Old 10th August 2006, 07:35   #1
kmfullM5
Garage: 2001 M5 Lemans Blue
Mild Performance mods for track days with E39
Hey gang, I'm a new member that recently bought a 2001 E39 M5. I love the car and think it is the best compromise between usability and performance. I plan on doing a couple of track weekends a year and wanted to get some feedback as to what kind of mods you might suggest. I was thinking about concentrating on some sway bars, adjustable shocks, and upgraded brakes. Also, I was looking at a short shift kit. Anybody that tracks their M5, have you seen any weeknesses with the car or is there anything I should be concerned about mechanically?
I appreciate your help. I live in the Cincinnati OH area if anyone is local.
Thanks again.
Kent
kmfullM5 is offline
Old 10th August 2006, 07:45   #2
ard
ard's Avatar
Pretty good list. The concensus seems to be that not much improvement is gained by changing the front bar.
275 tires on all 4 corners, a Ground Control system, 430lb./in front, 340 or 380 rear, a dinan rear sway bar would tranform the handling. Add a front BBK, or all 4 if you can swing it and you'd be set.
Welcome!
Adam
PS Not sure what that "compromise" thing is you're referring to....
ard is offline
Old 10th August 2006, 09:22   #3
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
Adam's description above would likely make a really nice handling M5 for the occasional track day. Not sure exactly how much compromise you'd get day to day with the springs. Bigger front tires, open the brake ducts and get some high temp fluid first, that will be cheap and have no downside (other than mild tramlining over uneven pavement with the bigger fronts). A rear sway bar is cheap and will help dial out more understeer. Go from there. This assumes you already have some track experience.
I have the dinan stage 3 set up and am pleased with it's compromise, certainly not a track oriented suspension, but considering this is my daily driver 355 days a year, and a track car maybe ten days a year (if i'm lucky) it works for me.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 10th August 2006, 21:00   #4
M5Kid
Garage: N/A
Mike,
I've hear so many things about Dinan's Stg. 3 from different owners and the level of it's compliance comapred to stock suspension. Is it actually noticably firmer? I was in S.F. recently on vacation and noticed some pretty rough freeways and roads in the city. How does it fair on these?
If the owner could swing it, do you think they would be better off just upgrading to Dinan Stg. 3 off the bat?
Travis
M5Kid is offline
Old 10th August 2006, 21:19   #5
mottati
mottati's Avatar
Hi Travis, it is definately firmer, but it really depends on the shock adjustment, and which shocks are being run. I hear people with JRZ's say its significantly firmer, but the jrzs have more range of adjustment, so i've read, so it should be possible to make a jrz equipt car ride better than a koni car. I have koni's, and played around with the front setting a bit initialy, but generally leave it in the same setting. I personally wouldn't want any firmer or lower for my day to day drive.
Originally Posted by M5Kid
Mike,
Travis
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 14th August 2006, 23:26   #6
kmfullM5
Hey, Thanks for the info. The rear bar sounds like a good idea. I was also going to include the brake fluid and pad swap. I have had good experience with Hawk HP+ pads in the past at the track. Is there another pad anyone might suggest? Also, I've used Koni yellows in the past and was pleased with their improvement in performance while still being adjustable to a relatively comfortable ride. I'm not familiar with the JRZs. How do these compare?
I have had some track experience in the past, just not with this car. I am going from a front drive, turbo charged car to rear wheel, normally aspirated. I think it's going to feel like I'm starting from scratch.
The compromise I was referring to had nothing to do with the performance of the BMW. We just had our first child and I wanted something that could hold a kid seat in the back if necessary. I was looking for the best "do-it-all" car.
Thanks again for the help.
kmfullM5 is offline
Old 15th August 2006, 05:30   #7
drabe
Garage: Black 1991 E34 M5
I track my M5. I have the GC kit with 550 front and 425 rear, Dinan bars and the Stop Tech BBK. I run 275 all around. The main weakness is the weight. The GC setup help mitigate some of the understeer. The Stop Techs are superb. I would change the fluids frequently even if the schedule doesn't call for it. Driving style may be important---the car has a lot of torque so be sure you accelerate after the apex otherwise you may be in for some suprises.
drabe is offline
M5 E39 Body Style S62 engine FACTS...Long V-10 4 Me E39 M5 and E52 Z8 Discussion 53 22nd March 2009 16:12
What is the best Bang for Buck mods for E39 M5 seanv E39 M5 and E52 Z8 Discussion 21 19th April 2004 02:36
Dinan Exhaust AlbertM E39 M5 and E52 Z8 Discussion 5 6th October 2000 19:11
Page generated in 0.15065 seconds with 11 queries
