Can Nitromethane be used for our cars. Read on...... - BMW M5 Forum and M6 Forums
post #1 of 22 Old 22nd September 2006, 12:45 AM Thread Starter
FAST 5
FAST 5's Avatar
Question Can Nitromethane be used for our cars. Read on......
I saw this article and was interested to hear what you guys have to say. Thanks!
If you want to make a high-power 4-stroke engine, there are a couple of different ways to accomplish your goal. One way is to increase the displacement. Another is to stuff more air into the engine with a supercharger. If you want to go to extremes, you would replace gasoline altogether and use a more energetic fuel. Top fuel dragsters do all three.
A "nitro-burning" engine and a "top fuel" engine are the same thing -- engines designed to burn nitromethane rather than gasoline. Gasoline is a hydrocarbon, and the common chemical formula for gasoline is C8H18. Nitromethane has the formula CH3NO2. Nitromethane is a little like gasoline that has been pre-mixed with nitrous oxide. The fuel comes with its own oxygen atoms to help it burn.
The big advantage of nitromethane is that you can get a lot more power from each explosion inside the engine. Pound for pound, nitromethane is less energetic than gasoline, but you can burn a lot more nitromethane in a cylinder. The net result is more power per stroke. You typically need about 15 pounds of air to burn 1 pound of gasoline, whereas you need only 1.7 pounds of air to burn 1 pound of nitromethane. This means that, compared to gasoline, you can pump about 8 times more nitromethane into a cylinder of a given volume and still get complete combustion.
Since nitromethane is not as dense as gasoline in terms of energy, you do not get an 8-time improvement in terms of power. It is more like a 2.5-time improvement. Still, you can double or triple your engine's horsepower simply by changing the fuel. That's a huge improvement!
http://www.pricechemical.com/super_concentrate.htm
http://www.motorsportsracingfuels.co...Additives.html
A typical drag-racing engine has a displacement of 8.9 liters, is supercharged and produces about 6,000 horsepower. It can burn close to a gallon (4 liters) of nitromethane per second! To put that in perspective, there is something like 2 teaspoons (10 cc) of nitromethane being poured into each cylinder per intake stroke.
An interesting thing about nitromethane is that it does not burn as quickly as gasoline. In fact, there is not enough time to burn all of the nitromethane between when the spark plug fires and when the exhaust valve opens. So the engine is pumping still-burning nitromethane into the exhaust pipe. That's why you see flames shooting out of the exhaust of a drag-racing car.
Mixing the fuel..............
Recent nitromethane problems have resulted in limited availability of specific mixtures. You may want to do some fuel mixing or changing of existing mixes. Also, you may want to get some idea of what these fuels do in an engine. The following may help. All mixes are described on a percentage by volume basis which seems to be standard in the glow engine fuel business. Standard American volume equivalents are: 1 U S gallon= 4 quarts= 128 fluid ounces= 231 cubic inches. A typical mix, called 10% fuel, is 10% nitromethane, with 25% castor oil and 65% methanol- all by percentage volume so that a gallon of 10% looks like the tabulation below. 12.8 oz. nitromethane 10% 32.0 oz. castor oil 25% 83.2 oz. methanol 65% --------------------- ----- 128.0 oz. total (gallon) 100% The calculation for oil, as an example, is 25% of a gallon which equals 0.25 x 128 oz. or 32 oz., and the calculation for nitromethane at 10% is 0.10 x 128 oz. or 12.8 oz. The nitro and oil are carefully mixed with about half gallon of methanol and then the gallon is completed with methanol- thus avoiding directly measuring the methanol. Stir some more and cap the mixed fuel. Mixed fuel, well capped, will last for years with no change in quality. I personally do two and a half gallons at a time. The materials discussed in this paper are methanol, nitromethane and castor oil. Alternates or options, such as nitroethane and synthetic oils, will be discussed briefly. More exotic and dangerous materials should not be used. Methanol (wood alcohol, methyl alcohol, and meths in the UK) is the first oxidation product of methane, CH4, and has the chemical name CH3OH. Further oxidation produces formaldehyde, then formic acid, and finally carbon dioxide and water (CO2 & H2O), which is ultimate--you cannot burn water! All of these godies occur in your engine and produce heat which does the work. Methanol is a colorless and almost oderless liquid which is a violent poison and is highly flameable. It burns with a pale blue flame which is not visible in daylight. You could be on fire with methanol and nobody could see the flames. Methanol produces 55,550 net BTU per gallon, a 3450 OF flame temperature in air, has a near 43 OF flash point (does not evaporate below 43 OF), and a 725 OF ignition temperature. The addition of castor oil and nitromethane will slightly lower the ignition temperature of the mix. 1300 OF to 1500 OF temperature is indicated by the "color" of a hot glow plug coil. The flammable limits of methanol (% vapor in air by volume) are 6.7% lower and 36.0% upper. So if lean or rich on a cold day (43 0F flash point), your engine will be a real bear to start. A gallon of methanol requires about 560 standard cubic feet of air for combustion, resulting in exhaust gasses composed of 78.4 standard cubic feet of carbon dioxide (CO2), 156.9 cu ft of water (H2O) at 212 OF (vapor), and 445.5 standard cubic feet of nitrogen (N2). The nitrogen comes from air, 21% oxygen (O2) and 78% nitrogen (N2), which must be pushed through the engine to provide oxygen for combustion of the fuel. Good methanol is both anhydrous (free of water), and hydroscopic (absorbs water from air and is soluable in water). It should never be exposed to humid air (most air is humid) for more than a few minutes. Dry methanol is a good fuel, while wet methanol is a dog- will still burn, but not well. Good dry methanol has a gravity of 0.7914 and anything higher shows water. Pure water has a gravity of 1.0000. Castor oil is the "classsic" oil for glow fuel; a vegitable oil from the beans of a plant called RICINUS COMMUNIS. Chemically it is C11H10O10, viscous, clear to yellow, and about the same weight as water. Medically it was an old fashioned laxitive and if 75 year old memory serves was pretty potent! Castor oil as a lubricant is exceptional because of heat resistance, cling, and lubricity. The cooeficient of frictiom for steel om steel, using castor oil as lubricant is 0.095, which is better than all other oils listed in the handbooks. Compare to wet ice on wet ice with a cooefficient of friction of 0.05 to 0.15, where the lower number is the most slippery. Castor oil at 10% would lubricate an engine, but it is raised to 25% so that the oil can also act as a coolant. It does not enter into combustion, just pumps through the engine the same as nitrogen. The castor "smoke" you see in the air is mostly fine droplets of oil. Traces of true smoke may be produced in a very hot engine. Castor oil smoke has a pleasant odor, while most of the synthetic oils have a perfume-like odor associated with their smoke. The two together produce a definite and unique flying-field odor. The main difficulty of the synthetic oils is that there are so many of them, each manufactured for a specific purpose, but not for glow engines. I tried one by NATIONAL CARBON, which was manufactured as a substitute for castor oil, and used as a lubricant for rubber conveyor belts. Using 1/3 synthetic and 2/3 castor as a 25% fuel component, I have experienced no problems and will continue as long as the keg of synthetic oil lasts. The big negative with castor is that it polymerizes to a tacky varnish when left on surfaces and exposed to air- makes messy airplanes. Synthetic oils seem to reduce or soften this polymerization when mixed with castor oil. Nitromethane (CH3NO2) is a colorless liquid, sweet smelling, soluable in methanol, and normally stable- but with the chemical potential to detonate. When mixed in methanol it gives the mixture the "alcohol" smell and provides some oxygen for combustion beyond the induced air. The OSHA exposure limit is 100 ppm over an eight hour period, so don't just sit there and sniff the stuff. At my purchasing level nitro is about $30.00 per gallon. The "old hands" say that the nitromethane "activates" the methanol, but as a nasty old combustion engineer, I do not know "what the watermelon hell", "activates" means. Let's look at the combustion to see if we can figure it out. The molecular balance for the combustion of methanol (CH3OH) is: 2(CH3OH) + 3O2 --> 2CO2 + 4H2O or two mols of methanol require 3 mols of molecular oxygen (two volumes of molecular methanol vapor require 3 volumes of molecular oxygen for complete combustion), but oxygen comes in a package called air which is 21% molecular oxygen and 78% molecular nitrogen. There is 3.76 times as much N2 as O2 in air. 3O2 + (3.76 x 3N2) or 14.26 "mols air" are required to burn 2 mols of methanol. Fuel/air ratio for methanol is 1/7.14. The molecular balance for the combustion of nitromethane, (CH3NO2) is: 4(CH3NO2) + 3O2 --> 4CO2 + 6H2O + 2N2. 4 volumes of nitromethane vapor require 3 volumes of molecular oxygen for complete combustion, which is 14.28 volumes of air as above. The fuel/air ratio for nitromethane is 1/3.57. Nitroethane (C2H3NO2) will provide available oxygen the same as nitromethane, but will not provide as much extra oxygen per unit volume. Compare methanol fuel/air ratio with nitromethane fuel/air ratio, 1/7.14 for methanol and 1/3.57 for nitromethane. The nitromethane is providing some oxygen for combustion and needs less induced air to burn; in fact, twice as much output is available from pure nitromethane as from pure methanol for the same amount of air. So the nitro is a chemical form of super-charging. With an increase in hp there is a corresponding increase in rpm, with an additional increase in induced (carbuerator) air, with a compound increase in output hp. I am working on an algorithum to relate % nitro to % increase in engine output-- realizing that no two of these little engines are the same or will experience the same operating conditions. How much output increase is very difficult to calculate, but we know with increase in % nitro we gain in output, engine operating temperature, and the cost of the fuel. The conclusion is that nitromethane provides extra oxygen above that provided by combustion air and therefor improves hp output. The practical rule is to provide no more nitromethane than needed for your plane, your engine, and your flying wants. Most of us can get along on 5% or 10% nitromethane fuel. 10% nitro is actually 13.3% nitro if you look only at combustibles- the oils do not enter into combustion so can be thrown out of the calculation for effective percent of nitro. A twenty year old ringed SUPER TIGRE "60" size engine running at 11500 rpm pumps 6900 cu in of air per minute or 3.99 cu ft of air per minute- on a good day! Round this out to 3,5 cu ft of air per minute because of nominally poor air, porting losses and blow-by. Apply the old combustion rule that a cu ft of air can burn a 100 btu, and the old engine burns about 350 btu per minutr. The engine may "suck up" a lot more fuel than this, but wastes it; these engines are rich even when "leaned out". 1 1/8 oz of 0-25-75 fuel runs about one minute in the "60", but this is only 0.844 oz combustibles since the oil is not to be burned or about 366 btu of methanol per minute. Note that there is more btu of fuel than btu of combustion air (366 to 359), so the air is limiting the input of the engine to 350 btu per minute. 350 btu per minute is roughly equivament to several hp, but a lot of energy is lost to exhaust temperature and very low efficiency in these small engines. The result is that engine output is estimated to be less than 3/4 hp- would hardly pull a sick river-boat gambler out of church! Your engine output may be more or less when running on 0% nitro. Back to mixing fuels. If we have a gallon of 10% and wish to chaange it to 5%, we first realize that the 10% has 12.8 oz nitro per gallon and we need only 6.4 oz per gall for 5%. There is no way to take nitro "out" of the 110% gallon, so the 10% gallon must be diluted to reduce the nitro to 5%. The extra nitro can build another gallon of mixture at 5%. The second gallon requires 32 oz (25%) of oil. Using a two gallon container, dump in the gallon of 10% mixture, add the 32 oz of oil, and enough methanol to complete the 2 gallons. Stir well and tightly cap the new 5% fuel. The new 2 gallons of 5% mixture is: 12.8 oz nitromethane 5% of 256 oz (2 gal) 64.0 oz oil 25% of 256 oz 179.2 oz methanol 70% of 256 oz --------------------- ---------------------- 256.0 oz total 100% of 256 oz (2 gal) When the added methanol completed the two gallons, 6.4 oz of the added methanol filled in for the 6.4 oz nitro that was "taken out" of the 10% gallon to start the new 5% gallon. To move from 5% fuel to 10% fuel, start with the 5% gallon which holds 6.4 oz nitro. Now add enough nitro to make a 10% mixtue (larger container now needed). The new mixture will have a volume of 128 oz plus whatever nitro is required to make a 10% mix. This sets up a small algerbra problem-- algerbra at the RC field-- what is this world comming to? If "x" is the added nitro, then (128 oz + "x" oz)(0.10) = "x" oz + 8.4 oz. This equation translates to 10% of the new volume is equal old nitro plus the added nitro. Now you hot shot math purists realize that adding nitro requires that we add a little more oil and a little more methanol. We are approaching a true 10% mix by simultaneously adding oil and methanol. The above algebraic approxamation puts us within 2% of being "right on", so do not worry about it unless you enjoy simultaneous equations. Presume a 5% mixture and a 10% mixture; the challange being to produce a 10% mixture. I would not waste my time thinking about this one- the practical approach is to correct the 5% to 10% and the 20% to 10% and throw the two into a container marked 10%. References are the North American Mfg Co combustion engineering book and Chemical Rubber Co chemistry and physics handbook.
I guess the old saying is true. "Gasoline is for washing parts, alcohol is for drinking and nitro is for racing."
FAST 5 is offline
post #2 of 22 Old 22nd September 2006, 02:19 AM
1mpowerme
1mpowerme's Avatar
I'm not reading this.....not at the end of a day at least.....
2000 BMW M5
Carbon Black
Black/Aluminum Trim
- Bilstein PSS9 Suspention
- Dinan F&R Tower Struts
- Navigation Upgrade to MKIV Computer and 16:9 Widescreen
- Headlight Upgrade to Hella Headlights w/Angel Eyes and 6000K HIDs
- Fog Light Upgrade with 6000K HIDs
- Tail Light Upgrade with Hella Celis Tail Lights
- BBS RGR Diamondblack Wheels
- Tubi Exhaust
- UUC Short Shifter
- Black Kidney Grills
- Carbon Fiber Roundels on Wheels, Hood and Trunk
1mpowerme is offline
post #3 of 22 Old 22nd September 2006, 02:47 AM
TurboCarrera
And you can cut the mean time between rebuilds by 90%. That is the footnote missing from the article.
Steve
00 M5
TurboCarrera is offline
post #4 of 22 Old 22nd September 2006, 03:45 AM
Evil One
Evil One's Avatar
Steve
00 M5
Lol !!
So if we take the mean time between rebuilds (MTBR) and multiply by the specific density of nitroethane diluted with methane, and replace all cannisters with liquid caster oil flavoring, mixed thogoughly with a left-handed screwdriver, we get:
MBTR+NETH+BOOZE/SLOSH = BANG + $$$ + .
Simplicity itself...
Of all the things I've had and lost, I miss my mind the least.
Evil One is offline
post #5 of 22 Old 22nd September 2006, 04:09 AM
jclyman
In Memoriam
jclyman's Avatar
BUY a TOP FUEL Funny car ... and, tow it to the track with your M5.
- Daniel Boorstin
jclyman is offline
post #6 of 22 Old 22nd September 2006, 05:32 AM
TiSiBeast
TiSiBeast's Avatar
Fast5 - try dumping some in and let us know the results.
Current Toys: 2000 M5 with lots of goodies, 1997 993 Targa mostly stock, 2002 Jeep GC all set for offroad, 2004 Acura TL bone stock
TiSiBeast is offline
post #7 of 22 Old 22nd September 2006, 06:16 AM
EM5PWR
EM5PWR's Avatar
EM5PWR is offline
post #8 of 22 Old 22nd September 2006, 07:11 AM
SC'dKellenersM5
SC'dKellenersM5's Avatar
Robert,
NOS Racing Fuel additive used MHT/MMT which is really nitromethane in their additive. I have used it before in the m5 back in the day and actually was pretty impressed with the difference in off idle torque and overall performance.
Im in the highspeed aluminum business
SC'dKellenersM5 is offline
post #9 of 22 Old 22nd September 2006, 07:15 AM
6spd
6spd's Avatar
I stopped at
One would have to increase the duty cycle and size of the injectors to make it work.
"Top fuel racing isn't real racing its a amateur form of rocketry and hydraulics"
Now don't waste your time on that stuff grab the Klotz CoXoC and run that.
We ran that stuff and it kicks butt on restricted class engines.
Old school fuel tests can't find it.
We ran it in a ProStock with great results, also great in boats up on Lake Tahoe.
I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way.
Modifications
Chipped paint
Worn tyres
Dirty Carpet
Chipped windshield
6spd is offline
post #10 of 22 Old 22nd September 2006, 07:34 AM
Tomahawk
Tomahawk's Avatar
I think finding a better fuel source sounds great if we get more horse power. The week before I moved from texas to cali I was running 100 octane! Boy you can feel it! Now I run 91
Frank T.
2000 M5
Dinan stage 3 software
Dinan SSK
Dinan strut bar
Dinan Flywheel
Tomahawk is offline
On the discussion of other cars and relative value... daniel E39 M5 and E52 Z8 Discussion 1 25th September 2013 10:33 PM
Carbon Build-up Issue: SURVEY RESULTS wilsodh E39 M5 and E52 Z8 Discussion 15 16th December 2005 08:39 PM
Alpina BMW CS coupes - what is the truth? Stasis M535i ALPINABoard.com | BMW Alpina Discussion 2 15th June 2005 02:38 PM
BMW 850i Alpina in Japan Ferda ALPINABoard.com | BMW Alpina Discussion 11 14th January 2003 04:06 PM
E60 M5 to be SMG ONLY?!?! Ashok Arora E60 M5 and E61 M5 Touring Discussion 98 2nd November 2002 11:53 PM
