Guys,
I wanted to get your opinion and thoughts on the symptoms my car has experienced in the last two days. The SES Light came on and the panel read "Engine Failsafe Program"... Along with that I felt that the car was "heavy" and/or restrained. I ran a search of past posts on this subject and it appears that many of you have experienced similar circumstances.
Based on the search, the most common reasons for this to occur are:
-Cam shaft sensors
-MAFs
-Pulse generators
-O2 rings
There were other mentioned, but none seemed as prominent as the ones listed above.
I have scheduled an appointment for this upcoming Friday to have the car checked out at the dealership. I was wondering how should I approach this as in should I let the dealer diagnose the car, or should I suggest the possible reasons (as cited above) so that they make sure they check those areas since there seems to be a number of occassions when the dealer did not recognize these as problem areas.
Finally, my car is a MY00 and it is now on an aftermarket warranty, so I was wondering if anyone had an estimate of what the costs and/or if the costs would be covered by the warranty, which I have with AAA.
Any comments would be greatly appreciated.
Thanks in advance,
-Akira
