Old 23rd August 2006, 00:54   #1
ehssan_alkhiyami
ehssan_alkhiyami's Avatar
Garage: BMW M5 E60
Send a message via MSN to ehssan_alkhiyami Send a message via Yahoo to ehssan_alkhiyami
Advice on using 540i fuel pump for M5?
my fuel pupm makes a lot of problems recently , so I'm going to change it ..
but the question is , will the 540 fuel pump fits our M5 or it's different .. ?
thanks
E.K
ehssan_alkhiyami is offline
Old 23rd August 2006, 01:03   #2
aaronmiles
aaronmiles's Avatar
Garage: 1999 Imola Red M5
Send a message via MSN to aaronmiles
The part numbers are different yes...
16146752369 is the M5 unit
and
16146752368 is the 540 unit.
1999 Imola Red M5. Extended Caramel Interior
Mods on my pre-update beast:Eisenmann "Race" exhaust (76mm tips), 19" Hamann PG2's, AACAI, Clear Angel Eyes, MK4 Nav, GC's M5 Coilover kit w/front camber plates, Dinan Front and rear sway bars, D/A swaybar mounts, Dinan front and rear strut brace, Braided brake lines, Eibach 3mm wheel spacers, Rogue Engineering underdrive pulleys, IATS Relocation, Powerchip, Xenon foglights & Lower engine covers w/Brake duct cutout
2008 Volkswagen Golf GTI. The wifes new car
2005 Ford Territory Ghia. The wifes car. (Sold)
1986 Toyota Landcruiser HJ75. The farm ute.
aaronmiles is offline
Old 23rd August 2006, 01:05   #3
ehssan_alkhiyami
Garage: BMW M5 E60
I understand , but physically it's exactly the same ,, I've seen it at the dealer ..there is no different at all , I was wondering what could be the different to make it 3 times more expensive ?? ..
anyone tried to replace the stock with 540 unit ?
E.K
Old 23rd August 2006, 10:15   #4
Red line
Garage: '02-M5 Imola Red
Interesting question.
I assume the M5 pump has more gallons per minute flow rate or higher output pressure. Just guessing.
'99 Ferrari 550.
'02 E39 M5 Imola Red. Sold.
'93 Dodge Viper R/T-10. Sold.
'92 Corvette ZR-1. Sold.
Red line is offline
Old 23rd August 2006, 23:07   #5
ehssan_alkhiyami
Garage: BMW M5 E60
exactly ,, this is what I found out .. the normal 5 series fuel pump will work but you can easily feel the different in the acceleration . so I'll pick up the OEM tomorrow in the morning .. and as the same time I'll change the left fuel gauge leveler as well , the beast will have a brand new fuel pump and gauges levelers ... happy for her ..
E.K
Old 24th August 2006, 00:01   #6
DrewKeen
DrewKeen's Avatar
Garage: Imola M5, Black SVT Cobra, Orange Pinto
Send a message via AIM to DrewKeen
The M5 pump flows more fuel. Is your fuel level sensor broken? If not there is no reason to replace it. The fuel pump is also located on the right (passenger) side of the car.
Imola Red; Black/Silver Sport
DrewKeen is offline
Old 24th August 2006, 00:04   #7
ehssan_alkhiyami
Garage: BMW M5 E60
Well acuatlly the new pump will come with the right leveler ,, and currently I'm having a problem that sometimes the fuel gauge gives a wrong information .. and anyway it's cheap to replace , something like 35 $ after discount .. so it worth it ..
E.K
Old 24th August 2006, 01:37   #8
aaronmiles
aaronmiles's Avatar
Check the connections to the pump also.. I've seen it where they can become frayed overtime... by this I mean at the end that screws into the tank, not the actual pump end. They are covered by a plastic sheath that can come away etc.
I replaced mine when the resistance was rather high and thus not pumping as well as it should...
Old 24th August 2006, 01:39   #9
ehssan_alkhiyami
Garage: BMW M5 E60
yeah sure , I will do that as well .. thanks for the information bro ..
E.K
Old 29th August 2006, 18:35   #10
willm5ad
willm5ad's Avatar
Garage: m5 indi oxford green 2000 335i 2007
I still have that problem at 1/4 tank my car starts to hunt for some reason, fill her up and all ok again, anybody understand why?
WillM5AD
willm5ad is offline
If you want to out-accelerate a 540i samson E34 M5 Discussion 87 24th November 2006 12:47
power steering pump - help please... mfiverx2 E34 M5 Discussion 2 15th July 2005 09:20
Loose Oil Pump Bolts...... Lscman E39 M5 and E52 Z8 Discussion 2 27th March 2005 20:43
Air pump problems mikek E34 M5 Discussion 7 30th December 2001 20:53
Page generated in 0.15866 seconds with 11 queries
