The license plate read "FF COBRA." You guess the abbreviation.
By the end of this story it should read "F'D UP COBRA."
Again, I'm out on patrol for a short cruise through Arcadia and Pasadena. (It turns out that I've found a source for UNOCAL 100 octane gas, and I am running 1/2 a tank of that stuff at $5.00 per gallon.) This story is short and sweet. I come across the confident driver of a 1999 Mustang Cobra in Arcadia on Huntington Dr. and Santa Anita Dr. This car is sporting slightly oversize tires in the rear, a modified exhaust, and plenty of stickers. I am nervous that this car is some kind of drag racing special and proceed with caution. This guy is aggressive, and wants to launch about 300 yards from a police station! No way for me. There were way too many cars around, and I've read about all of these serious wrecks on this message board.
In any case, we end up going north on Rosemead Blvd. and catch a red light at Del Mar. This confident sucker then gestures to me with the commanding point of his finger to line up next to him.
OK, here we go. The light goes green and he leaves with lots of revs. I know the M5 only needs about 1500 r.p.m. at launch, so I make sure I hook it up and don't hit the limiter. Instantly, the M5 leaves much harder and pulls more revs at the end of 1st. You can tell his power band is much shorter. At the end of 1st I have over 1 car length, and increase the distance easily. By 60 it's about 3 or more, and the distance quickly increases to 5 or more
as the speeds go to 75 or so.
This was a blowout. It didn't take 100 m.p.h before I was able to pull away, like some other stories I've read previously. This was a walk-away from the start. A real ego bruiser.
We had a second rolling start run where he started the charge from 2nd gear. The result was the same. I complimented him on his nice car and went away. He'll remember an M5, and maybe Ford drivers will be a bit more eductated for a change.
A lot of words for something that really is no big deal.
By the way, the UNOCAL 100 does make a difference. I found it in Pasadena at the UNOCAL station on Arroyo Parkway and Glenarm. That gas delivers a consistently sharp performance which is noticeable.
