Old 25th August 2006, 00:47   #1
Jon@TheMShop
Representative for themshop.com, m5board.com Sponsor
Garage: '98 M3 and '07 335i sedan
Send a message via AIM to Jon@TheMShop
Why you should change your fuel filter
M5Board member, Up, came to us for an inspection II. We removed his fuel filter and dark dirty fuel came out from the inlet side of the filter. Clean fuel came out from the outlet side.
We poured the rest of the dirty fuel to a plastic tray and let the fuel evaporate. Car had 78,XXX miles.
We drained some fuel from the tank and it too came out clean. Up bought the M5 recently so a previous owner might have put in a bad tank of gas.
Jon C.
Jon@TheMShop is offline
Old 25th August 2006, 01:39   #2
shadowman
shadowman's Avatar
Garage: Z8
A very good suggestion and an item often over looked whether at the dealer or by home mechanic until there is an issue.
Good post
Shadowman
shadowman is offline
Old 25th August 2006, 01:47   #3
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
i changed my fuel filter after doing a mafs test. I got a reading of 166L/h peak, in second gear (this was maybe 18mos ago) and thought man, that is a lot of fuel running thru there. After 60k miles, there must be some junk in there causing a bit of potential restriction. Easy and cheap enough to do, and it was part of the service procedure before bmw's became free to maintain!
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 25th August 2006, 01:47   #4
TiSiBeast
TiSiBeast's Avatar
Garage: 2000 E39 M5 TiSi, 2002 Jeep GC Gray
Wow - thats suprising how dirty that is. Can I get the filter from you guys at D/A?
Current Toys: 2000 M5 with lots of goodies, 1997 993 Targa mostly stock, 2002 Jeep GC all set for offroad, 2004 Acura TL bone stock
TiSiBeast is offline
Old 25th August 2006, 03:16   #5
ard
ard's Avatar
So, lets post the correct part numbers.
Is it:
Fuel Filter: 13321407299
GASKET RING: 07119963129
??? I assume a new o ring with the new filter. Anything else?
ard is offline
Old 25th August 2006, 03:21   #6
Jon@TheMShop
The O-ring is just a copper washer. It is recommend to get a new one because you have to remove the fuel pressure regulator from the filter assembly and bolt it onto the new filter.
Jon C.
Old 25th August 2006, 04:04   #7
M5inGA
M5inGA's Avatar
Garage: '01 M5 in Carbon Black
Jon, doesn't BMW feel that these are good to 100K? So I can assume that mine with 82K has not been changed. Looks to be a pretty straightforward procedure, right?
'01 Carbon Black
Black extended leather w/Aluminum
Fold down rear seat
PDC
Shades
STOCK (for the moment)
02 SWB Ford F-350 crew cab Lariat 4X4
3" lift
Edge Juice w/Attitude programmable chip
'02 Infiniti I35
'00 Lexus LX470
M5inGA is offline
Old 25th August 2006, 04:31   #8
Jon@TheMShop
I have no idea why BMW says 100,000 miles or on every inspection II. They don't know how many gallons of fuel passes through the filter. However, I think there is way to determine how many gallons of fuel a vehicle has used during its lifetime.
If you have not replaced your fuel filter yet and you're over 50,000 miles, then yes I do recommend replacing it. You might even notice a big difference in how the M5 accelerates.
Jon C.
Old 25th August 2006, 05:35   #9
Up
Garage: E39 M5, Avus Blue
I was disgusted at all the dirt coming out of my filter!
I did notice a difference in response and overall power in the car - probably due to the combination of oil change, spark plugs (extremely overdue replacement), and fuel filter. The car feels and sounds healthier.
That much resistance in the filter couldn't have been helping the cars' acceleration!
Next up - MAF's....I feel if previous owner didn't replace plugs and fuel filter, what's the chance of the maf's being replaced! I'm hoping to find more lost power.
Good day!
Up.
Up is offline
Old 25th August 2006, 06:16   #10
ard
ard's Avatar
Up. Pre Cat O2s made a noptceable improvement in mine at 50k.
Folks don't understand that the BMW recommended maintenance is NOT designed to keep your Ultimate Driving Machine in tip-top, race ready shape. It is designed to avoid lawsuits and to reach the end of the warranty period without too many claims.
ard is offline
Charcoal Filter Removal - Step-by-Step (w/Pictures) jfenley E60 M5 and E61 M5 Touring Discussion 432 18th November 2009 18:50
Ethanol based fuel...... Clem E39 M5 and E52 Z8 Discussion 28 23rd February 2006 23:52
E60 M5 - Charcoal Filter Removal - Step-by-Step (w/Pictures) jfenley M5 E39 and E60 tips & tricks 0 2nd February 2006 07:05
Fuel Filter Replacement boostmiser E39 M5 and E52 Z8 Discussion 9 24th November 2005 02:03
Fuel filter location picture and other questions madm5 E34 M5 Discussion 2 3rd November 2005 12:56
Page generated in 0.14697 seconds with 12 queries
