Old 24th August 2006, 16:37   #1
mr_bock
mr_bock's Avatar
Garage: 2002 M5, Sterling Gray
How to lift the engine...
I will be installing Supersprint headers soon. Does anyone know how best to lift/support the engine in order to remove the stock headers? Any DIY instructions, suggestions? I did The Search, but found nothing.
Thanks in advance!!!!!!!!!!!!!!!!!!
George B.
2002 Sterling Gray, Black and Aluminum interior
UUC Short Shifter & DSSR
UUC Clutch Stop
UUC Transmission Supports
UUC UltraSmooth CeraMetallic Clutch/LWF
Active Autowerks Cold Ram Air Intake - Modified
Air Plenum Heat Shield, 1700 degree black Jet-Hot coating
Alpine amp for JL Audio Sub Woofers
UFMotorsport S62 Intake Air Temp Sensor Relocation
Dinan Stage II Suspension
Dinan 3.45 Rear Diff. Gear Set
Dual JL Audio 10" Sub Woofers
K40/Laser Defuserplus, hidden install
K-Mac Adjustable Caster/Camber Plates
Kelleners Aluminum Sport Pedals & Foot Rest
MB Quart speaker replacement
NAV MKIV DVD
StopTech SS Brakelines
Axxis Ultimate Brake Pads
EvoSport Performance Underdrive Pulley Set
TubiStyle Cat-Back Exhaust
Power Chip 93 Gold - Modified & Sport 'On'
Perma-Cool Electric Engine Fan (no mechanical fan!)
Michelin Pilot Sport II Tires (front/rear stock sizes)
Royal Purple Synchromax Transmission Oil
Red Line 75W90 Differential Gear Oil
Sirius Radio receiver
SS Headers, EVO High Flow CATS
Zionsville Aluminum Radiator w/ Dual Speed Fan
My latest toy... a 2001 360 Modena Ferrari
My 'other' car is a supercharged 1996 911 C2 993
mr_bock is offline
Old 24th August 2006, 18:04   #2
Mike Krieger
Mike Krieger's Avatar
Garage: 2000 M5 Oxford Green
It sounds like you will DIY. Are you planning on welding stainless? I want to install mine also, but I think I need a TIG welder for the install. Has anyone installed the headers and driven loudly down to the muffler shop to have the thing welded or is it all clamps?
2000 Oxford Green/Extended Caramel
Split folding seats with ski bag
Alacantra headliner
Mk. IV nav upgrade v.27
16:9 monitor
UF Motorsport Intake air temp. sensor relocation
Bimmernav Bluetooth
PowerChip 93
OEM First Aid Kit
Hardwired V1
AA CAI
Bavarian Auto Angel Eye update
Supersprint headers, SS X-pipe and Evo Racing Cats
Dinan Stage 2 suspension
Dinan 3.45 Diff
Mike Krieger is offline
Old 24th August 2006, 18:31   #3
mr_bock
mr_bock's Avatar
Mike,
I am in the process of hooking up the wiring for my MIG welder. My intent is to DIY and tack weld the CATs (Hi-Flow 2.5" Evosport) in place. Lower the assembly so I can weld all around. The SS down pipes look like they clamp to the header collector. I will most likey have a couple of clamps, and weld what I can. I have a line on some Hi-temp caulk that I plan to use at the header pipe to collector.
UUC Clutch Stop
NAV MKIV DVD
mr_bock is offline
Old 24th August 2006, 18:58   #4
Mike Krieger
So TIG is the little one with the rod and MIG has the wire feed and gas bottle? I have an old Lincoln buzzbox arc welder, but I suppose on stainless I will need to upgrade. Does it take a different wire feed for stainless?
Alacantra headliner
16:9 monitor
Bimmernav Bluetooth
PowerChip 93
OEM First Aid Kit
Hardwired V1
AA CAI
Dinan 3.45 Diff
Old 24th August 2006, 19:03   #5
ECB
ECB's Avatar
Garage: 03 Titanium silver M5
Ha! I did that in high school with my '66 289 mustang. Installed tri-y headers at home and drove it to midas to connect them up. Very loud, turned some heads.
ECB is online now
Old 24th August 2006, 19:43   #6
mr_bock
mr_bock's Avatar
Most likely, it would be too expensive to upgrade your buzzbox. The newer welders are much better. MIG is more convienient as it is more 'point and shoot'. TIG requires two hand coordination to get a nice weld feed and bead.
UUC Clutch Stop
NAV MKIV DVD
mr_bock is offline
Old 24th August 2006, 19:56   #7
CSBM5
CSBM5's Avatar
Garage: 2001 M5 LeMans Blue
LOL, I guess many of us have something like that lurking in our past. I had a 1976 Capri II V-6 that I put Doug Thorley headers on (in addition to a heck of a lot of other stuff over time back in the 70's) and drove to Midas -- very loud and every cell in my body was vibrating at the frequency of the exhaust.
Current stable:
Ground Control camber plates
Stoptech front brake kit
Brake ducts opened
TC Design brackets
1996 Volvo 850R wagon
CSBM5 is offline
Old 24th August 2006, 21:59   #8
mr_bock
mr_bock's Avatar
Let's get this back to the original question: How best to lift the engine uo so the OEM headers can be removed. I don't want to risk punching a hole in the oil pan. Who has done this, or how did the shop do it to install the Supersprint headers???
UUC Clutch Stop
NAV MKIV DVD
mr_bock is offline
Old 24th August 2006, 23:59   #9
jcrist
jcrist's Avatar
Garage: 2001 M5 Silver/Black
I hope you work it out George, I'll be up to have you do mine!!!lol
Glad to see you went with this mod, I was pretty excited about this at your party.
My tech said that he was planning on tilting the motor to get the manifolds out. If you want, you can wait for me to get it done and then pass on the info. I will however, ask him intially how to lift and support during "tilt".
Jason
Jason
'01 Titanium Silver Metallic/Silverstone Extended
Ex-mod Queen, now back to Stock!
'97 Boston Green M3
BMWCCA Club Racing IP #360
jcrist is offline
Old 25th August 2006, 03:17   #10
mr_bock
mr_bock's Avatar
Jason,
That would be great. I would be very appreciative to get any tips before I do mine.
It may be a little while till I get to that point as I want to re-dyno my car and sent the results (including air/fuel ratio) along with my ECU module to PowerChip to tweek things to compensate for the new headers. May do another dyno after all of this to make sure all is Ok.
Thanks!!!
UUC Clutch Stop
NAV MKIV DVD
mr_bock is offline
Engine Oil Leak Suspected - Non-Linear Oil Usage 507bhp E60 M5 and E61 M5 Touring Discussion 12 10th December 2005 22:05
E39 M5 2001 Complete Engine Failure! benragan E39 M5 and E52 Z8 Discussion 18 13th October 2005 00:26
BMW M6 Press Release no 1: World Debut of the new BMW M6 (short version). Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 4 4th January 2005 20:39
Press Release no 2: The new V10 Power Unit in the BMW M6: A Masterpiece in Engine... Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 15th December 2004 01:15
New M Engine Info greggb E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 34 8th August 2004 18:17
Page generated in 0.15972 seconds with 11 queries
