Old 12th August 2006, 16:11   #1
CWY_M5
CWY_M5's Avatar
Garage: '00 M5 Silver; '91 M5 white; '01 525iT white; '94 525ia Black
Preventive Maintenance?
Just wondering, how many people swap things out before they fail - just so you won't be "FORD" - found on road dead.
my '00 beast has 85k miles now. Other than the suspension, front end, bushings, etc which I will definitely address this winter as my winter garage project, any comments with things like water pump, thermostat, fuel pump, alternator, etc etc?
Just for kicks, when do you have parts fail that leaves you dead on the road? What else should I be looking out for?
Chino
CWY_M5
E39 M5
'00 Titan Silver
99k miles
Koni FSD with Stock Springs and Vines arms
Intravee iPOD adapter
Clear Headlight w/ angel eye (CCFL)
Rear CELIS LED lights
BlueTooth Retrofit (LOVE THIS)
V1 direct wire w/ Blinder Extreme M20
MK-IV DVD Nav upgrade w/ 16x9 wide screen monitor
M-Sports Steering Wheel upgrade
E34 M5 '91 White (Newly acquired)
110k miles
Bone Stock - make your suggestions!!!
Other BMWs:
E34 525ia '94 Black (189k mi)
- Power chipped
- Bluetooth (Motorola)
- V1 direct wiring
- HID projector headlight
- Updated suspension (DIY)
E39 525iTa '01 White (68k mi)
- V1 direct wiring
CWY_M5 is offline
Old 12th August 2006, 17:56   #2
ard
ard's Avatar
Spare tire in the trunk. This has to be the vastly more likely failure that will leave you wating for a truck.
Battery?
Hoses?
At some point the odds of failure of one specific part get so small, and are distributed to 10, 20 items that the cost to replace all is silly. Choosing 2 or 3 to replace is a crapshoot and doesn't change, really, your odds of getting stranded.
ard is offline
Old 12th August 2006, 18:02   #3
KirklandM5
KirklandM5's Avatar
Garage: 2001 M5 Titanium Silver
Send a message via AIM to KirklandM5 Send a message via Yahoo to KirklandM5
1. Battery
2. Belts
3. Rebuild Entire cooling system Radiator, pump, thermostat, ALL HOSES. maybe at around 80K miles
4. Alternator good til around 120K miles
2001 E39 M5 Titanium Silver/Silverstone
1997 BMW M3 Gruppe N Race Car
2005 X5 4.4i
KirklandM5 is offline
Old 12th August 2006, 18:17   #4
DrewKeen
DrewKeen's Avatar
Garage: Imola M5, Black SVT Cobra, Orange Pinto
Send a message via AIM to DrewKeen
If it ain't broke, don't fix it.
My fuel pump died at right around 100k and left me stranded. I got it towed and replaced it myself.
Imola Red; Black/Silver Sport
DrewKeen is offline
Old 12th August 2006, 18:21   #5
Mike Krieger
Mike Krieger's Avatar
Garage: 2000 M5 Oxford Green
Since you are driving a 2000, I think the most important preventative maintenance you could do to save money, but not affect your ability to drive would be to take off the pipe between the two heads for the secondary air injection and drill a hole in at as shown many places elsewhere on this site, and periodically spray carb cleaner in it just before starting up when your engine is cold. The air pump runs for about two minutes and will blow the carb cleaner through the ports in your heads and prevent the carbon build-up that will cost you over $8,000 to fix. Next I would buy BeastPower rear sway bar brackets because if your stock brackets aren't broken now, they will be soon.
2000 Oxford Green/Extended Caramel
Split folding seats with ski bag
Alacantra headliner
Mk. IV nav upgrade v.27
16:9 monitor
UF Motorsport Intake air temp. sensor relocation
Bimmernav Bluetooth
PowerChip 93
Royal Purple Synchromax
OEM First Aid Kit
Hardwired V1
AA CAI
Bavarian Auto Angel Eye update
Supersprint headers, SS X-pipe and Evo Racing Cats
Dinan Stage 2 suspension
Dinan 3.45 Diff
Mike Krieger is offline
Old 12th August 2006, 19:35   #6
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
there is nothing special about a 2000 that leads it to develop carbon buildup. The other years will have it happen with the same frequency (which is not that great) as they age. I have yet to see anyone proove spraying carb cleaner into the smog ports will help prevent this. (or perhaps not cause some other damage down the line somewhere). My car had it's heads off at 73k miles, and the smog ports were not blocked at all, there was a little carbon in them, but they were 90% open.
Sway bar brackets will break, but i can't see how they would leave you stranded. I replaced my thermostat and water pump at the 73k mark just because the engine was apart, and figured it made sense at the time.
We have not seen huge issues with failing radiators with the m5, like 540s, perhaps just not as many numbers, but i can't recall any posts on the board. The M5 rad is a different part than the 540, so perhaps that is why. I've been told by both my dealer and my independent shop that hoses are easily 100k items, so i'll wait on those. Do check your fan clutch, i had mine become loose around 50k, got it replaced under warranty, but they do occasionally fail, and can make a mess.
I once replaced a fuel pump on my e34 525iT prophylactically at 100k, only to have a defective replacement that failed 5k miles later leaving me on the side of the road, so i'm waiting until my oe unit fails! How old is your battery?
I too carry a spare on trips, around town, i take my chances with M mobility. Then again, i could walk home if needed and get my spare....
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 12th August 2006, 19:48   #7
Mike Krieger
Congratulations on your clean heads. For those of us who have higher mileage (and 2000s are more likely than others to have high mileage), the carbon thing is a big deal. Since the hole in the pipe is a cheap project and could delay the need for head removal until you want to take them off for something fun like porting, I think it is a good idea. I suppose the proof you seek would require someone with partially blocked ports to measure the air flow through the ports, then install the hole and perform the carb cleaner routine for a while and then measure the flow through the ports to see if it has prevented more build-up. I find that to be an unlikely scenario since most people would just clean the ports if they had the heads off. I suppose someone really devoted might spend the money for the sake of research or to help other board members, but it is an expensive experiment. If you had clean ports to start with and after running the experiment you still had clean ports, it wouldn't prove anything so you fortunate souls without the carbon problem can keep doing whatever you are doing. For those of us with the SES light and not enough money (my dealer wants $12,500) for the cleaning, it seems like good preventative maintenance, although as you pointed out, and as I mentioned at the beginning of my post, these will "not affect your ability to drive."
Old 14th August 2006, 01:06   #8
wilsodh
wilsodh's Avatar
Hi Mike,
The original 'pioneer' on this was Luke 'LLCoolM5'. He did the drilling/solvent procedure, but it did not meet with much success. After cleaning out his secondary air tubes and running solvent through the system (including the head ports), I believe his SES light came back on in a few months, prompting him to contemplate more extreme plumbing measures. Granted, his secondary air system was clogged before the solvent procedure, but in a separate experiment he exposed carbon scrapings from his secondary tubes to various strong organic solvents. The scrapings did not show encouraging solubility tendencies. The evidence might suggest that occasional exposure to carb cleaner will probably have minimal impact on the chronic deposition of this hard carbon.
For those of us with the SES light and not enough money (my dealer wants $12,500) for the cleaning"
Have you taken this up with BMWNA directly? PM me and let's discuss. Alternatively, if you want to get your light off, we are hoping to get in our first trials of our secondary air system by-pass circuit in September. If you would like to participate, let me know.
Dave
'00 Royal Red/black/walnut M5
'El Diablo'
’00 Black/black DA s/c M5
Carrillo rods, Arias pistons,
Schrick cams, Vortech T-trim,
Supersprint headers/exhaust,
wilsodh is offline
Old 7th November 2006, 03:26   #9
FredW
FredW's Avatar
Garage: 2001 Titanium Silver
Tech Recommendation from Roundel magazine
I just read the latest recommendations from the Tech editor in Roundel Magazine. The three things recommended that I've not done in the past on my other BMWs are changing the water pump and thermostat at 60,000 miles and the radiator at 90,000 miles.
His recommendations were aimed at the generic 3s and 5s. I'm wondering if the M5 has heavier duty cooling or it might be a good idea.
I'm at 67,000 miles now.
That's my opinion, although I might not agree with it.
2001 M5, Titanium Silver, Black, Stock.(sold)
2005 Audi S4 Cabriolet, Moros Blue, Light Grey Interior
2003 X5 3.0, Grey Green Metalic
1994 B757-200
2001 B757-300
1999 B767-200ER
2002 B767-400ER
FredW is offline
Old 7th November 2006, 07:54   #10
SCC
SCC's Avatar
Garage: 2000 M5 Carbon Black
Dave
Dave this is the first I have heard of these trials. Is there a thread that discusses what this is all about? If not is this going to be an open discussion? Thx
Chris
00 M5 Carbon Black /All leather - Black/Bruyere Club/Alcantra Headliner
325i Sport (sold)
SCC is offline
E39 M5 Maintenance Nix930 E39 M5 and E52 Z8 Discussion 14 22nd November 2005 06:44
What's covered in standard maintenance agreement jlindy E39 M5 and E52 Z8 Discussion 2 23rd March 2005 20:58
Maintenance Warranty and Service Codes SpiderSense E39 M5 and E52 Z8 Discussion 3 11th January 2005 16:37
Extended Scheduled Maintenance Program HireM5 E39 M5 and E52 Z8 Discussion 3 29th June 2004 19:23
Need Advice - 2 year maintenance appointment M5xtc E39 M5 and E52 Z8 Discussion 3 23rd January 2004 06:02
Page generated in 0.17886 seconds with 11 queries
