Old 9th August 2001, 04:02   #1
sgalaba
sgalaba's Avatar
Garage: E46 M3 Silver
Movit Big Brakes, wheels spacers, aftermarket wheels
After installing Movit Big Brakes do you need to run a spacer or do the stock front wheels fit just fine? If a spacer is needed, how much? Anyone then install aftermarket wheels with Movit Big Brakes that fit without the need of spacers? If you do need spacers with the aftermarket wheels what brand and style of wheels and how big of a spacer is needed?
sgalaba is offline
Old 9th August 2001, 04:05   #2
johann
Administrator
johann's Avatar
Garage: BMW E39 M5, Carbon black
Send a message via MSN to johann
Re: Movit Big Brakes, wheels spacers, aftermarket wheels
This goes for the 322mm kit front.
Stock rims will need a 16mm spacer.
AC Schnitzer rims does not require a spacer.
BBS RC requires 4-6mm spacer.
There may be many rims that fit without a spacer.
Cheers,
/Johan
johann is offline
Old 9th August 2001, 04:52   #3
sgalaba
sgalaba's Avatar
AC Schnitzer rims
Do you know which style of AC Schnitzer rims it was that fits? Are AC Schnitzer rims made or are they the same as Breyton?
sgalaba is offline
Old 9th August 2001, 13:35   #4
johann
Administrator
johann's Avatar
Re: AC Schnitzer rims
I know that ACS Racing wheels Type III 19" works. I am also convined that they will work as 18" and also that the Light alloy wheels Type III will work in 18" as well as 19".
I dont' think they are the same as Breyton, they look a bit similar but completely similar.
Cheers,
/Johan
johann is offline
QUESTION: Does anyone have the DINAN BRAKES and if so......... FAST 5 E39 M5 and E52 Z8 Discussion 19 26th April 2006 21:11
Who makes the OEM wheels for BMW? Who makes the best aftermarket wheels? Magna E39 M5 and E52 Z8 Discussion 2 4th March 2002 06:18
A new wheel option for Mov'it, Brembo, StopTech customers DZeckhausen E39 M5 and E52 Z8 Discussion 15 3rd January 2002 17:41
Page generated in 0.11546 seconds with 11 queries
