannel open to the nav/audio area in the trunk, which has seemed to help.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 5th October 2006, 20:14   #3
Boz M5
Yes it is the mk4 I will try that. Thanks Mike
Boz M5 is offline
Old 5th October 2006, 20:34   #4
chrisj
chrisj's Avatar
Garage: 2000 M5 Jet Black / Black
Make sure the antenna connection didn't come loose. If your car rides rough, maybe the vibration caused it to work itself loose. Does the GPS see the satellites?
chrisj is offline
Old 6th October 2006, 01:22   #5
aaronmiles
aaronmiles's Avatar
Garage: 1999 Imola Red M5
Send a message via MSN to aaronmiles
Ive had this twice since I upgraded to V71 of the OS..... what version of the software are you running?
IF you check the service menu for the GPS you will see that the version is listed as 0.0.0 (or simmilar) rather than the 1.2.18 (or whatever its suppose to be)
1999 Imola Red M5. Extended Caramel Interior
Mods on my pre-update beast:Eisenmann "Race" exhaust (76mm tips), 19" Hamann PG2's, AACAI, Clear Angel Eyes, MK4 Nav, GC's M5 Coilover kit w/front camber plates, Dinan Front and rear sway bars, D/A swaybar mounts, Dinan front and rear strut brace, Braided brake lines, Eibach 3mm wheel spacers, Rogue Engineering underdrive pulleys, IATS Relocation, Powerchip, Xenon foglights & Lower engine covers w/Brake duct cutout
2008 Volkswagen Golf GTI. The wifes new car
2005 Ford Territory Ghia. The wifes car. (Sold)
1986 Toyota Landcruiser HJ75. The farm ute.
aaronmiles is offline
Blank Nav Screen Skulhammer E39 M5 and E52 Z8 Discussion 32 10th April 2009 16:39
Nav 22 Fixing DSP Gremlins? Rcl4668 E39 M5 and E52 Z8 Discussion 4 24th October 2003 19:19
Comment & Question about our NAV software for the beast............ FAST 5 E39 M5 and E52 Z8 Discussion 21 24th May 2003 17:58
NAV - unable to enter street numbers in address book w/ v 3-1/40 ? Jacob Lee E39 M5 and E52 Z8 Discussion 2 24th February 2002 01:00
updating NAV software...very simple, quick, and painless. 6 minutes. Jacob Lee E39 M5 and E52 Z8 Discussion 7 2nd February 2002 16:27
Page generated in 0.13484 seconds with 11 queries
