21st August 2006, 20:25
#1 (permalink)
Here it is - $150.00 AEM Custom Air Intake CAI - (PICS)
TQ2K -  |
'03 BMW M5 - Individual Petrol Mica/Champagne
- UUC Evo III SSK, DSSR, & Clutch Stop
- OEM Bluetooth + Snap-in Adapter | OEM Backup Camera
- SS Headers, X-Pipe, Exhaust | Dinan CAI + HFM + IATS
- Dinan S2 (Koni) & Rear Strut Brace | Strong Strut Brace
- Brake Ducts | 19" BBS CH Wheels | TCD Brackets
- Custom PC Gold 93v3 | Dinan Lightened Dual-Mass Flywheel
'04 BMW X5 4.4i - Alpine White/Truffle
21st August 2006, 22:11
#2 (permalink)
Nice writeup, been meaning to do this since I saw the original post
Did you notice any more "growl" from the motor with a better flowing cone filter over the stock panel filters?
Chris
21st August 2006, 22:19
#3 (permalink)
Very nicely done. I was looking through your dyno's and noticed how much your air/fuel fluctuated. Mine went to the line (12.5 or so I think) and stayed flat untill dropping down to the rich side at the top of the rpm range. What does that mean?....?.., I haven't the slightest! Do you?
Jason
'01 Titanium Silver Metallic/Silverstone Extended
Ex-mod Queen, now back to Stock!
'97 Boston Green M3
The new TRACK BEEEEEEEEE-ATCH!!!!!!!!!!!!
- JRZ RS, Ground Control, Ractech, Momo, Eibach, Toyo, etc.
21st August 2006, 22:22
#4 (permalink)
Not my Dyno run... It's M5BOSS' Dyno run after he installed the AEM Dryflow filters...
My M5 does feel a bit more responsive now...
TQ2K -  |
21st August 2006, 22:32
#5 (permalink)
I'm sure your MAF's like the new system allot better!
Jason
'97 Boston Green M3
21st August 2006, 22:33
#6 (permalink)
Is that 12hp on MTBE fuel or Ethanol?
I'm thinking this might offset the loss of power Ethanol has robbed us of.
The Upgrades: MKIV Nav Unit / JL 500.1 Amp / JL 12w6v2 Sub / UUC Evo III SSK / UUC DSSR / UUC Tranny mounts / MKIV Nav Upgrade / TCD Sway Bar Brackets
22nd August 2006, 04:49
#7 (permalink)
Thanks! Haven't noticed any growl when revving with the hood down and sitting on the driver's seat... Will try to observe this weekend...
TQ2K -  |
22nd August 2006, 06:40
#8 (permalink)
I did the same except...
instead of the aluminum tape, I used some of that permatex sealant putty to seal the inside and outside of the mandrel bent tube as it goes through the top of the filter box. You kneed the epoxy putty together with you fingers for a minute, it has two different chemicals in a neat little putty material that you can then roll between your hands forming a long bead of putty that you then wrap around the pipe where it goes through the filter box. Just seal both sides up. It hardens in 10 min or so. I tried the tape method but I could see light come through as I held it up to a shop light. That means dirty air could come through too.
I cut the mandrel pipes just as they come out of their bend on both sides, so you are cutting off most of the pipe on both ends.
You can pick this stuff up at any auto parts store but this is one brand of the material, the second or 3rd item listed is the stuff... http://www.caswellplating.com/permat...pairprods.html
Nice pics of the job here TQ2K!
M5 Dave
2000 TiSilver M5 - Supersprint Headers, Tubi Catback Exhaust, Active Autowerke Tuned ECU, Active Autowerke CAI, Custom Hi-Flow Air Filtration, UUC 11" Performance Organic Clutch/Aluminum Flywheel, UUC Short Shifter, UUC DSSR, UUC Clutch Stop, UUC Tranny Mounts, Strong Strut Front Strut Bar, Riken Raptor Tires, AXXIS Deluxe Plus Brake Pads, UUC Shifter Knob, DEPO Projector39 HID DDE Clear Corner Headlights, Xtec HID Xenon Low beams, High Beams and Fogs (six ballasts), MK4-16:9-V28 Nav Upgrade, Bimmian Interior Xenox Lighting, V1 Radar Locater.
22nd August 2006, 06:58
#9 (permalink)
What did you use to cut the pipes with?
22nd August 2006, 08:45
#10 (permalink)
Nice write up and photos, much better then what was never done on the other thread.
I hope you pulled the burrs off the pipe in pictures 13/14. That could break off and get sucked right into the engine and cause some major grooves cut into the bore.
Next rework the tubing to the factory air box.
I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way.
Modifications
Chipped paint
Worn tyres
Dirty Carpet
Chipped windshield
