Old 3rd October 2006, 12:44   #1
kiddhan625
kiddhan625's Avatar
Garage: 2002 M5
Some Concerns about the Beast
I have a 2002 M5 with about 22,000 miles on it. I am having some issues and would like for you guys to shed some light on possible causes. The car is going in tommorow for a dash replacement and would like to get the following issues looked at as well:
1. The Air Bag light comes on at random times and turns off at random. I am assuming this a faulty sensor of some sort?
2. When driving the car at consistent speed above 40 mph if I place my left foot slightly on the cluth pedal I feel a strong vibration coming from the pedal. The same vibration at a lesser effect can be felt in the shifter.
3. Shifting from 1st to 2nd and from 3rd to 4th is pretty rough. Feels like something needs to be greased or lubed.
4. The car seems to be lagging! It doesn't pull like it use to. Even in sport mode seems like the car is not performing anywhere near the level it was. Considering the car only has 22,000 miles I am kind of surprised.
5. I have an extended warranty on the car and was wondering if I should get the Extended Maintenance through BMW? Mine expires on Oct 16th of this month.
Any input would greatly appreciated. Thanks
kiddhan625 is offline
Old 3rd October 2006, 13:16   #2
Frits
Frits's Avatar
Garage: E36 M3 alpine white E39 M5 avus blue E24 M635CSi royal blue
As for number 4: do a search on MAFs. Or cam position sensors. These can seriously affect the car's performance.
Frits is offline
Old 3rd October 2006, 13:52   #3
dave_gt
dave_gt's Avatar
Garage: E39 M5 Le Mans Blue
kiddhan625. I stress that I am not a qualified mechanic, but I'll have a bash:
1. This could indeed be a faulty sensor, or more likely a dodgy connector. My airbag light did the same thing a while back. The dealer (who actually seems quite good) diagnosed that the passenger seat sensor was faulty. I read on this board that the connector underneath the seat can be the culprit. I fiddled around with said connector trying to make the best connection possible by hand and it seems to have worked. I haven't seen the airbag light for a couple of months and it was only this thread that reminded me of it!
2&3. Some people do report clutch failiures at 20,000+ miles but it depends on the sort of driving it is used for - mine is still going strong at 90,000. Most members report that the clutch can't hold onto the revs when it goes, so it might not be the actual cltuch plates that are worn. Also, several members report that they find the 1st to 2nd change a bit notchy, although 2nd to 3rd is usually ok. Maybe if there was a problem with the clutch - possibly the thrust bearing being knackered - that would affect the clutches ability to fully disengage engine from gearbox and the shifts wouldn't feel as smooth. I would get a proper garage to check it out.
4. I agree that MAFs sound a likely cause, but at 22,000 miles it would be early for MAFs to be bad. There is a test that you can do to monitor the fuel flow (and therefore air flow) which can indicate if you have bad MAFs. It was written by moderator DavidS - search should find it.
5. Warranties have been a bit contentious recently, and I think that the situation is a bit different on either side of the pond. I'll leave it up to someone in the good ol' US of A
2001 M5, Lemans Blue / Silverstone
Standard except for a few bits & stereo:
6.5" Focal components, 10" Directed sub, IceLink, JL Audio & Directed amps (hidden). Predator ICE, Stealth bulbs, V1, Roadpilot
1990 Mazda MX-5 (brilliant) 1998 Nissan Primera GT (modded)
dave_gt is offline
Old 3rd October 2006, 16:50   #4
kiddhan625
kiddhan625's Avatar
Garage: 2002 M5
Thanks for the input guys. Anyone have anymore insight on #2? If it normal to feel a vibration in the clutch pedal?
Old 3rd October 2006, 16:56   #5
MGZ
MGZ's Avatar
Garage: M5 e39 Carbon Black
Sales Feedback: (3)
Maybe a very, very, very slight vibration absolutely nothing more and that is only if I really think abt it.
MGZ is offline
Old 3rd October 2006, 16:57   #6
gbogh3
gbogh3's Avatar
Garage: 02, M5 Sterling Grey
Send a message via Yahoo to gbogh3
#5 I left my beast at the dealer for 3 weeks when it was coming off warranty. Even though you are about to get it back in a few days, or maybe its back, you may want to schedule another appt a couple days before it goes off.
The dealer can keep the paper work open if they choose so you can keep adding things to the car to be fixed. You can always take it to an independent, have them pull all the codes and give you a print out, then hand a copy (not the original) to the dealer to clear and fix faults, this way if something comes up in 4 months, you have made them aware of it BEFORE the car went off warranty.
Don't know about # 2, sorry.
GL
02 Sterling Grey with Extended Caramel Leather
AA Cold Air/ Brake Ducts, SS Headers, Mystery Short Shift, Dinan Stage III w/ JRZ, Tubi Competition Exhaust, Dinan Stage 4 software, Hardwire V1, XM, Clear Bra.
2010 X5 diesel, dialy driver, loaded
2004 X5 4.8is Sold
2005 X5 RIP
1995 E36 325i Sold
1989 E30 325i RIP
1972 3.0s Sold
gbogh3 is offline
Old 3rd October 2006, 17:02   #7
kiddhan625
kiddhan625's Avatar
Garage: 2002 M5
This isn't slight. I can feel it through the boots I wear. Its got me concerned because I feel the same vibration in the shifter but to a lesser effect.
Old 3rd October 2006, 17:22   #8
MGZ
MGZ's Avatar
Sales Feedback: (3)
Then I think that something might be seriously wrong. But wait until the real specialists have their say
MGZ is offline
Old 3rd October 2006, 19:28   #9
jclyman
jclyman's Avatar
Suggestion on 1. Same thing happened to my 1997 318ti, but the light stayed on. My indi blew the seat belt connector out with air and sprayed electrical contact cleaner in it ... SOLVED! I had assumed the same thing.
On 5. If you decide on the Extended Maintenance ... DON'T PAY MORE THAN $ 1,195.
- Daniel Boorstin
jclyman is offline
Old 3rd October 2006, 19:34   #10
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
i think by stepping on the clutch pedal, while you are driving, you are causing it to slip, hence the vibration.
mike
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
MMMach5 is complete. The beast is here. MMMach5 E60 M5 and E61 M5 Touring Discussion 35 6th May 2006 22:50
MMMach5 is complete. The beast is here. MMMach5 Owners Gallery 12 4th May 2006 16:20
How to wash the beast in freezing temps ELEVENS E39 M5 and E52 Z8 Discussion 14 30th January 2004 18:20
Help!! My beast producing burning smell...Doc needed?? WarpSpeeD E39 M5 and E52 Z8 Discussion 13 5th November 2003 17:33
"Great night" - beast crashed para22 E39 M5 and E52 Z8 Discussion 12 30th September 2001 07:45
Page generated in 0.17811 seconds with 11 queries
