Old 25th August 2006, 00:39   #1
Vason
Vason's Avatar
Garage: '03 M5 - Carbon Black/Caramel
Sales Feedback: (4)
Help with fault codes?
SES light came on the other day so I checked the codes with Peake reader and reset but the light came on again about 20 minutes later. My '03 has
31k miles and the only recent changes to the car is the Powerchip 93 a little over a week ago. Also worth noting is that I filled up the tank with gas that I normally don't ever use and that same day is when the SES came on. Could it be a tank of bad gas causing these faults? The car drives fine. Any insight would be great before I take it the stealer. Here are the codes:
Idle speed controller
Fuel control, cyl #1-4
Fuel control, cyl #5-8
Misfire during warm-up, cyl #3
Misfire during warm-up, cyl #4
Misfire during warm-up, multiple cylinders
'03 M5 Carbon Black/Caramel
'03 M3 Alpine White/Black - Flooded/R.I.P.
Vason is offline
Old 25th August 2006, 01:46   #2
shadowman
shadowman's Avatar
Garage: Z8
Originally Posted by Vason
SES light came on the other day so I checked the codes with Peake reader and reset but the light came on again about 20 minutes later. My '05 has
Before getting exciting and chasing a possible issue I would have the codes cleared and see if they re-appear.
Takes care
Shadowman
shadowman is offline
Old 25th August 2006, 04:01   #3
M5inGA
M5inGA's Avatar
Garage: '01 M5 in Carbon Black
Might be worth a call to the PowerChip folks to see what they have to say...
'01 Carbon Black
Black extended leather w/Aluminum
Fold down rear seat
PDC
Shades
STOCK (for the moment)
02 SWB Ford F-350 crew cab Lariat 4X4
3" lift
Edge Juice w/Attitude programmable chip
'02 Infiniti I35
'00 Lexus LX470
M5inGA is offline
Old 25th August 2006, 06:04   #4
Vason
Vason's Avatar
Sales Feedback: (4)
Takes care
Shadowman
I've cleared the codes twice that same day and they have come back with the same fault codes both times. I'm going to call PowerChip in the morning and see what they have to say.
Vason is offline
Old 25th August 2006, 06:37   #5
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
my money would be on mafs. I have had the exact same codes (besides idle) for mafs. if you are still on that tank of gas that you are questioning, i'd try to run that stuff off and refill with fresh fuel too. Bad gas could cause these codes.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 25th August 2006, 08:24   #6
Vason
Vason's Avatar
Sales Feedback: (4)
Thanks, I'm going to burn through the remaining gas and fill up with what I normally use and then clean the MAFs. If it still throws the same codes then I'll take it in.
Vason is offline
Old 25th August 2006, 14:57   #7
M5inGA
M5inGA's Avatar
I've learned the hard way, you need to do the easiest and cheapest fix first!
Good luck!
'01 Carbon Black
Fold down rear seat
PDC
Shades
3" lift
'02 Infiniti I35
'00 Lexus LX470
M5inGA is offline
M5 OBC FAULT CODES imolaman E39 M5 and E52 Z8 Discussion 0 21st June 2005 10:46
Peake Tool and Resetting Fault codes QUESTION SACM5 E39 M5 and E52 Z8 Discussion 2 15th April 2005 19:13
need help with fault codes please jkarp E39 M5 and E52 Z8 Discussion 1 7th January 2005 06:30
SES light stays on - 4 fault codes M5 CFF E39 M5 and E52 Z8 Discussion 5 18th December 2004 20:46
fault codes without SES light? mottati E39 M5 and E52 Z8 Discussion 9 2nd December 2004 00:27
Page generated in 0.12396 seconds with 11 queries
