Old 26th August 2006, 10:49   #11
Salty
Salty's Avatar
Garage: 2000 M5 Avus Blue
Originally Posted by mr_bock
Jason,
That would be great. I would be very appreciative to get any tips before I do mine.
It may be a little while till I get to that point as I want to re-dyno my car and sent the results (including air/fuel ratio) along with my ECU module to PowerChip to tweek things to compensate for the new headers. May do another dyno after all of this to make sure all is Ok.
Thanks!!!
You probably already thought of this, but it will be a good time to inspect and possibly replace your motor mounts.
Good luck.
Salty.
Salty is offline
Old 26th August 2006, 16:47   #12
mr_bock
mr_bock's Avatar
Garage: 2002 M5, Sterling Gray
Salty,
Good call! I will do an inspection.
Thanks!!
2002 Sterling Gray, Black and Aluminum interior
UUC Short Shifter & DSSR
UUC Clutch Stop
UUC Transmission Supports
UUC UltraSmooth CeraMetallic Clutch/LWF
Active Autowerks Cold Ram Air Intake - Modified
Air Plenum Heat Shield, 1700 degree black Jet-Hot coating
Alpine amp for JL Audio Sub Woofers
UFMotorsport S62 Intake Air Temp Sensor Relocation
Dinan Stage II Suspension
Dinan 3.45 Rear Diff. Gear Set
Dual JL Audio 10" Sub Woofers
K40/Laser Defuserplus, hidden install
K-Mac Adjustable Caster/Camber Plates
Kelleners Aluminum Sport Pedals & Foot Rest
MB Quart speaker replacement
NAV MKIV DVD
StopTech SS Brakelines
Axxis Ultimate Brake Pads
EvoSport Performance Underdrive Pulley Set
TubiStyle Cat-Back Exhaust
Power Chip 93 Gold - Modified & Sport 'On'
Perma-Cool Electric Engine Fan (no mechanical fan!)
Michelin Pilot Sport II Tires (front/rear stock sizes)
Royal Purple Synchromax Transmission Oil
Red Line 75W90 Differential Gear Oil
Sirius Radio receiver
SS Headers, EVO High Flow CATS
Zionsville Aluminum Radiator w/ Dual Speed Fan
My latest toy... a 2001 360 Modena Ferrari
My 'other' car is a supercharged 1996 911 C2 993
mr_bock is offline
Engine Oil Leak Suspected - Non-Linear Oil Usage 507bhp E60 M5 and E61 M5 Touring Discussion 12 10th December 2005 22:05
E39 M5 2001 Complete Engine Failure! benragan E39 M5 and E52 Z8 Discussion 18 13th October 2005 00:26
BMW M6 Press Release no 1: World Debut of the new BMW M6 (short version). Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 4 4th January 2005 20:39
Press Release no 2: The new V10 Power Unit in the BMW M6: A Masterpiece in Engine... Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 15th December 2004 01:15
New M Engine Info greggb E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 34 8th August 2004 18:17
Page generated in 0.10476 seconds with 11 queries
