31st August 2006, 19:34
#51
Originally Posted by olis1
Hey Palantirion, why don't you scan and post the dyno sheet that showed both our cars on the same graph. I think that will be interesting for lots of people as well as help Dinan see that these were two cars on the same dyno within minutes of each other both with Dinan equipment on them, albeit your has more.
Oh, and what does Palantirion mean?
Jon
-Because I have three scanners - and none of them work for one reason or another. No matter, I can use my digital camera clean it up in Pshop. Might be tomorrow before I have time though, got a lot going on right now...
p.s. Palantirion (long story, going back to college) is from Tolkien's Sylvan Elf language and it basically means "far-seer", or "one that looks to the long way". The full name is actually Palantirion Dur-wen Vagoroth. "Far Seer" "Lover of Women" "Those that strike from the shadows". A friend and I have been using the House Vagoroth name for online gaming since 1999, but the clan is between games at the moment.
www.ebsart.com
2011 X3 35i, Alpine White with Nevada Chestnut interior and waveline wood trim
-Ceramic tint on all windows
-DVDinMotion DVD software unlock
-245/275 P Zeros f/r on 18x8.5/10 BBS RG-Rs
2007 Z4 M Coupe, Titanium Silver with Imola Red interior and silver trim
-for paint details: www.myartcar.com
-for mod details: www.mymcoupe.com
2003 M5, Imola Red with black interior and silver trim
-Dinan S2 drivetrain
-Dinan stage 3 suspension with JRZ shocks
-StopTech brakes
-Rogue Engineering short shift kit and clutch stop
-275/35R18 Michellins f/r on 18x9.5 BBS RS-GTs
-Progressive window tint
-Euro dash and armrest conversions
-CDT/Total audio, NavTv w/ DVD
-Seat massagers
31st August 2006, 19:50
#52
2001 M5 Dinan S1
Olis means "Lover of women and fast cars".
2001 Dinan S1 M5, Lemans Blue, Blue/Black, sunshades, pdc, alcantara headliner, M Audio)
-Dinan S1 (Stage III Suspension, Exhaust, Cold Air Intake, Floor Mats)
-Powerchip Gold 91 Software (currently running Dinan S1 software)
-Stoptech 355mm Front BBK Kit with M5 Logo on caliper
-Autosolutions Ratio 2 Short Shift Kit
-TC Designs Rear Sway Bar Brackets
-BBS CH Wheels, 8.5x19 front, 10.0x19 rear
-Michelin PS2's 245/35/19 front, 275/30/19 rear
-UF Motorsports IATS Kit
-Stage II 62 HID Lowbeams
-4300k HID Foglights
-Eurospec Center Console w/ Storage
-Mark IV DVD System
-Euro Angel Headlights w/ Clear Corners
-Silvervision turn signal bulbs on all 4 corners
-M5 Trunk Mat
-M-technic kit with custom painted splitter in M colors
-Brake duct kit
-35% Madica Film Tint
-MB Quart speakers w/ Neo Tweeters/ Monster 1 Farad Capacitor
1st September 2006, 01:36
#53
Official Dinan representative
E60 M5 White
Hi
In an earlier past you said there was fuel dripping from the exhaust. Assuming that the car still has cats this would be highly unusual; I would be very suspicious that it was actually water. In fact with cats we have never seen that and frankly if it were that rich we would be amazed it would be running. If it really is fuel than it is your problem , no question.
The effect of ambient temp as a rough rule is 1% for every 7 deg F so that wouldn’t explain it.
1)How much heat there is in the motor/cooling system when the pull is started can changer the power dramatically
2)We install a stand alone Air/Fuel meter and drive it on the street.
3)Here is where I begin to get suspicious, what work was performed at the body shop? If the MPG calc went that far off at that time. Is it just the MPG of the on board computer or did the mileage actually change also? If so you would have to believe that something broke/put together wrong. By virtue of the fact that the MPG (calc or actual) changed so dramatically there must be some problem. After all the MPG calculation are based on injector duty cycle time, fuel injector size, fuel pressure… At a minimum the electronics went a little nutty, you have to fix what you know is wrong before looking for new faults.
4)Does it have overdrive? If it were in overdrive then the HP would come out correct but the TRQ would be low HP
HP = (TRQ * RPM)/5252
Where HP = horse power, TRQ = torque in Ft*Lb and RPM = revolutions per minute
So 320= (TRQ*5500)/5252 therefor TRQ = 382
If it were in overdrive of .8
320 = (TRQ*(5500/.8))/5252 therefore TRQ =244
These numbers line up pretty closely with what you got.
Cheers
1st September 2006, 01:58
#54
Representative for themshop.com, m5board.com Sponsor
'98 M3 and '07 335i sedan
Originally Posted by jimmyz2
Wow,great thread.Thanks guy's.Man if I was The VFE guy I would be really pissed.Heck,my little E34 540i did a heat soaked 370 rwhp before my upgrades.They M5s do sound awesome.
On a dynojet, that VF SC 540i made 322rwhp.
Did anyone recall the A/F ratio Roadwarrior's SC 540i got?
Jon C.
1st September 2006, 03:18
#55
02 M5
looks like a BBS convention to me ...
1st September 2006, 10:21
#56
Originally Posted by Dinan Engineer
Hi
-Now I wish I had bothered to smell it  The car had been driven to the shop, then sat for an hour, hour and a half before dynoing. Maybe some condensation could have formed?
-Right.
-It had been siting for 1-1.5 hours. It was warmed, but not hot.
-So there's no hidden diagnostic code in the M5's ECU? I thought somewhere there was once posted a code used for checking if you MAFs were clean that showed a/f.
-They replaced the front PS fender, both PS doors, repaired the PS rear quarter, and painted appropriate pieces. I also had them do the hood since it was cheap to do at the time. My mileage is still the same, just the counter is off. Any idea on what (physically) could have been effected by the above repairs? Chris ( I assume you know him and BMS) cleared about 40 console faults and one "unrealistic air temperature" fault on Friday, the day before the Dyno Day.
-It's an M5, so yes. I don't know what gear they ran it in, but it was within 1 second of Olis1's time to spin under load (I checked the tape). I don't know if that time would change depending on gear used though. When I take it back I'll certainly be keeping more detailed notes.
Cheers
-That's an interesting formula. So is the TQ number on a Dyno only accurate if you are in a 1:1 gear? And the HP gets corrected by measuring the wheel rpm?
-If I did the math right...If my S2 was actually generating 290lb-ft at the wheels in 6th gear (0.83:1) at 5200rpm, then it was actually making 349lb-ft at the flywheel in 5th (1:1). 70lb-ft short of advertised, 19 less than stock.
Thanks for your detailed response Paul. I hope we can sort this out
1st September 2006, 16:21
#57
2001 M5 Dinan S1
[/quote]
Thanks for your detailed response Paul. I hope we can sort this out  [/quote]
I'm pretty sure the torque isn't calculated like that. The dyno measures engine rpm and wheel rpm and from that makes the gear conversion so it doesn't matter what gear you are in (I think if I understand it right - someone correct me if I'm wrong).
You may want to read some of the earlier posts in this thread as we were discussion how they measure torque on a dyno without inputing the gear and ratios, etc.
By the way, they ran my car in 3rd gear and my guess is yours was the same.
Jon
1st September 2006, 18:16
#58
E60 M5 White
olis1
thats a good point, let me talk to a few of the guys here who have a lot of experance with the dyno and get back on this.
Do you have a scan of the 540iT dyno run?
1st September 2006, 19:31
#59
couple of thoughts...
1. water is a byproduct of combustion, so i'd bet water was what you saw coming out of the exhaust, not fuel (unless there was fire spitting out of the pipes as well!).
2. I'd highly doubt a dyno run in 6th gear. Dyno's have an upper rpm limit, and even in 5th, you're talking 150+mph dyno speed. This is why many dyno in 4th, 3rd just seems too low. You're going to have significantly more frictional losses in 3rd vs 5th, so that could account for a reduction in the numbers (as far as i understand dynos).
Still likely fault/adaptation issues going on since you had them cleared the day before.
1st September 2006, 19:44
#60
2000 BMW M5 Silverstone
I'm going to give the shop a call next week and set up a time to take my car in during the month of Sept. If anyone who missed this wants to come also and catch lunch also, PM me. I'm REALLY interested to see how my ride matches up on the same dyno.
2009 Mercedes-Benz C63 AMG
2006 Z4 M Coupe
2000 E39 M5
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
