Old 4th October 2006, 04:53   #1
bimmernut1
bimmernut1's Avatar
Garage: Ti Silver M5, Red Porsche C4S
Is the term MAF a misnomer?
I've read through about every link on this subject and have a question. When I read how this system works, it appears that the sensor itself does not measure mass flow but instead volumetric flow (e.g. SCFH). True mass flow is only obtained when the volumetric flow is converted to mass (e.g. lbs/hr) by the car's computer using the ambient air pressure and temperature readings. This mass flow appears to be the flow that fuel flow is ratioed against, not the output from the MAF itself. Is this assumption correct? If so it should be called a VAF (volumetric air flow).
On a related note all I see points to the fact that the MAFs should be treated as a maintenance item. That is, assuming you can get them from David rather than the dealer's high price, shouldn't they just be replaced at say 50k miles regardless of how the car "appears" to run. If other electrical items like O2 sensors and spark plugs have a recommended replacement interval, shouldn't the MAFs as well since they can gradually lose efficiency which is only detected by the test procedure. I don't see many total MAF failures, most appear to just gradually perform poorly. I can see not doing this at the dealer's cost but if the cost is reasonable, I think they should just be replaced at some given interval (what that interval is is uncertain to me however). Could BMW's 4 year 50k mile warranty be the reason they don't recommend replacing them within that period? I'm not cynical by the way.
2003 Titanium Silver M5
1996 Red Porsche 993 C4S
1979 Tobacco Metallic 911SC
bimmernut1 is offline
Old 4th October 2006, 05:04   #2
Nabio
Nabio's Avatar
Garage: Jet Black E39 M5
Send a message via AIM to Nabio Send a message via Skype™ to Nabio
When BMWNA marketing began offering extended maintenance a lot of normal maintenance items turned into "lifetime" or "only if it throws a code" replace items. I don't know if the MAFs fall under this category (although the dealer will replace them under CPO if they throw a code I think) but the fuel filter is an example of an item you should replace optimally every 30k. Clearly it's not a "lifetime" item as BMW seems to think.
Jet Black 2000 M5
Nabio is offline
Old 4th October 2006, 05:19   #3
bimmernut1
bimmernut1's Avatar
That's a good point. I would love to see a list of items that have increased recommended intervals "after" the marketing of zero maintenance began. Perhaps some are a result of improvements in technology, but I bet some are just a result of BMW not wanting to pay during the 4/50 period.
Old 4th October 2006, 06:25   #4
StevenZ
Garage: BMW M5 Silver/Black
The fuel filter is an often overlooked maintenance item. After you run your tank to empty a few times you should probably change the fuel filter. You are basically cleaning your fuel tank into your fuel filter. You don't want that crud to get to your engine.
If you keep your tank at or above 1/4 full with quality fuel you can probably change this filter every 50 - 60K miles. I've never seen a filter that lasts forever!
2000 M5 Silver/Black 03/00 build
StevenZ is offline
Old 4th October 2006, 06:29   #5
StevenZ
Add transmission oil and differential oil to this list. They don't last forever either. I change transmission oil at 50K miles and differential oil at 65K miles. If you drive your car especially hard change them sooner.
StevenZ is offline
How to test the MAFs yourself and How MAFs work DavidS E39 M5 and E52 Z8 Discussion 378 2nd September 2009 03:42
MAF Tech Info bimmerpwr E39 M5 and E52 Z8 Discussion 2 23rd June 2006 20:36
DINAN Maf Silverstone//M5 E39 M5 and E52 Z8 Discussion 4 17th October 2005 07:49
MAF Cleaning - First Hitch ... grp E39 M5 and E52 Z8 Discussion 24 18th April 2005 16:37
KN filter and MAF....Lost power? Gaspasser E39 M5 and E52 Z8 Discussion 7 3rd September 2003 11:48
Page generated in 0.12586 seconds with 11 queries
