Old 4th October 2006, 00:34   #1
DavidS
DavidS's Avatar
Garage: 2000 M5 LeMans blue
Sales Feedback: (4)
If there is sudden and gradual loss of power - BEWARE!
A word of caution regarding coolant leaks on all BMWs:
The coolant temperature sensor is located high up on the engine. If there is a massive loss of coolant, and the sensor gets dry, it will happily keep reporting a nice low temperature, while the cylinder heads will melt at the valve seats from the heat in the exhaust gases. In that case there will be no warning lights or anything, just a destroyed cylinder head.
Any sign of sudden gradual power loss, immediately stop the engine.
Depending on how much power the engine is running at, you have between 5-30 s before there is insanely expensive damage.
The situation is far more immediately dangerous to the engine than a complete loss of oil pressure would be.
That power loss likely comes from overheated cylinders causing pre-ignition and the DME pulling ignition timing to compensate.
There are sensors for pretty much everything, but not for the temperature of the cylinder heads. (Apart from the coolant temperature sensor, which stops working if it gets dry) Forget about noticing the problem on the oil temp gauge, it is a very slowly reacting temp sensor, and it does not start to move until it is far too late.
David
(I just posted this in a thread about coolant leaks, and then it occured to me that it might be of value as a thread of its own.)
DavidS is offline
Old 4th October 2006, 00:41   #2
FallbrookM5
Garage: '08 E60 M5 6 spd SpaceGray
not to mince words, as this sounds serious....but is sudden and gradual not mutually exclusive ?
FallbrookM5 is offline
Old 4th October 2006, 01:02   #3
DavidS
DavidS's Avatar
Sales Feedback: (4)
Not mutually exclusive in this context. Suddenly starting powerloss, that gets gradually worse by the second as the cylinder heads overheat.
I´ve seen perhaps 3 or 4 such heads in BMW dealer workshops, and it is not a pretty sight. Molten aluminium and holes straight through the valve seats.
David
DavidS is offline
Old 4th October 2006, 01:04   #4
FallbrookM5
My old man fried his head on a 1986 325i in germany.....I think it was the same issue. Scary to think about what thecost that would be on the M5. I agree with your explanation though ! I will be very aware.
Old 4th October 2006, 01:15   #5
DavidS
DavidS's Avatar
Sales Feedback: (4)
Sorry the hear that. I have no first hand info from anyone who has driven a car it has happened to, just good advice from mechanics.
Perhaps you could ask him what happened, and what, if any, warning signs there was immediately before the damage.
David
DavidS is offline
Old 6th October 2006, 05:43   #6
psunitlions1
psunitlions1's Avatar
Garage: 2001 M5 Carbon Black
where does the power loss occur
im experiencing some lugging of the engine around 3500 rpms like it kinds wants to go but make a deep gutteral sound and you can feel it in the seats but once it gets what it want at higher rpms then it seems fine
is this lack of oil, cps or the dreaded cylinder heads?
psunitlions1 is offline
Old 6th October 2006, 08:45   #7
veilside02
veilside02's Avatar
Garage: 2003 BMW M5 Jet Black
Send a message via AIM to veilside02
thanks for the info
2003 Jet Black /// M5
Rogue SSK/WSR
Rogue Transmission Mounts
Tubi Rumore Exhaust
CA Carbon Rear Diffuser
Active Autowerke Front Grille
Bimmian Shadow Black Grille
K-40 Radar Detector and Laser Jammer
FOR SALE: Hamann Full Front Spoiler
veilside02 is offline
Old 6th October 2006, 14:28   #8
racerock
Garage: 5
My brother in laws dads car was a few miles from this condition. Exactly as you describe. Pinhole leak in the radiator, overflow tank sensor stuck. No indicators that it was low on coolant.
racerock is offline
Old 6th October 2006, 15:10   #9
Jenner
Jenner's Avatar
Garage: 2003 M5 Sterling Grey
Does anyone know how this would be handled by CPO warranty given that it's a sensor design/location flaw?
Would they repair or replace?
2007 Audi RS4 Avus Silver/Black/Premium
Tubi exhaust/LI-S4 concealed display
1997 Porsche 993TT Black/Black
FVD 440 HP ECU/GHL Exhaust/Bilstein PSS-9/Turbo S Lip/SSR GT3
Past M cars:
2003 M5 Sterling Grey/Silverstone
Jenner is offline
Old 6th October 2006, 18:05   #10
racerock
Garage: 5
racerock is offline
Page generated in 0.27663 seconds with 11 queries
