Old 23rd August 2006, 13:55   #1
vics
vics's Avatar
Garage: 99 HayaBusa & BMW K1200RS
Image of right front wear - thoughts?
Less than 20K on this set -
Anyone hazard a guess as to what adjustment of front end componentry would cure this wear? Left front tire is worn evenly...
Thanks !
00 M5 (8/1/00); 130K, Anthracite/black/fold-down rears/Dinan exhaust/Dinan Stage II software/cold air intake.
99 Copper HayaBusa; 19K, (unrestricted, 196 mph )
98 BMW K1200RS; 110K, The Ultimate BMW K1200/ K1300 Portal
vics is offline
Old 23rd August 2006, 15:15   #2
Luke@tirerack
Luke@tirerack's Avatar
Garage: 2001 Porsche Carrera
looks like a camber issue to me
Luke Pavlick
Perfomance Specialist
ASE Certified Master Tech
For more info or to place
an order please click the
link below my name or call
800-428-8355 ext. 362
for prompt personal service.
www.tirerack.com
Luke@tirerack is offline
Old 23rd August 2006, 15:52   #3
WylM5
WylM5's Avatar
Garage: 91 E34M5 01E39M5
I'm sure Luke would know since he works for Tirerack!! Anyways nothing an alignment won't cure as it looks like too much negative camber.
1991 E34 M5
Dinan Stage III Suspension///Dinan Chip
Brembo Cross Drilled Rotors///HRE 340 Rims
Supersprint Exhaust///UUC Short Shifter
____________________________________
2001 E39 M5
Dinan Front and Rear Brace///Dinan Software///Dinan Differential///Dinan Rear Swaybar///BP Sway bar braket
///Tubi Exhaust
Brembo Front brake kit///UUC Short Shifter///UUC Clutch + Lightweight Flywheel///Rouge Engineering Tranny Mounts///UF Motorsports IATS
///Koni front + rear
WylM5 is offline
Old 23rd August 2006, 16:37   #4
100%Cocoa
100%Cocoa's Avatar
Garage: E39 M5 Carbon Black/Caramel
I'm thinking something is worn in your steering linkage. Interesting to see the tyres for another reason though - I have the same on the front of my beast & have the same cracks around the circumference bnetween the tread blocks. I took it to the guy who fitted them & he said it was nothing to worry about, but I have to admit I get a little concerned at high speed. Have you ever had them checked out?
Cheers,
Barney.
100%Cocoa is offline
Old 23rd August 2006, 16:49   #5
vics
vics's Avatar
Barney.
Hi & nope - they concern me as well - only 14 months old w/cracks?
Anyone recommend a great, local to Boston independent who's capable of tackling this seemingly straight-forward job? The dealer is not an option as far as I'm concerned.
Thanks!
vics is offline
Old 23rd August 2006, 17:08   #6
mr_bock
mr_bock's Avatar
Garage: 2002 M5, Sterling Gray
What make is the tire?
2002 Sterling Gray, Black and Aluminum interior
UUC Short Shifter & DSSR
UUC Clutch Stop
UUC Transmission Supports
UUC UltraSmooth CeraMetallic Clutch/LWF
Active Autowerks Cold Ram Air Intake - Modified
Air Plenum Heat Shield, 1700 degree black Jet-Hot coating
Alpine amp for JL Audio Sub Woofers
UFMotorsport S62 Intake Air Temp Sensor Relocation
Dinan Stage II Suspension
Dinan 3.45 Rear Diff. Gear Set
Dual JL Audio 10" Sub Woofers
K40/Laser Defuserplus, hidden install
K-Mac Adjustable Caster/Camber Plates
Kelleners Aluminum Sport Pedals & Foot Rest
MB Quart speaker replacement
NAV MKIV DVD
StopTech SS Brakelines
Axxis Ultimate Brake Pads
EvoSport Performance Underdrive Pulley Set
TubiStyle Cat-Back Exhaust
Power Chip 93 Gold - Modified & Sport 'On'
Perma-Cool Electric Engine Fan (no mechanical fan!)
Michelin Pilot Sport II Tires (front/rear stock sizes)
Royal Purple Synchromax Transmission Oil
Red Line 75W90 Differential Gear Oil
Sirius Radio receiver
SS Headers, EVO High Flow CATS
Zionsville Aluminum Radiator w/ Dual Speed Fan
My latest toy... a 2001 360 Modena Ferrari
My 'other' car is a supercharged 1996 911 C2 993
mr_bock is offline
Old 23rd August 2006, 18:00   #7
ard
ard's Avatar
Thanks !
Impossible to tell!
(20k I'd be overjoyed with my PS2s....)
Make sure you set your toe to CLOSE to zero (-.02 or -.03 but no more) Folks look at inner edge wear and assume it is cmber- not necessarily true. Too much toe combined with the proper - camber will cause the wear.
BMWs spec is broader than you want to allow- they allow too much front toe. IMHO
A
ard is offline
Old 23rd August 2006, 18:45   #8
Absinthe
Absinthe's Avatar
Garage: Carbon Black 2000
Send a message via Yahoo to Absinthe
I am with ard, toe chews up way more tires that does camber, I am fairly willing to be that wear truns out to be a toe issue and not a camber one, especially due to the nature of the wear ont he next block of tread.
please post your alignment specs when you do have it fixed.
Absinthe is offline
Old 23rd August 2006, 18:59   #9
CHAP6868
CHAP6868's Avatar
Garage: 2000 M5 Black
VIC I have used Wheel Dynamics in Natick ask for Jeff. He really knows his stuff and you get great service
CHAP6868 is offline
Old 23rd August 2006, 23:29   #10
veilside02
veilside02's Avatar
Garage: 2003 BMW M5 Jet Black
Send a message via AIM to veilside02
you probably have a problem with your ball joints
2003 Jet Black /// M5
Rogue SSK/WSR
Rogue Transmission Mounts
Tubi Rumore Exhaust
CA Carbon Rear Diffuser
Active Autowerke Front Grille
Bimmian Shadow Black Grille
K-40 Radar Detector and Laser Jammer
FOR SALE: Hamann Full Front Spoiler
veilside02 is offline
Front License Plate Idea Niknotiq E60 M5 and E61 M5 Touring Discussion 30 11th October 2009 09:01
How to attach front plates without drilling bumper ? d_russian E39 M5 and E52 Z8 Discussion 19 16th November 2006 18:58
Strong Strut front strut tower brace install...pictures and feedback ATLANTA M5 E39 M5 and E52 Z8 Discussion 9 2nd April 2006 12:15
SALE PENDING: E39 M5 Dinan front strut brace (image update) audemars For Sale or Wanted 12 16th January 2006 19:31
Front camber, part II - pic inside, advice req'd EdP E39 M5 and E52 Z8 Discussion 37 3rd June 2005 01:19
Page generated in 0.13969 seconds with 12 queries
