Old 19th August 2006, 01:53   #1
lestat832
lestat832's Avatar
Garage: 2003 Sterling Grey M5
Send a message via AIM to lestat832
Griot Garage's Hand Pump Oil/Liquid Extractor
Hi all,
Perusing through the new catalog and came upon this product. The website actually says that this method extracts more oil than draining.
http://www.griotsgarage.com/search.j...text=hand+pump
Does anybody have any experience with this? Anyone tried it with the beast?
Thanks,
MCG
lestat832 is offline
Old 19th August 2006, 02:05   #2
BKH
BKH's Avatar
Garage: 2000 BMW M5 Silverstone
I use something similar and I wouldn't go back to draining oil the old-fashioned way. You'll wonder why you didn't get one sooner.
BKH is offline
Old 19th August 2006, 02:06   #3
BKH
BKH's Avatar
Hey, now that I look at the Griot's version it's identical to mine. Highly recommended!
BKH is offline
Old 19th August 2006, 02:07   #4
lestat832
lestat832's Avatar
mind if i ask which product you are using?
i like to do comparison tests
thanks my friend
Old 19th August 2006, 02:09   #5
BKH
BKH's Avatar
I use the Pela 650:
http://www.pelaproducts.com/
BKH is offline
Old 19th August 2006, 05:22   #6
M5Joe
M5Joe's Avatar
Garage: BMW M5 Anthracite
Have used the Griot's evacuator for years. Works great on the M5 but not as well on other cars (my e30 M3). I had a cheaper model from BMP but this one was nearly useless as the metal container made it impossible to tell if the collecter tank was full vs not working or working fine. The Griot's model is about a quart shy on capacity; you have to dump a little and then reattach the tubing, but this is a minor inconvenience. A theoretical problem with top side evacuators is that they leave debris in the bottom of the oil pain. I have my local independent BMW mechanic do the inspections and therefore the oil gets drained conventionally every 30k miles. I do my own oil changes every 7500 miles. 106k miles to date.
Joe
M5Joe is offline
Old 20th August 2006, 03:15   #7
lestat832
lestat832's Avatar
Thanks for the info.
BKH, have any of you encountered that problem with debris in the oil pan when using these kind of pumps?
M5Joe, has your dealer noticed the presence of debris when in for a regular oil change?
Old 20th August 2006, 03:16   #8
Hawkwind
Hawkwind's Avatar
Garage: 2003 M5 Sterling Gray
Check out the Mityvac 7400. Tooltopia.com has it for $45., $7 shipping. Holds a little over 7 liters.
Hawkwind is offline
Old 20th August 2006, 03:46   #9
BKH
BKH's Avatar
No, never. What kind of debris could there be? If you change your oil when it's warm the contaminants that are not captured by the filter are held in suspension and sucked out. IMO these pumps are the only way to go.
BKH is offline
Old 20th August 2006, 05:13   #10
greg
greg's Avatar
Garage: 2000 Anthracite
Counterpoint: Not all contaminants are held in suspension - heavy ones settle out and stay at the lowest point, near the drain plug. The BMW is the easiest oil change of any car I've ever owned. I'll stick to the drain plug.
greg is offline
Page generated in 0.13710 seconds with 10 queries
