Old 23rd August 2006, 09:46   #1
AlLmItEeM5
AlLmItEeM5's Avatar
Garage: 2001 bmw m5 lemans blue
Send a message via AIM to AlLmItEeM5
Straight pipe or X-pipe
hello all. i have a local muffler shop made a custom magnaflow exhaust for my car. i decided to go with the straight pipes. the high pitch tone sounds really good but didn't notice much on the performance side. lately i notice that my low end torque is gone. can anyone tell me in their opinion or expertise which is better? straight pipes or x pipes is better?
AlLmItEeM5 is offline
Old 23rd August 2006, 10:31   #2
Carrera2RS
Garage: M5
The xpipe is there for a reason, this forms part of the pulse tuned exhaust. It would be expected that removing this reduces torque. Given very little else is changed I would put the xpipe back in the same location (ie approx distance from manifold etc)
This xpipe is no different than running a 4-1 and putting individual pipes on each cylinder as an alternative - yuk
Pressure waves from each cylinder assist scavenging from alternative cylinders, the maths of this is well documented (rules of thumb) and can be accurately modelled on sophisticated programs like Ricardo wave, Engine expert, and simpler systems like dynomation etc
In short the xpipe does something worthwhile, the strength of the pulses at the distance past the cats and manifold will reduce the impact over header lengths, but it is there for a worthwhile reason....
I'd go back to the shop and mod your exhaust
Carrera 2RS
Carrera2RS is offline
Old 23rd August 2006, 11:35   #3
BBM5
BBM5's Avatar
Garage: 2001 E39 M5 Le-Mans Blue
This might explain why i've been feeling a little short changed by the low end torque on my beast. The previous owner had straight pipes put in, in place of the stock resonator which acts like an x-pipe.
BBM5 is offline
Old 23rd August 2006, 17:27   #4
badboypolar
badboypolar's Avatar
Garage: '02 M5 Carbon Schwarz Metallic
Send a message via AIM to badboypolar
the stock resonator is not a x-pipe. the stock configuration has an H pipe right after the cats before going into the stock resonantor.
You can't not be home before you haven't left.
2002 M5
M5Board.com Stickers Now Available
Crackberry E39 M5 Theme Ver 1.0
badboypolar is offline
Old 23rd August 2006, 18:30   #5
BBM5
BBM5's Avatar
Thanks for clearing that up, whats the difference between X and H? and would removing the H pipe for straight through have any detrimental effect on power/torque?
BBM5 is offline
Old 23rd August 2006, 18:40   #6
Absinthe
Absinthe's Avatar
Garage: Carbon Black 2000
Send a message via Yahoo to Absinthe
I have a feeling you are have that inclination about your TQ more due to the 2 ton weight of the car.
I had my resonators chopped as well, made no noticable performance difference, frankly made very little volume difference too, just a little angrier at WOT.
Absinthe is offline
Old 23rd August 2006, 19:23   #7
badboypolar
The X configuration greatly increases scavenging in the exhaust system. Instead of pressure being equalized by a smaller, more restrictive straight piece of pipe, the sides come together in a much more effective design. The X section is larger, and the pipes angle directly into it, meaning the airflow does not have to try and jump from one side to the other to equalize pressure; it is a much smoother transition, leading to better flow numbers than its H-pipe brethren.
From BBK performance website.
Old 24th August 2006, 00:10   #8
AlLmItEeM5
AlLmItEeM5's Avatar
thanks carerra 2rs. i kind of figured that.
BBP's CAI (DIY save $$$) badboypolar E39 M5 and E52 Z8 Discussion 60 29th May 2008 03:59
Eisenmann X-Pipe & Straight Pipe canysmc E60 M5 and E61 M5 Touring Discussion 1 23rd August 2006 07:04
Track Pipe Dyno Results ajw45 E28 M5 Discussion 2 11th May 2006 15:15
Rasp-X pipe & Kelleners exhaust now on! LONG ALX E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 6 7th June 2004 22:12
Finally, a sample of my straight pipe! VanCooper Off Topic Forum 8 23rd October 2002 05:49
Page generated in 0.13169 seconds with 11 queries
